with the post I actually use , if I generate a canned thread the code comes out as G76 X.. Z.. K.. D.. A.. F.. which is OK. F is the Lead If I generate a Long hand thread the generated code looks like G33 Z-1 F.05 F is the lead..which is wrong. For (G33 only) the letter of the lead should be K instead of F. I did try different solutions but did not find the solution.. the modification should only change the prefix of the lead for thread generation.. in my attempts it would be ok if my toolpath contained only threads.. but if I added a linear move like G01 Z-1 F2 the output code for the feed would come out as K2 if i had just generated a Long hand thread(g33) I know it is not a big deal and that i can correct the generated code by hand but i am trying to understand how to modify a post...I look at it as a challenge... thanks for the help . the code is following pffr #Output feedrate, force if ipr_actv$ = zero, pfr_m else, pfr_l *feed pfr #Output feedrate if ipr_actv$ = zero, pfr_m else, pfr_l `feed pfr_m #Format feedrate for lathe result = nwadrs(strf, feed) result = newfs (17, feed) pfr_l #Format feedrate for mill if opcode$ = 104, [ #Format feedrate for lathe thread result = nwadrs(strf, feed) result = newfs (19, feed) ] else, [ result = nwadrs(strf, feed) result = newfs (18, feed) ] pscool #Coolant is separate code if cool_w_spd = zero, scoolant else, [ # 'cool_w_spd' mode is active - (1/10/2003) if coolant$ = zero, scoolant #Turn coolant OFF else, if prv_coolant$ = zero, scoolant #Turn coolant ON ] !coolant$ pfscool #Coolant is separate code, force if cool_w_spd = zero, *scoolant !coolant$ pcc_capture #Capture ends of canned turning path, stop output w/rough #Stop output in rough only lathe canned cycles #between rough and finish paths if cc_stop_fcc & rcc_flg$ = 6, no_nc_out$ = one #Capture vector for G73 cycle if rpd_typ$ = 6 & abs(lathecc) = two, [ if rcc_flg$ = one, lcc_xcst = vequ (copy_x) if rcc_flg$ = three, lcc_xcend = vequ (copy_x) ] pcom_moveb #Common motion preparation routines, before pshft_map_xa pxyzcout ps_inc_calc ppos_cax_lin #Position C if from CL if (prv_pnt_at_zero) & c_axistype < three, [ #Output to NC, C axis movement only - rapid deg/min sav_gcode = gcode$ sav_feed = feed gcode$ = one if millcc = zero, [ feed = maxfrdeg pbld, n$, psgcode, pfcout, pffr, e$ ] else, pbld, n$, psgcode, pfcout, pfr, e$ gcode$ = sav_gcode feed = sav_feed ] pcom_movea #Common motion preparation routines, after pcan2 pe_inc_calc ppos_pnt_zero #Position C if from CL !pnt_at_zero pnt_at_zero = zero #Mill canned cycle output pmillccb #Cross/Face canned cycle code, before if c1_millcc = n1_millcc & n1_millcc & n1_gcode = 1000 & cutpos2$ = three, [ sav_cutpos2 = two cutpos2$ = two ] if cutpos2$ = one, [ result = newfs(two, cabs) result = newfs(two, cinc) #Cross/Face canned cycle start code if abs(cuttype) = two, [ #Face canned cycle start code, G112 (break ramp) pbld, n$, *sgfeed, *sgcode, *sg112, e$ prv_xabs = c9k prv_xinc = c9k prv_cabs = c9k prv_cinc = c9k compok = one ] else, [ #Cross canned cycle start code, G107 pbld, n$, *sgcode, *sgfeed, *sg107, *crad, e$ ] ] if cutpos2$ > zero & cutpos2$ < four, [ #Change rapid to highest possible feedrate if gcode$ = zero, [ gcode$ = one feed = maxfeedpm ] ] pmillcca #Cross/Face canned cycle code, after if cutpos2$ = three, [ #Cross/Face canned cycle end code if abs(cuttype) = two, pbld, n$, *sg113, e$ #Face else, pbld, n$, *sg108, "C0.", e$ #Cross result = newfs(11, cabs) result = newfs(14, cinc) ] # -------------------------------------------------------------------------- # Drilling # -------------------------------------------------------------------------- pdrill0$ #Pre-drill postblock call if cuttype = five, #Don't allow 5 axis, rests at toolchange [ usecandrill$ = zero usecanpeck$ = zero usecanchip$ = zero usecantap$ = zero usecanbore1$ = zero usecanbore2$ = zero usecanmisc1$ = zero usecanmisc2$ = zero ] else, [ if abs(cuttype) < three, mdrl_dir = zero else, mdrl_dir = one x$ = xnci$ y$ = ynci$ z$ = refht$ copy_x = vequ(x$) pshft_map_xa pxyzcout refht_x = vequ(xabs) z$ = depth$ copy_x = vequ(x$) pshft_map_xa pxyzcout depth_x = vequ(xabs) z$ = zdrl$ copy_x = vequ(x$) pshft_map_xa pxyzcout zdrl_x = vequ(xabs) z$ = initht$ #Initial is last copy_x = vequ(x$) pshft_map_xa pxyzcout initht_x = vequ(xabs) znci$ = initht$ ps_inc_calc ] pdrlcommonb #Canned Drill Cycle common call, before if gcode$ = 81, [ if drillcyc$ = three, drlgsel = fsg1 (-g_speed) + drillcyc$ * two #Tap else, drlgsel = fsg2 (dwell$) + drillcyc$ * two if initht$ <> refht$, drillref = zero else, drillref = one prv_refht_a = c9k prv_refht_i = c9k prv_dwell$ = zero ] if mdrl_dir = zero, #Set Z to depth [ zia = fmtrnd(depth_z) zinc = zia - prv_zia ] else, #Set X to depth [ xia = fmtrnd(depth_x) xinc = xia - prv_xia ] xabs = vequ (depth_x) comment$ pcan pgdrlout #Drill Gcode output if mdrl_dir = zero, *sgdrillf else, *sgdrillc prdrlout #R drill position if mdrl_dir = zero, refht_a = refht_z else, refht_a = refht_x refht_i = refht$ - initht$ if absinc$ = zero, refht_a, !refht_i else, refht_i, !refht_a ldrill$ #Canned drill cycle, lathe #Use this postblock to customize lathe drilling cycles 0 - 7 pdrlcommonb "CUSTOMIZABLE DRILL CYCLE ", pfxout, pfyout, pfzout, e$ pcom_movea lpeck$ #Canned peck drill cycle, lathe ldrill$ lchpbrk$ #Canned chip break cycle, lathe gcode$ = zero prv_dwell$ = zero @dwell$ comment$ pcan pe_inc_calc xabs = vequ(refht_x) ps_inc_calc pcan1, pbld, n$, sgcode, pzout, strcantext,e$ pe_inc_calc xabs = vequ(depth_x) ps_inc_calc if old_new_sw = one, [ pbld, n$, *sg74, *peckclr$, e$ result = nwadrs (strq, peck1$) ] else, result = nwadrs (strk, peck1$) pcan1, pbld, n$, *sg74, pfzout, *peck1$, pffr, strcantext, e$ prv_gcode$ = -1 if refht$ <> initht$, [ gcode$ = zero xabs = vequ(refht_x) ps_inc_calc pe_inc_calc xabs = vequ(initht_x) ps_inc_calc pbld, n$, sgcode, pfzout, e$ ] pcom_movea ltap$ #Canned tap cycle, lathe gcode$ = zero prv_dwell$ = zero @dwell$ comment$ pcan pe_inc_calc xabs = vequ(refht_x) ps_inc_calc pcan1, pbld, n$, sgcode, pzout, strcantext, e$ pe_inc_calc xabs = vequ(depth_x) ps_inc_calc opcode$ = 104 #thread address from feedrate #andre pffr pour try pbld, n$, *sthdg32, pfzout, pffr, pnullstop, e$ if dwell$, pdwell1 pe_inc_calc xabs = vequ(refht_x) ps_inc_calc pswtchspin pbld, n$, *sthdg32, pfzout, *spindle_l, e$ if dwell$, pdwell1 prv_gcode$ = -1 pbld, n$, pnullstop,e$ pswtchspin if refht$ <> initht$, [ gcode$ = zero pe_inc_calc xabs = vequ(initht_x) ps_inc_calc pbld, n$, sgcode, pfzout, *spindle_l, e$ ] pbld, n$, spindle_l, e$ opcode$ = 81 #Restore opcode pcom_movea lbore1$ #Canned bore #1 cycle, lathe ldrill$ lbore2$ #Canned bore #2 cycle, lathe ldrill$ lmisc1$ #Canned misc #1 cycle, lathe ldrill$ lmisc2$ #Canned misc #2 cycle, lathe ldrill$ mdrill$ #Canned drill cycle, mill pdrlcommonb pcan1, pbld, n$, *sgdrlref, pgdrlout, pxout, pyout, pzout, pcout, prdrlout, dwell$, pffr, strcantext, e$ pcom_movea mpeck$ #Canned peck drill cycle, mill pdrlcommonb pcan1, pbld, n$, *sgdrlref, pgdrlout, pxout, pyout, pzout, pcout, prdrlout, *peck1$, dwell$, pffr, strcantext, e$ pcom_movea mchpbrk$ #Canned chip break cycle, mill mpeck$ mtap$ #Canned tap cycle, mill pdrlcommonb pcan1, pbld, n$, *sgdrlref, pgdrlout, pxout, pyout, pzout, pcout, prdrlout, pffr, strcantext, e$ pcom_movea mbore1$ #Canned bore #1 cycle, mill mdrill$ mbore2$ #Canned bore #2 cycle, mill mdrill$ mmisc1$ #Canned misc #1 cycle, mill pdrlcommonb pcan1, pbld, n$, *sgdrlref, pgdrlout, pxout, pyout, pzout, pcout, prdrlout, *shftdrl$, dwell$, pffr, strcantext, e$ pcom_movea mmisc2$ #Canned misc #2 cycle, mill mdrill_2$ #Canned drill cycle repeat, mill pdrlcommonb pcan1, pbld, n$, pxout, pyout, pzout, pcout, prdrlout, dwell$, pfr, strcantext, e$ pcom_movea mpeck_2$ #Canned peck drill cycle repeat, mill mdrill_2$ mchpbrk_2$ #Canned chip break cycle repeat, mill mdrill_2$ mtap_2$ #Canned tap cycle repeat, mill mdrill_2$ mbore1_2$ #Canned bore #1 cycle repeat, mill mdrill_2$ mbore2_2$ #Canned bore #2 cycle repeat, mill mdrill_2$ mmisc1_2$ #Canned misc #1 cycle repeat, mill mdrill_2$ mmisc2_2$ #Canned misc #2 cycle repeat, mill mdrill_2$ pdrlcst$ #Custom drill cycles 8 - 19 (user option) #Use this postblock to customize drilling cycles 8 - 19 pdrlcommonb "CUSTOMIZABLE DRILL CYCLE ", pfxout, pfyout, pfzout, pfcout, e$ pcom_movea pdrlcst_2$ #Custom drill cycles 8 - 19 (user option) #Use this postblock to customize drilling cycles 8 - 19 pdrlcommonb "CUSTOMIZABLE DRILL CYCLE ", pfxout, pfyout, pfzout, pfcout, e$ pcom_movea pcanceldc$ #Cancel drill cycle xabs = vequ (initht_x) #Position to return ps_inc_calc pe_inc_calc #Update to current location gcode$ = zero pcan pcan1, pbld, n$, sgcode, "G80", strcantext, e$ pcan2 # -------------------------------------------------------------------------- # Version 9+ MiscOps Section # -------------------------------------------------------------------------- #Miscellaneous Variables Common to all Miscops operations #Format as needed #Integers #miscops_mi1, miscops_mi2, miscops_mi3, #miscops_mi4, miscops_mi5, miscops_mi6, #miscops_mi7, miscops_mi8, miscops_mi9, #miscops_mi10 #Reals #miscops_mr1, miscops_mr2, miscops_mr3, #miscops_mr4, miscops_mr5, miscops_mr6, #miscops_mr7, miscops_mr8, miscops_mr9, #miscops_mr10 # # -------------------------------------------------------------------------- #Format Assignments and Initializations # -------------------------------------------------------------------------- fmt Z 2 stck_init_z$ #Initial Z position of the stock (900-902,904,905) fmt Z 2 stck_final_z$ #Final Z position of the stock (900-902,904,905) fmt Z 2 stck_chuk_st_z$ #Initial Z axis Chuck Position (900-903) fmt X 2 stck_chuk_st_x$ #Initial X axis Chuck Position (900-903) fmt Z 2 stck_chuk_end_z$ #Final Z axis Chuck Position (900-903) fmt X 2 stck_chuk_end_x$ #Final X axis Chuck Position (900-903) fmt W 3 stck_chuk_st_dz$ #Destination chuck Z axis reference position before transfer (900) fmt U 3 stck_chuk_st_dx$ #Destination chuck X axis reference position before transfer (900) fmt W 3 stck_chuk_end_dz$ #Destination chuck Z axis reference position after transfer (900) fmt U 3 stck_chuk_end_dx$ #Destination chuck X axis reference position after transfer (900) fmt Z 2 stck_clear$ #Stock clearance value for stock pull operation (902) fmt X 2 stck_tool_x$ #Tool X axis position for bar stop / puller (902) fmt Z 2 stck_grip$ #Grip length value for stock pull operation(902) fmt F 18 stck_adv_fr$ #Used with Lathe Stock Advance (Bar-Feed/Pull) function (NCI 902) fmt F 18 stck_appr_fr$ #Used with Lathe Stock Advance (Bar-Feed/Pull) function (NCI 902) #Flags stck_op$ : 0 #Stock advance operation method (902) #(0=Push stock,1=Push stock with Use Tool Stop option,2=Pull stock) stck_spindle$ : 0 #Active spindle with stock to transfer (900-902) #0=Left Spindle,1=Right Spindle clmp_op$ : 0 #The selected Operation mode: 0=Clamp,1=Un-clamp,2=Re-position (903) clmp_spindle$ : 0 #Active spindle for clamp/unclamp 0=Left Spindle,1=Right Spindle (903) tlstck_on$ : 0 #Retract or engage the tailstock (0=Retract,1=Engage) (904) toolend_flg : 1 #Flag to execute ptoolend sequence or not # -------------------------------------------------------------------------- #Postblock Section -comments only! # -------------------------------------------------------------------------- pstck_trans$ #NCI code = 900 available variables: #stck_spindle, stck_init_z, stck_final_z, #stck_chuk_st_z, stck_chuk_st_x, #stck_chuk_end_z, stck_chuk_end_x, #stck_chuk_st_dz, stck_chuk_st_dx, #stck_chuk_end_dz, stck_chuk_end_dx if toolchng <> two, ptoolend$ toolend_flg = zero #Do not execute ptoolend again after xfer [ !spaces$ spaces$ = zero pbld, n$, "M00",e$ if prv_spaces$ > 0, " ",e$ if stck_spindle$ = 0, "(Xfer Part from Left Spindle)", e$ if stck_spindle$ = 1, "(Xfer Part from Right Spindle)", e$ spaces$ = prv_spaces$ ] pstck_flip$ #NCI code = 901 available variables: #stck_spindle, stck_init_z, stck_final_z, #stck_chuk_st_z, stck_chuk_st_x, #stck_chuk_end_z, stck_chuk_end_x if toolchng <> two, ptoolend$ toolend_flg = zero #Do not execute ptoolend again after xfer [ !spaces$ spaces$ = zero pbld, n$, "M00",e$ if prv_spaces$ > 0, " ",e$ "(Flip Stock)", e$ spaces$ = prv_spaces$ ] pstck_bar_fd$ #NCI code = 902 available variables: #stck_spindle, stck_op, stck_clear, #stck_grip, stck_init_z, stck_final_z, #stck_chuk_st_z, stck_chuk_st_x, #stck_chuk_end_z, stck_chuk_end_x, #stck_adv_fr, stck_appr_fr if stck_op$ <> 1, # if NOT using the 'Tool Stop option' [ if toolchng <> two, ptoolend$ toolend_flg = zero #Do not execute ptoolend again after xfer ] else, toolend_flg = one #DO execute ptoolend after xfer [ !spaces$ spaces$ = zero pbld, n$, "M00",e$ if prv_spaces$ > 0, " ",e$ if stck_op$ = 0, "(Push stock -",e$ if stck_op$ = 1, "(Push stock with Use Tool Stop option -",e$ if stck_op$ = 2, "(Pull stock -",e$ if stck_spindle$ = 0, " from Left Spindle)", e$ if stck_spindle$ = 1, " from Right Spindle)", e$ spaces$ = prv_spaces$ ] pchuck$ #NCI code = 903 available variables: #clmp_spindle, clmp_op, stck_chuk_st_z, #stck_chuk_st_x, stck_chuk_end_z, stck_chuk_end_x if clmp_op$ = two, [ if toolchng <> two, ptoolend$ toolend_flg = zero #Do not execute ptoolend again after xfer ] [ !spaces$ spaces$ = zero pbld, n$, "M00",e$ if prv_spaces$ > 0, " ",e$ if clmp_op$ = 0, "(Clamp -",e$ if clmp_op$ = 1, "(Un-clamp -",e$ if clmp_op$ = 2, "(Re-position -",e$ if clmp_spindle$ = 0, " Left Spindle)", e$ if clmp_spindle$ = 1, " Right Spindle)", e$ spaces$ = prv_spaces$ ] if clmp_op$ >= one, pchuck_unclamp if clmp_op$ = two, pbld, n$, *stck_chuk_end_z$, e$ if clmp_op$ = zero | clmp_op$ = two, pchuck_clamp pchuck_clamp #user-defined postblock for chuck clamp if clmp_spindle$ = zero, "M10", e$ if clmp_spindle$ = one, "M210", e$ pchuck_unclamp #user-defined postblock for chuck unclamp if clmp_spindle$ = zero, "M11", e$ if clmp_spindle$ = one, "M211", e$ ptailstock$ #NCI code = 904 available variables: #tlstck_on, stck_init_z, stck_final_z if toolchng <> two, ptoolend$ toolend_flg = zero #Do not execute ptoolend again after xfer [ !spaces$ spaces$ = zero pbld, n$, "M00",e$ if prv_spaces$ > 0, " ",e$ if tlstck_on$ = 0, pbld, "(Retract Tailstock)", e$ if tlstck_on$ = 1, pbld, "(Engage Tailstock)", e$ spaces$ = prv_spaces$ ] psteadyrest$ #NCI code = 905 available variables: #stck_init_z, stck_final_z if toolchng <> two, ptoolend$ toolend_flg = zero #Do not execute ptoolend again after xfer [ !spaces$ spaces$ = zero pbld, n$, "M00",e$ if prv_spaces$ > 0, " ",e$ "(Position Steadyrest)", e$ spaces$ = prv_spaces$ ] # -------------------------------------------------------------------------- # Threading output # -------------------------------------------------------------------------- pthread0$ #Pre-thread calculations # Calculate taper delta 'X' on Acceleration Clearance distance thdrdlt = (((thdx2$ - thdx3$) / (thdz1$ - thdz2$)) * thdzclr$) # Add to the original thread 'X' difference calculation thdrdlt = (thdrdlt + (thdx2$ - thdx3$)) * pl_ax_m0x thdang = rad2deg$ * thdangle$ thd_dirx = (thdx2$ - thdx3$) * pl_ax_m0x thd_dirz = (thdz1$ - thdz2$) * pl_ax_m0z thd_vlen = thdlead$/ nstarts$ thd_dirx = vsa (thd_vlen, thd_dirx) if fr_pos$, pthreadpull else, thdpull = zero pthreadpull #Pre-thread calculations if thdpulloff$/(fr_pos$*10) > 0.99,thdpull = 99 else, thdpull = (thdpulloff$/(fr_pos$*10))*100 pthdext$ #Calculation override for external thread #thddepth = thdlead * .61343 #Calc. thread depth #thdflat = thdlead * .1667 #Calc. thread flat pthdint$ #Calculation override for internal thread #thddepth = thdlead * .54127 #Calc. thread depth #thdflat = thdlead * .125 #Calc. thread flat pthdface$ #Calculation override for face thread #thddepth = thdlead * .61343 #Calc. thread depth #thdflat = thdlead * .1667 #Calc. thread flat pthrg32_1$ #G32 threading first comment$ gcode$ = zero lrapid$ pthrg32_2$ #G32 threading second gcode$ = zero lrapid$ pthrg32_3$ #G32 threading third copy_x = vequ(x$) pcom_moveb #------------------------------------------------------------------- #andre la ligne qui suit output la ligne de code pour thread G33 #------------------------------------------------------------------- pcan1, pbld, n$, sgfeed, *sthdgcode, pxout, pyout, pzout, pcout,pffr , strcantext, e$ pcom_movea prv_gcode$ = m_one pthrg32_4$ #G32 threading fourth gcode$ = zero lrapid$ pthrg92_1$ #G92 threading if thdpass$ = one, pthrg92_11 pthrg92_11 #G92 threading comment$ gcode$ = zero lrapid$ prv_feed = m_one prv_zabs = c9k prv_thdtype$ = m_one pthrg92_2$ #G92 threading pthrg92_3$ #G92 threading copy_x = vequ (x$) pcom_moveb pcan1, pbld, n$, sgfeed, sthdgcode, pfxout, pyout, pzout, pcout, [if thdrdlt & thdpass$ = one, *thdrdlt], pfr, strcantext, e$ pcom_movea prv_gcode$ = m_one pthrg92_4$ #G92 threading pg32e$ #G32/G92 threading end gcode$ = zero lrapid$ pthrg76_1$ #G76 threading start point gcode$ = zero lrapid$ pg76$ #G76 threading comment$ gcode$ = zero lrapid$ sav_xa = vequ(copy_x) if thdface$ = zero, copy_x = thdx2$ else, copy_z = thdx2$ if thdface$ = zero, copy_z = thdz2$ else, copy_x = thdz2$ pcom_moveb nstart_cnt = zero while nstart_cnt < nstarts$, pg76nstart pcom_movea prv_gcode$ = -1 copy_x = vequ(sav_xa) copy_x = copy_x + (thd_dirx * (nstarts$ - one)) copy_z = copy_z + (thd_dirz * (nstarts$ - one)) pcom_moveb pe_inc_calc !gcode$, !xabs, !yabs, !zabs, !xinc, !yinc, !zinc pg76nstart #G76 threading, for multiple starts if old_new_sw = zero, pg76old else, pg76new nstart_cnt = nstart_cnt + one if nstarts$ <> one & nstart_cnt <> nstarts$, pbld, n$, *sgcode, thd_dirx, thd_dirz, e$ pg76old #G76 threading old style ce que turbocnc4 utilise #andre4 enleve ce qui est entre parentheses ( *thdrdlt) apres pfzout pour eliminer I0. pbld, n$, *sthdgcode, pfxout, pfzout, *thddepth$, *thdfirst$, *thdang, pffr, e$ pg76new #G76 threading new style pbld, n$, *sthdgcode, *nspring$, *thdpull, *thdang, *thdlast$, *thdfinish$, e$ pbld, n$, *sthdgcode, pfxout, pfzout, *thddepth$, *thdfirst$, *thdrdlt, pffr, e$
__________________ Andy |
| Try changing strf to strk result = nwadrs(strf, feed) This is telling is what string to output for the feedrate strf string F strk string K Mike Mattera
__________________ Tips For Manufacturing Training CD's, DVD's for Mastercam, SolidWorks, Inventor, G-Code Training & More http://www.tipsforcadcam.com |
| thanks for the help.it already had been tried..it would then screw up the feed letter of a linear move .would be K instead of F. I finally figured it out..I copied under an other name the section of code that G33 jumps to and i used strk in place of strf..now the change only affects the feed letter on a G33 ..Thanks to eveybody for the answers..
| help for mastercam post modification | zafarsalam | Post Processor Files | 10 | 06-05-2008 11:52 PM |
| MasterCam 9.0 Post Modification | tbar2485 | Post Processors for MC | 1 | 02-02-2008 08:23 PM |
| Version 9 post modification | tbar2485 | Post Processors for MC | 3 | 01-08-2008 09:28 PM |
| New MCG's need modification | Swede | Servo Motors and Drives | 3 | 01-12-2005 08:46 AM |
