| Mastercam to Galil Post processor needed I am searching for a post processor to use Mastercam with my Galil DMC-1750 controller. I am converting a Bridgeport Mill to CNC and only need 3 axis control. Any ideas? |
| put together a sample program that cuts lines and arcs using a contour toolpath. Then program all of the drilling/tapping cycles you wish to be supported. Post out this program using Generic_Fanuc_4_axis in X or MPfan.pst in 9. With the generated Gcode put notes to the right of the code that describes the changes that need to be made for the code to run correctly on your machine. You may also want to include a complete G and M code list for your machine. Send the MCX or MC9 file along with the post you used to your Mastercam dealer or post it here as someone else may be able to help but whoever works on it is going to need this info. Hope this helps. AC |
I see Mach now supports Galil. This would be an excellent low cost solution. Or if you like top shelf, take a look at Camsoft. Karl |
| If you are using the Mach system then the default MPfan.pst or Generic_4ax_mill should work almost perfect right out of the box. Alex Cole
__________________ AC Has anyone seen my pillow? |
| galil active X toolkit I have a DMC-4040 motion control module with software CD to run this board I would appreciate if somebody would supply a password for the active-x toolkit that is optional when purchasing this Galil module. software cost 800$ but don't want to spend tha t amount of money. I am only using this board for fun and hobby |
| Heidenhain TNC410 Mastercam post processor | Goran P. | Post Processor Files | 24 | 04-13-2011 09:13 PM |
| help to edit mastercam post processor | Moorej91 | Post Processor Files | 17 | 04-06-2010 03:09 PM |
| Post processor info for Mastercam to Mach 3 | 9lrac9 | Post Processor Files | 7 | 08-10-2009 08:08 PM |
| Mastercam VTL post processor. | jrebel | Post Processors for MC | 5 | 12-09-2006 05:24 PM |
| BOSS 5 Post processor for Mastercam | bbuonomo | Post Processor Files | 6 | 09-03-2006 01:11 PM |
