Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > Mastercam > Post Processors for MC
Old 12-19-2006, 04:19 PM
rond16148 is on a distinguished road
Mastercam X - debugging
I need help turning on the debugging for MasterCam X. I have turned on at the control definition and set fastmode to debug but still no information in the nc file ?
Old 12-20-2006, 06:39 PM
Alex_Cole's Avatar
Alex_Cole is on a distinguished road
Set bug2 to a value of 35 or 40. This is the column position of where you want the debugging params output. If it has a value then this is not your issue.
Example
bug2 : 0 --Before
bug2 : 35 --After
HTH
AC
Old 01-28-2007, 11:46 AM
ObrienDave's Avatar
ObrienDave is on a distinguished road
My experience with X is the fastmode switch does not work anymore.
I could be wrong.
You need to do both the control definition and change the bug2 value.
Making the bug2 value a negative number outputs ALL postblocks called.
Name:	Control Definition.jpg‎
ObrienDave. MasterCam since V6. Gcode since 1983.
Be careful, the nose you punch today may belong to the butt you have to kiss tomorrow.
