Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > Mastercam > Post Processors for MC
Old 02-06-2007, 08:32 AM
m_marenghi is on a distinguished road
MasterCAM Post - CNT Router w/ WinCNC Controller Help!!
I have a newer CNT Router that runs a WinCNC controller. I have an existing post that allows me to run MasterCam X but in some surface machining functions I'm getting large circles and arcs when I open it up on the controller and try to run it. It is fine when I verify it MasterCam prior posting. Does anyone have any suggeastions? Is there anyone that could help me fix this problem? I will pay for someones time.
Old 03-14-2007, 09:45 AM
perpetualdark is on a distinguished road
Cool Check your "D" offsets.
Some post confuse "D" dia offset with The "H" height offset. If you have the "D" offsets turned on at the machine, and it has the same offset number as you height offset, the machine will try to compensate for the larger offset and make big arcs. To fix this problem, you can simply turn off the "D" compensation at the machine in you software, or edit your post. Open the post and look for a line of "Ds" with numbers beside it. Change these numbers to start with the fist number after the last tool that you have in your changer. ex, if the last tool is 10, then the first "D" offset should be 11. make sure that the offset banks in the controller for the new "D" offsets are all set to 0.000 or to the number you wish to compensate for, ex, -0.0010
I hope that this helps.
Perpetualdark
Old 05-20-2009, 09:19 AM
igorski is on a distinguished road
Hi. I have cnc router that runs on wincnc, i'm trying to find postprocessor for mastercam X3. Can you send it to me?
Thanks in advance.
Old 06-08-2009, 02:57 PM
mwestvang is on a distinguished road
mastercam 9 post for wincnc router
Does anyone have a post for MC 9 to wincnc?
Thanks,
Mike
Mike Westvang
Dryad Bows Inc.
mastercam post for practical cnc/wincnc teacher Post Processors for MC 5 08-03-2008 10:40 PM
Post needed for WinCNC behn WinCnc 4 02-19-2008 03:26 PM
mastercam post for parker 6K series controller? novacustard Post Processor Files 1 02-03-2007 12:13 AM
Surfcam to WinCNC controller post needed behn Post Processor Files 0 10-19-2006 11:31 AM
BobCad with WinCNC controller 2.1 Scott V BobCad-Cam 9 01-17-2006 02:23 PM
