Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > Mastercam > Post Processors for MC
Old 12-21-2006, 04:34 PM
soundqsho is on a distinguished road
Rotary post issued, based on MPFAN
I'm trying to get a rotary axis to behave properly using an OLD cnc controller that does not use conventional code handling. I'm getting close using the MPFAN.PST, but still have one problem to overcome.
The controller expects to see the A axis value as absolute, and the + or - value is used as direction control.
This means that when I post a file, and all of the rotary values are positive absolute, then the rotary axis will only rotate clockwise. (so moving from A2.0 to A1.0 would involve a 359 degree move in the wrong direction, but moving from A1.0 to A2.0 works just like it should).
I'm no post genious, but I'm trying to figure out how to get the value exported in the way I need it.
Old 02-24-2007, 11:26 AM
Alex_Cole's Avatar
Alex_Cole is on a distinguished road
Try building your post from the fadal format 1 or format two posts. I realize that the fadal post will need more general format changes to get the rest of the code to match what you need but the rotary should already be setup to work in the way you are describing.
Hope this helps
AC
Old 02-26-2007, 12:59 PM
Mike Mattera's Avatar
Gold Member
Mike Mattera is on a distinguished road
Or you could isolate the section of code from the Fadal post that does the +/- direction and insert it into your post .
Mike Mattera
Tips For Manufacturing Training CD's, DVD's for Mastercam, SolidWorks, Inventor, G-Code Training & More
http://www.tipsforcadcam.com
