Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > Mastercam > Post Processors for MC
Old 01-01-2008, 06:57 AM
brandou10l's Avatar
brandou10l is on a distinguished road
rotary code at tool change
how can i get a rotary output at every tool change?
it will put it out if the index is diffrent
i want to to put it out even if the index is the same
i tried to fool with the post but only got it to put out an index after every line
i want this to keep operators from starting on the wrong side of the pallet
using the generic fanuc 4x mill
Old 01-04-2008, 01:57 PM
Mike Mattera's Avatar
Gold Member
Mike Mattera is on a distinguished road
Really depends on how the post is outputting the rotary.
You probably want to output it in the ptlchg section of the post, after the tool is called ( pbld, n, *t, "M06", e). Somewhere after that you should add a line to force the rotary pbld, n, *cabs, e (or what ever variable is calling the rotary output.
Of course you didn't say it it's V8, V9, or X. so this format will vary slightly.
Mike Mattera
Tips For Manufacturing Training CD's, DVD's for Mastercam, SolidWorks, Inventor, G-Code Training & More
http://www.tipsforcadcam.com
Old 01-05-2008, 06:33 AM
brandou10l's Avatar
i am using version x
it was the "pindex" variable
thanks mike
Very slow tool change on Tool Room Mill Capt Crunch Haas Mills 3 12-21-2007 12:20 PM
G or M code for tool change bradyfb DeskCNC Controller Board 14 12-19-2007 08:27 PM
G Code Change gm3211 Haas Mills 4 09-20-2007 07:02 PM
How to change Tool change position(About MAZATROL T1 control) liushuixingyun Mazak, Mitsubishi, Mazatrol 5 07-07-2007 02:58 PM
Rotary tool MrRage Polls 9 10-15-2005 02:29 PM
