Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > Mastercam > Post Processors for MC
Old 01-14-2004, 04:03 PM
Nimrod is on a distinguished road
Fadal post
Anyone know how I can get my Fadal post to put out a G84.2 pryer to my G84.1 so it would read like so:
G84.2
H18Z10.M8
G84.1G98Z-9.4R05.S286.F357.5
thanks
Nimrod
The Mighty Hunter
Old 01-14-2004, 04:47 PM
Rekd's Avatar
Rekd is on a distinguished road
Re: Fadal post
G84.2
H18Z10.M8
thanks
Nimrod
If you want it on every file on every tool change, you can hard-code it in the ptlchg_com section of your post.
Mine reads like this
Code:
ptlchg_com      #Tool change common blocks
      pcom_moveb
      c_mmlt #Multiple tool subprogram call
      #ptoolcomment
      spaces=0
      spaces=sav_spc
      pcan
      if sav_mi3 = 1, n, "M33", e
      if mi7 <> 0,
      	n, "G91", "G28", "Z0", E
      	n, "G0", "A180.", E
      	n, "A-180.", E
      n, "M01", e
      popnumber
      comment
      if stagetool <= zero, pbld, n, *t, "M06", ptoolcomm, e
      if stagetool >= one,
      		n, "G91", "G28", "Y0", E
      		n, "G90", "G00", "G52", "X-40.", E
      		pbld, n, "M06", ptoolcomm, E
      spaces=0
      if output_z = yes, preadbuf5
      #if output_z = yes & opcode > 0 & opcode < 16, "(", "MAX | ", *max_depth, ")", e
      if output_z = yes & opcode > 0 & opcode < 16, "(", "MAX-DEPTH | ", *min_depth, ")", e
      spaces=sav_spc
      pstock
      pindex
      sav_absinc = absinc
      if wcstype > one, absinc = zero
      if speed <> 0, n, *spindle, *speed, pgear, strcantext, e #used for Part Location Cycle
      pcorner_round
      pcan1, pbld, n, *sgcode, *sgabsinc, pwcs, pfxout, pfyout, *cabs, e
      pbld, n, "G43", *tlngno, pfzout, next_tool, e
      "/", n, scoolant, E
      absinc = sav_absinc
      pcom_movea
      toolchng = zero
      c_msng #Single tool subprogram call
      last_op_id = op_id
      if sav_mi3 = 1, n, "M31", e
Yours is different, but you should be able to find where to place the code. In mine, it's 8 lines from the bottom, above the line that has the "G43" in it.
You'd write something like this..
Code:
     n, "G84.2", e
If you want to have it depend on anything, like tool number, fixture number etc, you'll have to come up with some kind of logic statement to do it.
HTH
'Rekd
BTW, BACK UP YOUR POST before you start making ANY edits. (Been there, done that, go a post so screwed up I had to start over... )
Matt
San Diego, Ca
___ o o o_
[l_,[_____],
l---L - □lllllll□-
( )_) ( )_)--)_)
Old 01-14-2004, 04:50 PM
Rekd's Avatar
Oh, how did you make out with the Access and tool table issues? Did you get it formatted the way it needs to be?
'Rekd
Matt
San Diego, Ca
___ o o o_
[l_,[_____],
l---L - □lllllll□-
( )_) ( )_)--)_)
Post Cimatron to Fadal Dennist Post Processor Files 2 12-27-2011 09:22 PM
Emco Compact 5 PC...have ???? Double G Mini Lathe 42 08-22-2010 07:26 PM
Upgrading control hardware - Emco eDudlik General CNC (Mill and Lathe) Control Software (NC) 21 12-08-2009 01:52 AM
v2xt post jrrhotrod Post Processors for MC 25 12-10-2008 06:20 PM
Cimatron post to fadal Dennist Post Processor Files 1 10-03-2003 10:27 AM
