Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > Mastercam > Post Processors for MC
Old 03-08-2007, 11:03 AM
jymdman is on a distinguished road
Inverting values.
Hi
I need to edit the standrad MPFAN postprocessor for MC 9 to invert the values of X and Y
For example: postprocessor outputs X125.0 and I wan't to have X-125.0
I think I need this for I and J also.
Is this doable??
I'm having a Fanuc 21i system.
/Fredrik
Old 03-08-2007, 02:52 PM
tobyaxis's Avatar
Moderator
tobyaxis is on a distinguished road
Originally Posted by jymdman View Post
Hi
Is this doable??
/Fredrik
You could spend a few bucks and get this www.ncplot.com
Toby D.
"Imagination and Memory are but one thing, but for divers considerations have divers names"
Schwarzwald
www.refractotech.com
Old 03-08-2007, 02:56 PM
Rekd's Avatar
Rekd is on a distinguished road
Hi
Is this doable??
/Fredrik
Are you programming it backwards? Not sure the reasoning here.
Matt
San Diego, Ca
___ o o o_
[l_,[_____],
l---L - □lllllll□-
( )_) ( )_)--)_)
Old 03-08-2007, 03:56 PM
tobyaxis's Avatar
Moderator
Maybe he is doing a Mirror Image for Left/Right Hand Parts.
I'm confused too
Toby D.
Schwarzwald
Old 03-08-2007, 04:02 PM
The reason is that the coordinates is reversed in my machine compared to MC.
In MC all values to the right an top of the origin is positive, but in my machine those values are negative...
Or can I work around this with some G-code in my system.
Anyway, I wrote a small C# program to invert the values, but it would be great if I didn't have to do that.
/Fredrik
Old 03-08-2007, 06:50 PM
Matt Berube's Avatar
Power User
Matt Berube is on a distinguished road
Is there a parameter in the control you could switch to have the axis inverted ?
Just thinking out loud here...
Old 03-09-2007, 09:30 AM
Alex_Cole's Avatar
Alex_Cole is on a distinguished road
This can be done you just need to determine if changing it in the post is the best way for you to do it or not. If you do not have a large number of programs already for your machine tool you might be better off changing them in the machine to match the standard right hand rule. If you want to do it in the post processor you can though. I have done it several times and it seems to work great.
I am not going to tell you exactly how because I do not know your post, but to reverse the sign of a variable you use the logic below.
xabs is my variable for this example.
xabs = xabs * -1
This will take the value of xabs and change it from positive to negative or from negitive to positive. This is the easy part. The hard part is making sure you have this in the right location of your post. Where you need to put it will vary based on if your post supports rotary logic or not. Typically this is done where the XYZ and IJK matrix is mapped to the current plane.
I strongly sudgest you take this information to your Mastercam dealer and request this change. They should be able to make this change for you.
Thanks and I hope this helps
PS You have a PM
AC
Old 03-09-2007, 09:39 AM
ImanCarrot's Avatar
ImanCarrot is on a distinguished road
Change the GCode filename extension to .TXT and open the file using Word for Windows as a text document.
Click the Edit Tab and then Replace.
Stick X in the replace bit and X- in the Replace With bit.
Do the same with Y.
Watch out for any X0 and Y0 values.. you'll need to change these manual cos the Replace will change these to X-0 which might mess up your program.
Save the file then rename it with the appropriate filename extension.
Hope this helps!
I love deadlines- I like the whooshing sound they make as they fly by.
Old 03-09-2007, 10:00 AM
Mike Mattera's Avatar
Gold Member
Mike Mattera is on a distinguished road
theres a variable for changing that. If you search in the post (dia_mult) you'll find .....
dia_mult : 2 #Multiplier for output on X axis (Neg. switches sign of X)
y_mult : 1 #Multiplier for output on Y axis (Neg. switches sign of Y)
z_mult : 1 #Multiplier for output on Z axis (Neg. switches sign of Z)
dia_mult is what changes the output for Radius ot Dia.
Every X value runs thru it before getting output. Changing it to -2 will invert the value and make the output 2 times the radius.
Mike Mattera
Tips For Manufacturing Training CD's, DVD's for Mastercam, SolidWorks, Inventor, G-Code Training & More
http://www.tipsforcadcam.com
Old 03-09-2007, 10:12 AM
post_guy is on a distinguished road
The default MPFAN in V9 contained some limited logic for this. To do it properly, open the .pst file and find the following section:
Code:
pxyzcout        #Map coordinates
      if rot_on_x,
        if cuttype = zero, pxyzcout0    #Toolplane Positioning
        if cuttype = one, pxyzcout1     #Axis Substitution
        if cuttype = two, pxyzcout2     #Polar Conversion
        if cuttype = three, pxyzcout3   #Simulatneous 4 axis (Multi-axis)
        if rot_ccw_pos = one, csav = -csav
        if mr_rt_actv <> two,
          pcoutrev
          if index, pindxcalc
          pfcalc
        else, feed = fr_pos
      else,
        xabs = vequ (x)
        feed = fr_pos
      #Check flags and change orientation         # - eap 1/17/03
      if xflip = yes, xabs = xabs * -1            # - eap 1/17/03
      if yflip = yes, yabs = yabs * -1            # - eap 1/17/03
      if zflip = yes, zabs = zabs * -1            # - eap 1/17/03
The xflip and yflip and zflip variables are the ones you are really interested in. The logic needs to be modified to work properly. Change it to:
Code:
      if xflip = yes,
        xabs = xabs * -1
        i = i * -1
      if yflip = yes,
        yabs = yabs * -1
        j = j * -1
      if zflip = yes,
        zabs = zabs * -1
        k = k * -1
Now find the variable initializations in the post:
Code:
xflip       : no    #Reverse X axis orientation                - eap 1/17/03
yflip       : no    #Reverse Y axis orientation                - eap 1/17/03
zflip       : no    #Reverse Z axis orientation                - eap 1/17/03
and change them to:
Code:
xflip       : yes   #Reverse X axis orientation                - eap 1/17/03
yflip       : yes   #Reverse Y axis orientation                - eap 1/17/03
Old 03-10-2007, 01:28 AM
Gold Member
Why did I think he was asking abouy a lathe post ?
Mike Mattera
Old 03-10-2007, 01:35 AM
Gold Member
Good Point Post_Guy. The I J K arc values also have to be flipped for the circles to come out right. It seems that code was missing from the original MPFAN.
Mike Mattera
Torque values cncshaper Stepper Motors and Drives 2 11-23-2007 12:17 AM
Inverting a 220 to 110 v transformer elogicca General Electronics Discussion 4 01-20-2007 11:55 AM
K Values And Bend Radii lostbaka Bending, Forging,Extrusion... 1 12-04-2006 07:29 AM
List of L values for G10 L?? iMisspell G-Code Programing 3 07-30-2006 11:32 PM
Output values?? hop Machine Problems, Solutions , Wireless DNC, serial port 0 06-07-2006 06:37 AM
