Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > Mastercam > Post Processors for MC
Old 05-29-2007, 05:40 AM
gearsoup is on a distinguished road
Minor changes to Generic Fanuc Posts....
So, I've been able to change a good deal of the post processor to suit my shops preferences. A couple things I'm stuck on:
It outputs a G17 in the first line, and a G20 in the second line. Since the CNC we have defaults to that anyway, can I remove these from the post sequence? If so, how?
And at the end of the program, my partner wants to see:
M5
G91G30Z0.M9
G28Y0.
M30
It's currently giving me a G30 Z0 on the first line, but the next line is G30 Y0....
Also, is there a way to have N numbers ONLY on the toolchange? My partner has worked a certain way for a LONG time. He is used to seeing:
N10 T1 M6
N20 T2 M6
N30 T3 M6
so on and so forth......
Thanks,
Seth
Old 05-29-2007, 10:56 AM
Lars is on a distinguished road
I am not a post genius, but if you look in "psof" there should be a line that sayes"pbld, n, *smetric, e" that is your G20.
And in the following line that should be a "*sgplane" that is your G17.
HTH
Lars
Old 06-01-2007, 10:32 AM
Mike Mattera's Avatar
Gold Member
Mike Mattera is on a distinguished road
If it doesn't matter, why do you want to bother with it? What if someday you want to run a program metric? Now you'll have to put it back in. If it works leave it alone.
Lets say you want to start a program where the first cut is in the XZ plane. Now you'll have a problem again. Those codes are there for a reason.
Mike Mattera
Tips For Manufacturing Training CD's, DVD's for Mastercam, SolidWorks, Inventor, G-Code Training & More
http://www.tipsforcadcam.com
Wiring Diagram for Generic Breakout board, home and Limit Switches, Generic Drives. CJL5585 Open Source CNC Machine Designs 33 02-24-2010 03:39 PM
minor cookie problem BullCreek Forum Questions or Problems 0 05-05-2007 11:41 AM
rolled ballscrew minor diameter? ged Linear and Rotary Motion 2 12-03-2006 01:48 PM
BobCAD posts vs. Mastercam posts justCNCit BobCad-Cam 124 08-16-2006 02:17 PM
Tri-power minor problem bherr Shopmaster/Shoptask 0 05-19-2006 07:21 AM
