Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > Mastercam > Post Processors for MC
Old 01-04-2008, 01:03 PM
tbar2485 is on a distinguished road
MasterCam 9.0 Post Modification
We have a new machine with a Fanuc 18i-MB control. I'm looking for some help in modifying my MasterCam post to enable/disable the AI_NANO feature from operation to operation in the MC9 file. I've been using the base MPFAN post with some of my own modifcations with 100% success so far, but this seems to be a little over my head. Maybe some help getting me pointed in the right direction will help.
To activate the feature: G5.1Q1R10
To deactivate: G5.1Q0
R is a "precision" variable (1 - 10)
The machine code needs G49 to cancel the length offsets before activating the feature. I figured it would be easiest to just send the machine home (G91G28Z0), then X & Y position, activate with the G5.1Q1R(?), and then turn on length comp.
I assume that using the Misc. Integers to activate/deactivate and the Real Numbers for the "R" variable.
Any help would be appreciated.
Thanks, Tom
Old 02-02-2008, 08:23 PM
gplush is on a distinguished road
Are you still using 9? I don't have that installed, but changing that shouldn't be hard. Send me two examples of code, and I should be able to figure it out.
help for mastercam post modification zafarsalam Post Processor Files 10 06-05-2008 11:52 PM
Y Axis modification Mike F Syil Products 6 11-12-2007 04:23 PM
Modification to closed VXB bearing phantomcow2 Linear and Rotary Motion 0 04-08-2006 06:30 AM
New MCG's need modification Swede Servo Motors and Drives 3 01-12-2005 08:46 AM
Lathe Modification links CNCadmin Mini Lathe 0 10-14-2003 03:29 PM
