| changing values to non modal I have one control in the shop where feedrates have to be put back in after a rapid move, and also need the I and J moves on arcs to be in every line even if they dont change from line to line, even when its a zero it needs it on each line. I am using 9.1...........thanks |
| in this portion of your post.. do you have the pfr in there? I believe thats what kicks out the feedrate plinout #Output to NC of linear movement - feed pbld, n, sgplane, sgcode, pwcs, pccdia, pxout, pyout, pzout, pfr, pcout, pcan1, e pcirout #Output to NC of circular interpolation pbld, n, sgplane, sgcode, pwcs, pccdia, pxout, pyout, pzout, pcout, parc, pfr, pcan1, e as far as your I and J's would it help if you added the parc in the plinout part of your post? plinout #Output to NC of linear movement - feed pbld, n, sgplane, sgcode, pwcs, pccdia, pxout, pyout, pzout, parc, pfr, pcout, pcan1, e |
| not yet I tried that didnt seem to work, should I copy exactly what u wrote , I just added those 2 things and now I have errors on line 774, I am using the fanuc post it works fine on all are other machines, I would like it to work on this control too, I also need the g2 ang g3 to repeat everytime they are needed, even on the next line ...........thanks for helping |
| No. I was hoping just adding that in your existing lines would have kicked the same results I got. It kicked out the I, and J's on every line for me, and the pfr was what gave me the feedrates. Sorry, wasnt trying to guide you in the wrong direction. |
| Adding an asterisk * to the beginning of a variable name, such as *pfr, forces the output to the NC file every time.
__________________ ObrienDave. MasterCam since V6. Gcode since 1983. Be careful, the nose you punch today may belong to the butt you have to kiss tomorrow. Last edited by ObrienDave; 12-03-2006 at 03:23 PM. |
| MMUR, Try this arcoutput : 0 #0 = IJK, 1 = R no sign, 2 = R signed neg. over 180 parc #Select the arc output format if arcoutput = zero | full_arc_flg | arc_pitch, [ #Arc output for IJK # If you do NOT want to force out the I,J,K values, # remove the "*" asterisks on the *i, *j, *k 's below... if plane = zero, *i, *j, k #XY plane code - G17 if plane = one , i, *j, *k #YZ plane code - G19 if plane = two , *i, j, *k #XZ plane code - G18 ] else, [ #Arc output for R if abs(sweep) <= 180 | arcoutput=one, result = nwadrs(srad, arcrad) else, result = nwadrs(srminus, arcrad) *arcrad
__________________ www.cad2cam.net Programmer/ Certified Cam Instructor |
