I figured out the 164 line to make my post a 3 axis post. Now for the life of me I cannot figure out how to get the X0. out of the second to the last line. This is what I get out of my post: M5 G91 G28 Z0. M9 G28 X0. Y0. M30 % I just manually change it now, but the more that I learn the more I want to know, and this should have been able to be figured out by me, but I can't. Now I ask for your help, please. Thanks |
| Looks like that might be in the peof function in the post. Make sure you use this peof... Code: peof #End of file for non-zero tool Code: peof
__________________ Matt San Diego, Ca ___ o o o_ [l_,[_____], l---L - □lllllll□- ( )_) ( )_)--)_) (Note: The opinions expressed in this post are my own and are not necessarily those of CNCzone and its management) |
| Thank you Rekd. As for everyone on every post that says "check with your dealer", why don't you just ask the admins to get rid of this forum, because every question that is asked on here could be solved by the dealer. I don't get it, I looked at every post on here about haas machines and I couldn't believe how many times I read "check with your dealer" jeesh!! |
| Don't worry, you're not alone. When you get assigned to 'one dealer' who assigns 'one rep' for your area, you're at the mercy of that person. CNC Software refuses to help when the VAR can't answer the questions. For the money they charge for this software, the support should be better than it is. I shouldn't have to customize my own post for a three-freakin-axis-Haas. I'm still debugging mine. POS.
__________________ Greg |
| employees, at the eMastercam.com forum. I don't think there's been a situation yet that hasn't been resolved.
Aside from the fact that you should have told your rep that you wanted a working post (to your specs) with the purchase of Mastercam, the support you get with Mastercam is the best I've seen in over a half a dozen major CAM brands I've used, and it's better than ALL the CAD brands I've used put together. You probably run things a little bit differently on your particular HAAS, don't you? Perhaps you think the default format should use G90 instead of G91, or you think the drill cycles should do this or that instead of that or this. Perhaps you think the default tapping cycle should be for rigid tapping instead of floating head, etc etc etc. If you are indeed like the tens of thousands of other people that run things just a little bit different on their machine, aren't you glad you can adjust your post? I sure am! And aren't you glad you can get ALL THE SUPPORT YOU NEED to make minor adjustments for free, instead of having to pay a post developer to do the small stuff? My HAAS posts do amazing things. Lots of custom canned cycles for deep hole drilling, engraving, (serial and text), drop stops, etc etc etc. They put out excellent code for the machines and for setup sheets and other things. They're pretty much unlimited from what I've seen so far. They've got their own open source computer language to run their posts and you think they're a POS because they give you complete access to it? Indeed! As for "Ask your dealer", that should only happen when people ask for a post. Not when they ask for help on tweaking theirs. It's usually not the forum mod's saying that. Like in this case, where a kid with 5 posts comes in and says it. What happens is that a lot of people pirate Mastercam and want to get a post, so they come here and ask for one. "Ask your dealer" is a way of weeding out some of the pirates.
| I started with MC 9. I was pretty much left on my own (by the VAR) but I'm a smart, resourceful guy and I quickly figured it all out. It came with a Haas post and it worked out of the box. Once I understood that I could edit the post, I did indeed do the 'little tweaks'. When the boxes arrived in the mail for the transition to X, I was given a transition program that was supposed to save and move all of my settings. That's great until you have to reformat a hard drive and need to know where all of those settings went. And...it didn't work...or at least I could never determine which files it altered and what they were named. In any case, I kept getting told (by the VAR) that I should just use the 'Generic Fanuc' post..."it'll work just fine" was their battle cry. I'm not making money with this machine (it's a hobby right now) but I did indeed pay very real money for MasterCam and the Haas. I was running just fine under MC9 until I decided that I 'had to' move into X. That stopped me dead in my tracks. The machine didn't make another chip until this past Sunday night. I was (and still am) frustrated with the disorganized, nested dialog, multiple file nature of 'control defs, machine defs, tool libraries, etc'. I still don't understand if the Machine definition uses a Control definition or if they always remain separate and must be selected each time. Ditto for the post. In my simple, little brain I should be able to:
No, I didn't use a pirated version of the software. I paid full admission to be part of the club and got little more support than if I HAD been a pirate. I got rolled eyes and little help from most of the people at the Mastercam booth (again...thinking I'm using pirated software for sure). That was until I found the guy from my VAR standing on the other side of the booth. They finally took the time to give me all of the 'supposed' post and machine defs to take home on my thumbdrive. AND THOSE didn't work either. Anyway, I'm sympathetic to the company for both the situation of pirated software AND incompetent people out in the field. But I did call them back east (for POST help) and got shrugged off to the VAR. If customizing the post is a necessary part of owning the software, then they should have included a thorough manual (either PDF or hardcopy) so I could do it.
| You might try MPMaster.pst. It does much better out of the box on a HAAS than the HAAS or fanuc posts. But trying to blame CNC Software for making a safe, generic post is pretty lame at best.
If you're still having trouble with posts, definitions etc, you should ask for help here or go to eMastercam.com's forum for help. Hint, you'll get more with sugar than you will with vinegar at either. And no, I don't work for CNC Software, I just get tired of people bagging on them for reasons that are simply not true or accurate, or due to bad judgment on the user's part.
| Donkey Hotey, I see were you are from . what show are you speaking of? this was not the last Westec show I take it. if so I would of been your Rep. And I know I can still help. Send me an PM and I will make sure you get what you need. Jay (cadcam)
__________________ (Note: The opinions expressed in this post are my own and are not necessarily those of CNCzone and its management) Cadcam Mastercam Instructor , Programming Consultant and ME (Manufacturing Eng) |
#10
![]() I wasn't 'blaming' CNC software. I think they have room for improvement. Maybe they don't know how their product is perceived. I'd be a fool to believe that the involved parties will never see these posts: it's a small world. I was not a happy customer. I was impressed by 9. I was not impressed by X. ![]() One time I made a phone call and got an answer. A few other times I called and got completely wrong answers (work offsets). Look through my post history here. I'm a helpful guy. You really have no idea how upset I was when this was all going on. Really. This is the constructive version of events. Offline, I'd tell you what I really think. I know the level of support I got from Solidworks. I know what I get when I call Haas. I know what I got when I called the VAR and Mastercam about their product. It wasn't the same level of support--not even close--despite being the most expensive piece of software, by far. I hope to finally get it going and maybe I'll be so impressed by the software that I'll forget all the transition problems. We'll see.
#11
OIC. I didn't know that. They should have suggested MPMaster, I think they ported an X version of that post.
You will have to change the way you think about programming, but I'm sure it will be worth it in the long run.
#12
| Do you mind telling us what is your current version of X. I have X2MR2 with the last 2 updates installed. There is a HAAS post, Machine Definition and Control Definition for the HAAS as of X MR2 which was almost 2 years ago. Seeing how we have the same VAR I would have to strongly disagree with your comments about them and wonder if you called ranting verse calling to talk to someone?? I am sure you handle your customers who call you ranting all the time the same as the one who call you telling you about the good job you are doing. ![]() I can tell you I don't and do everything in my power to get them off the phone as soon as possible. Like MR Funk In Rekd said hope over to here:http://www.emastercam.com/cgi-bin/ultimatebb.cgiThe only thing you may need is your sim# not a big deal. I have been know to go over there a time or two and answer some questions and I have got plenty of questions answered over the years over there myself. The issues you are having would take anyone with a little bit of post experience about 15 to 20 minutes to button up. My post for one machine does probing, put in customer data, Rev numbers, Machine it is posted for who the programmer was that programmed it and has tons of custom drill cycles like was stated above and never touched by a dealer to do it and my programming experience is limited to Machine tools!!! Need some help you can keep asking over here, but I promise you a $100 that over in emastercam forum and you got some manners they will get answered a lot faster. Go over there and try to rip Mastercam and the dealer a New one and I promise you will not like what you get back in return. That is a friendly piece of advice please take it. I make my living off of Mastercam and I do very well with it so sorry if I got very little sympathy for what you are going through. |
| Haas OL-1 desktop lathe for small parts ? | Metalmog | Haas Mills | 9 | 11-23-2008 01:19 AM |
| Help with post change | proform | Post Processors for MC | 2 | 11-06-2006 09:16 AM |
| CAT40/Haas Quick change lathe adapters | archer66 | Haas Mills | 2 | 09-06-2006 03:23 PM |
