Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > Mastercam > Post Processors for MC
Old 04-27-2006, 06:06 AM
jaangi is on a distinguished road
Exclamation Mastercam post for Fagor 8055M
I am running Mastercam 9, I downloaded a post from emastercam, but I can't post directly to the machine, I have to go through the Fagor dnc program then upload it to the machine into programs. When I start the program I get get an error message: 0002 Improper data. N114 G43 D1 Z50 if I delete the line from the program it then runs through the rest of the program which at the moment seem to be fine, at the end of the program the machine returns to its home position, but likewise if I delete the line from the program it stops at the end without returning to its home position. Can anyone help me modify my post so that I don't have to do this? Or help me post directly to the machine?
Old 04-27-2006, 07:01 AM
Kiwi is on a distinguished road
jaangi
I don't have MC but do use a Fagor 8055M
I believe your line N114 G43 D1 Z50 should have Z before the D.
eg: N114 G43 Z50 D1
Not sure why your machine returns to home at the end.
Old 04-27-2006, 09:35 AM
Rekd's Avatar
Rekd is on a distinguished road
If you're looking to modify your post, you need to post the code you're getting, the code you want, and we should be able to get the post working for you.
As for getting the file to the machine, there are, as with many aspects of MC, many options to do it. Your best bet might be to call the transfer program from the post after it finishes posting, or call the post from a script then launch the transfer program from the script.
Matt
San Diego, Ca
___ o o o_
[l_,[_____],
l---L - □lllllll□-
( )_) ( )_)--)_)
Old 04-28-2006, 06:45 AM
Thanks. I changed the line so that the Z is before the D and that worked I also have to delete the next line which is G53 and G53 X0 Y0 Z0 at the end of the program to stop the machine returning to its home position. How and what do I need to do to mod my post so that it will work without having to do this?
Old 04-28-2006, 10:10 AM
Rekd's Avatar
Should be in the PEOF function somewhere. Make a backup before you start editing.
HTML Code:
peof            #End of file for non-zero tool
      iseof = 1
      pretract
      iseof = 0
      spaces=0
      comment
      spaces=sav_spc
      #Remove pound character to output first tool with staged tools
      #if stagetool = one, pbld, n, *first_tool, e
      n, "G52", "X-40.", e
      if stagetool <> 0, pbld, n, "M06", e
      #if t <> first_tool, n, first_tool, "M06", e
      if sav_mi3 = 1, n, "M33", e
      n, "M30", e
      mergesub
      clearsub
      mergeaux
      clearaux
      "%", e
Matt
San Diego, Ca
___ o o o_
[l_,[_____],
l---L - □lllllll□-
( )_) ( )_)--)_)
Old 04-30-2006, 07:18 AM
Hi Matt
I tried to edit my post but came with an iseof error, I have probably done something wrong, perhaps if you could take a look at my post below you could advise me?
Mike
Code:
# Post Name           : MASTER_FAGOR
# Product             : MILL
# Machine Name        : MACHINE
# Control Name        : FAGOR 8050/8055 M CNC
# Description         : IHS MASTER GENERIC MILL G-CODE POST
# Associated Post     : NONE
# Mill/Turn           : NO
# 4-axis/Axis subs.   : YES
# 5-axis              : NO
# Subprograms         : YES
# Executable          : MP v9.05
# WARNING: THIS POST IS GENERIC AND IS INTENDED FOR MODIFICATION TO
# THE MACHINE TOOL REQUIREMENTS AND PERSONAL PREFERENCE.
# Revision log:
# Programmers Note:
# IHS 01/30/02  -  Mpmaster based on CNC Software's V8/V9 Mpfan, dat
# IHS 01/30/02  -  Initial post update for V9, dat
# IHS 04/01/02  -  Comments repeated in translational subs, dat
# IHS 05/01/02  -  lock_codes logic tweak, dat
# IHS 05/07/02  -  arccheck set to 3, dat
# IHS 05/17/02  -  Removed null comment from subs, dat
# IHS 05/24/02  -  Rotary subprograms mod, dat
# IHS 07/17/02  -  Incremental drilling calculation mod, dat
# IHS 07/25/02  -  Switch added to control rotary index move retracts, dat
# XXX MM/DD/02  -  Written for Company X from Mpmaster, xxx
# Features:
# This post supports Generic Fagor code output for 3 and 4 axis milling.
# It is designed to support the features of Mastercam Mill V9.
# Following Misc. Integers are used:
# mi2 - Absolute or Incremental positioning at top level
#        0 = absolute
#        1 = incremental
# mi9 - Lock on First WCS - Set in first operation
#        0 = No
#        1 = Yes
# mi10 - M00 before operation
#         0 = No
#         1 = Yes
# Work offsets:
# wcstype - Work coordinate system
#            0 = Reference return is generated and G92 with the
#                X, Y and Z home positions at file head.
#            1 = Reference return is generated and G92 with the
#                X, Y and Z home positions at each tool.
#            2 = WCS of G54, G55.... based on Mastercam settings.
#                0 thru 5 = The WCS of G54 thru G59 respectively.
#                6 and up = The WCS of G54.1 P1 and up.
#            3 = Off
#Canned text:
#    Entering cantext on a contour point from within Mastercam allows the
#    following functions to enable/disable.
#    Cantext value:
#    1 = Stop = output the "M00" stop code
#    2 = Ostop =  output the "M01" optional stop code
#    3 = Bld on = turn on block delete codes in NC lines
#    4 = bLd off = turn off block delete codes in NC lines
#    5 = Dwell = Input G04 K100 command
#Milling toolpaths (4 axis)
#Layout:
# The term "Reference View" refers to the coordinate system associated
# with the Top view (Alt-F9, the upper gnomon of the three displayed).
# Create the part drawing with the axis of rotation about the axis
# of the "Reference View" according to the setting you entered for
# 'vmc' (vertical or horizontal) and 'rot_on_x' (machine relative
# axis of rotation).
# vmc = 1 (vertical machine) uses the top toolplane as the base machine
# view.
# vmc = 0 (horizontal machine) uses the front toolplane as the base machine
# view.
# Relative to the machine matrix -
# Rotation zero position is on the Z axis for rotation on X axis.
# Rotation zero position is on the Z axis for rotation on Y axis.
# Rotation zero position is on the X axis for rotation on Z axis.
# The machine view rotated about the selected axis as a "single axis
# rotation" are the only legal views for 4 axis milling.  Rotation
# direction around the part is positive in the CCW direction when
# viewed from the plus direction of the rotating axis.  Set the variable
# 'rot_ccw_pos' to indicate the signed direction.  Always set the work
# origin at the center of rotation.
#Toolplane Positioning:
# Create the Cplane and Tplane as the rotation of the machine view about
# the selected axis of rotation.  The toolplane is used to calculate
# the position of the rotary axis.  This is the default setting.
#3 Axis Rotary (Polar)
# Polar positioning is offered in Mastercam 3 axis toolpaths through the
# rotary axis options dialog.  The selected toolpath is converted to angle
# and radius position.  The axis of rotation is forced to zero.
#Axis substitution:
# Use the Rotary axis substitution by drawing the geometry flattened
# from the cylinder.  The rotary axis button must be active for axis
# substitution information to be output to the NCI file. The radius of
# the rotary diameter is added to all the Z positions at output.
#Simultaneous 4 Axis (11 gcode):
# Full 4 axis toolpaths can be generated from various toolpaths under the
# 'multi-axis' selection (i.e. Rotary 4 axis). All 5 axis paths are
# converted to 4 axis paths where only the angle about the rotation axis
# is resolved.
#Drill:
# All drill methods are supported in the post.  See Simultaneous 4 Axis.
#Additional Notes:
# 1) Disable 4 axis by setting the numbered question 164. to 'n'.
# 2) G54 calls are generated where the work offset entry of 0 = G54,
#    1 = G55, etc.
# 3) Metric is applied from the NCI met_tool variable.
# 4) Incremental mode calculates motion from home position at toolchanges.
#    The home position is used to define the last position of the tool
#    for all toolchanges.
# 5) The variable 'absinc' is now pre-defined, set mi2 (Misc. Integer) for
#    the 'top level' absolute/incremental program output.  Subprograms are
#    updated through the Mastercam dialog settings for sub-programs.
# 6) Always avoid machining to the center of rotation with rotary axis!
# 7) Transform subprograms are intended for use with G54.. workshifts.
# General Output Settings
spaces      : 1     #Number of spaces to add between fields
omitseq     : no    #Omit sequence numbers?
seqmax      : 9999  #Max. sequence number
arcoutput   : 0     #0 = IJK, 1 = R no sign, 2 = R signed neg. over 180
arctype     : 2     #Arc center 1=abs, 2=St-Ctr, 3=Ctr-St, 4=unsigned inc.
breakarcs   : 2     #Break arcs, 0 = no, 1 = quadrants, 2 = 180deg. max arcs
do_full_arc : 0     #Allow full circle output? 0=no, 1=yes
helix_arc   : 1     #Support helix arc output, 0=no, 1=all planes, 2=XY plane only
maxrad      : 999   #Maximum arc radius
hel_2100    : no    #Acramatic 2100 style helical moves, 0=no, 1=yes
usecanned   : yes   #Use canned drilling cycles?  Set to no for long output.
wcstype     : 2     #0 = G92 at start, 1 = G92 at toolchanges, 2 = G54, 3 = Off
force_wcs   : yes   #Force WCS output at every toolchange?
stagetool   : 0     #0 = Do not pre-stage tools, 1 = Stage tools
tool_table  : 1     #Tool table, 0=no, 1=yes, 2=Predator VCNC, 3=MetaCut View
output_z    : yes   #Output Z Min and Z Max values (yes or no)
cool_zmove  : yes   #Coolant off with last move
use_pitch   : 0     #0 = Use feed for tapping, 1 = Use pitch for tapping
maxfeedpm   : 500   #Limit for feed in inch/min
maxfeedpm_m : 10000 #Limit for feed in mm/min
use_gear    : 0     #Output gear selection code, 0=no, 1=yes
max_speed   : 10000 #Maximum spindle speed
min_speed   : 50    #Minimum spindle speed
sextnc      .PIM    #NC extension override
# Rotary Axis Settings
# Typical Vertical
srotary     "A"     #Rotary axis prefix
vmc         : 1     #0 = Horizontal Machine, 1 = Vertical Mill
rot_on_x    : 1     #Default Rotary Axis Orientation, See ques. 164.
                    #0 = Off, 1 = About X, 2 = About Y, 3 = About Z
# Typical Horizontal
#srotary     "B"     #Rotary axis prefix
#vmc         : 0     #0 = Horizontal Machine, 1 = Vertical Mill
#rot_on_x    : 2     #Default Rotary Axis Orientation, See ques. 164.
#                    #0 = Off, 1 = About X, 2 = About Y, 3 = About Z
rot_ccw_pos : 1     #Axis signed dir, 0 = CW positive, 1 = CCW positive
ret_on_indx : 1     #Machine home retract on rotary index moves, (0 = no, 1 = yes)
index       : 0     #Use index positioning, 0 = Full Rotary, 1 = Index only
ctable      : 5     #Degrees for each index step with indexing spindle
one_rev     : 0     #Limit rotary indexing between 0 and 360? (0 = No, 1 = Yes)
lock_codes  : 0     #Use rotary axis unlock/lock M-Codes? (0 = No, 1 = Yes)
use_frinv   : 0     #Use Inverse Time Feedrates in 4 Axis, (0 = no, 1 = yes)
rot_feed    : 1     #Use calculated rotary feed values, (0 = no, 1 = yes)
maxfrdeg    : 2000  #Limit for feed in deg/min
maxfrinv    : 999.99#Limit for feed inverse time
frc_cinit   : 1     #Force C axis reset at toolchange
ctol        : 225   #Tolerance in deg. before rev flag changes
ixtol       : .01   #Tolerance in deg. for index error
frdegstp    : 10    #Step limit for rotary feed in deg/min
# Debugging and Factory Set Program Switches
fastmode    : yes   #Posting speed optimizition
bug1        : 2     #0=No display, 1=Generic list box, 2=Editor
bug2        : 60    #Append postline labels, non-zero is column position?
bug3        : 0     #Append whatline no. to each NC line?
bug4        : 0     #Append NCI line no. to each NC line?
whatno      : yes   #Do not perform whatline branches? (leave as yes)
# Additional General Output Settings
ldrcode   : 0      # Leader character dec. equiv. (fleader outputs code)
ncldr     : 20     # No. of leader characters (fleader outputs code)
nobrk     : no     # Omit breakup of x/y & z rapid moves LEAVE AS NO!!!
omitcrlf  : no     # Omit CR/LF
#eob       : 42    # End of block
nobrk       : no    #Omit breakup of x, y & z rapid moves
progname    : 1     #Use uppercase for program name (sprogname)
sub_level   : 1     #Enable automatic subprogram support
sub_seq_typ : 1     #Enable subprogram sequence number reset at sub call
arccheck    : 3     #Check for small arcs, convert to linear
atol        : .01   #Angularity tolerance for arccheck = 2
ltol        : .002  #Length tolerance for arccheck = 1
vtol        : .0001 #System tolerance
ltol_m      : .05   #Length tolerance for arccheck = 1, metric
vtol_m      : .0025 #System tolerance, metric
tooltable   : 1     #Read for tool table and pwrtt - use tool_table to disable
m_one       : -1    #Define constant
zero        : 0     #Define constant
one         : 1     #Define constant
two         : 2     #Define constant
three       : 3     #Define constant
four        : 4     #Define constant
five        : 5     #Define constant
c9k         : 9999  #Define constant
get_1004    : 1     #Find gcode 1004 with getnextop?
rpd_typ_v7  : 0     #Use Version 7 style contour flags/processing?
strtool_v7  : 2     #Use Version 7+ toolname?
tlchng_aft  : 2     #Delay call to toolchange until move line
cant_tlchng : 1     #Ignore cantext entry on move with tlchng_aft
newglobal   : 1     #Error checking for global variables
getnextop   : 1     #Build the next variable table
error_msg   : 1     #0=file and prompt, 1=to screen, 2=one to screen
err_file    : 1     #0=fatal, 1=all errors, 2=inc mprint, 3=inc prompts, 4=always
# Enable Canned Drill Cycle Switches
usecandrill : yes   #Use canned cycle for drill
usecanpeck  : yes   #Use canned cycle for Peck
usecanchip  : yes   #Use canned cycle for Chip Break
usecantap   : yes   #Use canned cycle for Tap
usecanbore1 : yes   #Use canned cycle for Bore1
usecanbore2 : yes   #Use canned cycle for Bore2
usecanmisc1 : yes   #Use canned cycle for Misc1
usecanmisc2 : yes   #Use canned cycle for Misc2
# Common User-defined Variable Initializations (not switches!)
xia         : 0     #Formated absolute value for X incremental calculations
yia         : 0     #Formated absolute value for Y incremental calculations
zia         : 0     #Formated absolute value for Z incremental calculations
cia         : 0     #Formated absolute value for C incremental calculations
cuttype     : 0     #Cut type flag
                    #0 = Tool Plane, 1 = Axis Subs,  2 = Polar, 3 = 4/5 axis
bld         : 0     #Block delete active
result      : 0     #Return value for functions
sav_spc     : 0     #Save spaces
sav_gcode   : 0     #Gcode saved
sav_absinc  : 0     #Absolute/Incremental Saved Value
sav_coolant : 0     #Coolant saved
sav_workofs : 0     #Saved work offset
sav_frc_wcs : 0     #Force work offset flag saved
sav_progno  : 0     #Saved program number
#sav_n1      : 0     #Saved sequence number
#sav_n2      : 0     #Saved sequence number
sav_rot_on_x : 0    #Rotary configuration saved
toolchng    : 1     #On a toolchange flag
spdir2      : 1     #Copy for safe spindle direction calculation
#Drill variables
drlgsel     : -1    #Drill Select Initialize
drillref    : 0     #Select drill reference
peckacel    : 0     #Fractional percent to reduce peck2 when usecan.. : no
drlgcode    : 0     #Save Gcode in drill
sav_dgcode  : 0     #Drill gcode saved
#Subprogram variables
mr_rt_actv  : 0     #Flag to indicate if G51/G68 is active
                    #0=Off, 1=Toolchange, 2=Subprogram call/start, G68
                    #3=Absolute start, both
rt_csav     : 0     #C saved value
end_sub_mny : 0     #Many tool setting captured at transform sub end
#Rotary/Index variables
prvcabs     : 0     #Saved cabs from pe_inc_calc,
                    #Used for rotary feed and direction calculations
cdelta      : 0     #Calculation for angle change
rev         : 0     #Calculation for deg/min
sav_rev     : 0     #Saved revolution counter
indx_out    : c9k   #Rotation direction calculation
fmt     16  indx_mc #Rotation direction calculation
#Vector Constants for Rotatary Calculations
aaxisx      : 1     #A axis rotation vector constant
aaxisy      : 0     #A axis rotation vector constant
aaxisz      : 0     #A axis rotation vector constant
baxisx      : 0     #B axis rotation vector constant
baxisy      : 1     #B axis rotation vector constant
baxisz      : 0     #B axis rotation vector constant
caxisx      : 0     #C axis rotation vector constant
caxisy      : 0     #C axis rotation vector constant
caxisz      : 1     #C axis rotation vector constant
#Feedrate calculation variables
frdelta     : 0     #Calculation for deg/min
frinv       : 0     #Feedrate inverse time
frdeg       : 0     #Feedrate deg/min actual
prvfrdeg    : 0     #Feedrate deg/min actual
ldelta      : 0     #Calculation for deg/min, linear
cldelta     : 0     #Calculation for deg/min, linear and rotary
circum      : 0     #Calculation for deg/min
ipr_type    : 0     #Feedrate for Rotary, 0 = UPM, 1 = DPM, 2 = Inverse
#Misc variables
tcnt       : 0     # Count the number of tool changes
toolcount  : 1     # Tool counter for logic control
toolcountn : 0     # Next tool counter for logic control
toolcountp : 0     # Previous tool counter for logic control
tooltotal  : 0     # Tool tool count
nexttool   : 0     # Next actual tool
nexttp     : 0     # Next tool plane
prvtp      : 0     # Previous tool plane
counter    : 0     # Counter
nstrlen    : 0     # Length of string
last_op_id : 0     # Previous internal operation id
last_cuttype : 0   # Previous cuttype
stock_typ  : 0     # Predator Stock Type
cyl_typ    : 0     # Predator Cyl Stock Type
z_min      : 99999 # Min Z
z_tmin     : 99999 # Overall min Z
z_max      : -99999# Max Z
z_tmax     : -99999# Overall max Z
tapflg     : 0     # Flag for tap cycle
sav_mi9    : 0     # Saved mi9 value
numpeck    : 0     # Number of pecks
# FORMULAS - global formulas
toolcountn = toolcount + 1   # Index!
toolcountp = toolcount - 1   # Index!
# Format statements - n=nonmodal, l=leading, t=trailing, i=inc, d=delta
#Default english/metric position format statements
fs2 1   0.7 0.6     #Decimal, absolute, 7 place, default for initialize (:)
fs2 2   0.4 0.3     #Decimal, absolute, 4/3 place
fs2 3   0.4 0.3d    #Decimal, delta, 4/3 place
#Common format statements
fs2 4   1 0 1 0     #Integer, not leading
fs2 5   2 0 2 0l    #Integer, force two leading
fs2 6   3 0 3 0l    #Integer, force three leading
fs2 7   4 0 4 0l    #Integer, force four leading
fs2 8   5 0 5 0l    #Integer, force five leading
fs2 9   0.1 0.1     #Decimal, absolute, 1 place
fs2 10  0.2 0.2     #Decimal, absolute, 2 place
fs2 11  0.3 0.3     #Decimal, absolute, 3 place
fs2 12  0.4 0.4     #Decimal, absolute, 4 place
fs2 13  0.5 0.5     #Decimal, absolute, 5 place
fs2 14  0.3 0.3d    #Decimal, delta, 3 place
fs2 15  0.2 0.1     #Decimal, absolute, 2/1 place
fs2 16  1 0 1 0n    #Integer, forced output
fs  17  1.4lt       #Decimal, absolute, four trailing
#String and string selector definitions for NC output
#Numbered question 164. string to detect Rotary axis y/n
sq164
#Address string definitions
stri        "I"
strj        "J"
strk        "K"
strm        "M"
strn        "N"
stro        "O"
strp        "P"
srad        "R"
srminus     "R-"
sblank
#Cantext string definitions (spaces must be padded here)
sm00        "M00"
sm01        "M01"
scant5      "G04 P1"
strtextno
strcantext
#Transform mirror and rotate codes
strns_mir_on     "G51.1" #Programmable mirror image code
strns_mir_off    "G50.1" #Programmable mirror image cancel code
strns_rot_on     "G68"   #Coordinate System Rotation
strns_rot_off    "G69"   #Coordinate System Rotation Cancel
# Error messages
saxiswarn   "WARNING-POST ROTARY AXIS ASSIGNMENT ('rot_on_x') OVERWRITTEN BY OPERATION"
saxisoff    "ERROR-POST ROTARY AXIS ASSIGNMENT ('rot_on_x') IS DISABLED"
saxiserror  "ERROR-INVALID ROTARY AXIS ASSIGNMENT ('rot_on_x') FOR CURRENT OPERATION"
sindxerror  "WARNING-INDEX ANGLE DOES NOT MATCH POST SETTING ('ctable')"
stlorgerr   "ERROR-TOOL ORIGIN DOES NOT MATCH CENTER OF ROTATION IN POLAR MILLING"
shomeserror "ERROR-G92 WORK OFFSET ('wcstype') DOES NOT SUPPORT TRANSFORM SUBPROGRAM"
sprgnerror  "ERROR-SUBPROGRAM NUMBER MATCHES THE MAIN PROGRAM NUMBER"
# Misc strings
snull     ""       # Null character string
sdot      "."      # dot string
stest1    ""       # Test string 1
stilde    "~"      # Tidle string
snocomm   "DEFINE TOOL NAMES"
stoper    ""       # String for tool notes
spostname ""       # Post name
snullop   "UNDEFINED OPERATION"
slicense  "IN-HOUSE SOLUTIONS"
# Parameter Tables
fprmtbl 13      2         # Multisurf Finish
        10010   stock     # Amount of stock to leave on drive surfs
        10227   check     # Amount of stock to leave on check surfs
fprmtbl 14      2         # Multisurf Rough
# Buffer 3 - Holds the variable 'tlplnno' for each toolpath segment
rc3 : 1
wc3 : 1
fbuf 3 0 1 0    # Buffer 3
# Buffer 4 - Holds the variable 't' for each toolpath segment
rc4 : 1
wc4 : 1
fbuf 4 0 1 0    # Buffer 4
# Buffer 5 - Min / Max
b5_gcode : 0
b5_zmin  : 0
b5_zmax  : 0
rc5     : 2
wc5     : 1
size5   : 0
fbuf 5 0 3 0            #Min / Max
# Question format statements
fq 1 stock_typ Predator Stock [0=Box,1=Cylindrical]
fq 2 cyl_typ Cylindrical Stock Axis [1=X,2=Y,3=Z]
# Strings - String labels must start with 's' - they are not pre-assigned
#Select operation note
sop00   "NULL......."      # String definition
sop01   "CONTOUR...."      #    "       "
sop02   "CONTOUR...."      #    "       "
sop03   "DRILL/MISC."      #    "       "
sop04   "POCKET....."      #    "       "
sop05   "RULED......"      #    "       "
sop06   "2D-SWEPT..."      #    "       "
sop07   "3D-SWEPT..."      #    "       "
sop08   "REVOLVED..."      #    "       "
sop09   "LOFT......."      #    "       "
sop10   "COONS......"      #    "       "
sop11   "FILLET....."      #    "       "
sop12   "FLOWLINE..."      #    "       "
sop13   "M.FINISH..."      #    "       "
sop14   "M.ROUGH...."      #    "       "
sop15   "POINT......"      #    "       "
sop16   "DRILL5AX..."      #    "       "
sop17   "CURVE5AX..."      #    "       "
sop18   "SWARF5AX..."      #    "       "
sop19   "FACING....."      #    "       "
sop20   "OP20......."      #    "       "
sopnote                    # Target string
fstrsel  sop00 opcode sopnote
sdr00   "DRILL/CBORE"    # String definition
sdr01   "PECK DRILL."    #    "       "
sdr02   "CHIP BREAK."    #    "       "
sdr03   "TAP........"    #    "       "
sdr04   "BORE 1....."    #    "       "
sdr05   "BORE 2....."    #    "       "
sdr06   "FINE BORE.."    #    "       "
sdr07   "MISC 2....."    #    "       "
sdr08   "CUST 9....."    #    "       "
sdr09   "CUST 10...."    #    "       "
sdr10   "CUST 11...."    #    "       "
sdr11   "CUST 12...."    #    "       "
sdr12   "CUST 13...."    #    "       "
sdr13   "CUST 14...."    #    "       "
sdr14   "CUST 15...."    #    "       "
sdr15   "CUST 16...."    #    "       "
sdr16   "CUST 17...."    #    "       "
sdr17   "CUST 18...."    #    "       "
sdr18   "CUST 19...."    #    "       "
sdr19   "CUST 20...."    #    "       "
sdrnote                  # Target string
fstrsel  sdr00 nextdc sdrnote
# Select month
smon00        ""
smon01        "JAN"
smon02        "FEB"
smon03        "MAR"
smon04        "APR"
smon05        "MAY"
smon06        "JUN"
smon07        "JUL"
smon08        "AUG"
smon09        "SEP"
smon10        "OCT"
smon11        "NOV"
smon12        "DEC"
smonth
fstrsel smon00 month smonth
# General G and M Code String select tables
# Motion G code selection
sg00    G00     #Rapid
sg01    G01     #Linear feed
sg02    G02     #Circular interpolation CW
sg03    G03     #Circular interpolation CCW
sg04    G04     #Dwell
sgcode          #Target for string
fstrsel sg00 gcode sgcode
# Select work plane G code
sg17    G17     #XY plane code
sg19    G19     #YZ plane code
sg18    G18     #XZ plane code
sgplane         #Target string
fstrsel sg17 plane sgplane
#Select english/metric code
sg20    G70     #Inch code
sg21    G71     #Metric code
smetric         #Target string
fstrsel sg20 met_tool smetric
# Cutter compensation G code selection
scc0    G40     #Cancel cutter compensation
scc1    G41     #Cutter compensation left
scc2    G42     #Cutter compensation right
sccomp          #Target for string
fstrsel scc0 cc_pos sccomp
# Canned drill cycle string select
sg81    G81     #drill      - no dwell
sg81d   G82     #drill      - with dwell
sg83    G83     #peck drill - no dwell
sg83d   G83     #peck drill - with dwell
sg73    G69     #chip break - no dwell
sg73d   G69     #chip break - with dwell
sg84    G84     #tap        - right hand
sg84d   G84     #tap        - left hand
sg85    G89     #bore #1    - no dwell
sg85d   G89     #bore #1    - with dwell
sg86    G86     #bore #2    - no dwell
sg86d   G86     #bore #2    - with dwell
sgm1    G85     #misc #1    - no dwell
sgm1d   G85     #misc #1    - with dwell
sgm2    G81     #misc #2    - no dwell
sgm2d   G82     #misc #2    - with dwell
sgc9    G81     #custom #9  - no dwell
sgc9d   G82     #custom #9  - with dwell
sgdrill         #Target for string
fstrsel sg81 drlgsel sgdrill
# Select incremental or absolute G code
sg90    G90     #Absolute code
sg91    G91     #Incremental code
sgabsinc        #Target string
fstrsel sg90 absinc sgabsinc
# Feed mode G code selection
sg94    G94     #UPM
sg94d   G94     #DPM, See pfcalc_deg if you use another gcode
sg93    G93     #Inverse
sgfeed          #Target for string
fstrsel sg94 ipr_type sgfeed
#Canned drill cycle reference height
sg98    G98     #Reference at initht
sg99    G99     #Reference at refht
sgdrlref        #Target for string
fstrsel sg98 drillref sgdrlref        # Drill cycle G string select
# Generate string for spindle
sm04    M04     #Spindle reverse
sm05    M05     #Spindle off
sm03    M03     #Spindle forward
spindle         #Target for string
fstrsel sm04 spdir2 spindle
# Coolant M code selection
sm09    M09     #Coolant Off (Use sm09_0 through sm09_2)
sm08    M08     #Coolant Flood
sm08_1  M07     #Coolant Mist
sm08_2  M08     #Coolant Tool
sm09_0  M09     #Coolant Flood Off
sm09_1  M09     #Coolant Mist Off
sm09_2  M09     #Coolant Tool Off
scoolant        #Target for string
fstrsel sm09 coolant scoolant
# Table unlock and lock codes
slock   M10     #Axis lock
sunlock M11     #Axis unlock
# Table rotation direction
# Table rotation direction, index
sindx_cw   M22  #Rotate CW code
sindx_ccw  M21  #Rotate CCW code
sindx_mc        #Target for string
fstrsel sindx_cw indx_mc sindx_mc
# Define the gear selection code
flktbl  1       3       #Lookup table definition - table no. - no. entries
        40      0       #Low gear range
        41      400     #Med gear range
        42      2250    #Hi gear range
# Toolchange / NC output Variable Formats
fmt  T  4   t           #Tool No
fmt  T  4   first_tool  #First Tool Used
fmt  T  4   next_tool   #Next Tool Used
fmt  D  4   tloffno     #Diameter Offset No
fmt  D  4   tlngno      #Length Offset No
fmt  G  4   g_wcs       #WCS G address
fmt  P  4   p_wcs       #WCS P address
fmt  S  4   speed       #Spindle Speed
fmt  M  4   gear        #Gear range
fmt  N  4   n           #Sequence number
fmt  X  2   xabs        #X position output
fmt  Y  2   yabs        #Y position output
fmt  Z  2   zabs        #Z position output
fmt  X  3   xinc        #X position output
fmt  Y  3   yinc        #Y position output
fmt  Z  3   zinc        #Z position output
fmt  A  11  cabs        #C axis position
fmt  A  14  cinc        #C axis position
fmt  A  4   indx_out    #Index position
fmt  R  14  rt_cinc     #C axis position, G68
fmt  I  3   i           #Arc center description in X
fmt  J  3   j           #Arc center description in Y
fmt  K  3   k           #Arc center description in Z
fmt  K  2   lead        #Helical lead
fmt  R  2   arcrad      #Arc Radius
fmt  F  15  feed        #Feedrate
fmt  K  4   dwell       #Dwell
fmt  K  4   dwell_out   #Dwell
fmt  M  5   cantext     #Canned text
#Move comment (pound) to output colon with program numbers
fmt     8   progno      #Program number
fmt     4   main_prg_no #Program number
fmt     4   sub_prg_no  #Program number
fmt     4   sub_prg_call#Program number
fmt  X  2   sub_trnsx   #Rotation point
fmt  Y  2   sub_trnsy   #Rotation point
fmt  Z  2   sub_trnsz   #Rotation point
fmt  I  2   peck1       #First peck increment (positive)
fmt  R  2   peck2       #Second or last peck (positive)
fmt  C  2   peckclr     #Safety distance
fmt  H  2   retr        #Retract height
fmt  J  4   shftdrl     #Fine bore tool shift
fmt  Z  2   zdrl        #Depth of drill point
fmt  Z  2   tosz        #Drilling top of stock
fmt  N  4   n_tap_thds  #Number of threads per inch (tpi)
fmt  F  2   pitch       #Tap pitch (inches per thread)
fmt  Z  2   refht_a     #Reference height
fmt  Z  2   refht_i     #Reference height
fmt  J  4   numpeckint  #Number of pecks
fmt  B  2   bval        #Peck value
fmt  D  2   dval        #Refht to zdrl
fmt "TOOL - "       4   tnote       # Note format
fmt " DIA. OFF. - " 4   toffnote    # Note format
fmt " LEN. - "      4   tlngnote    # Note format
fmt " DIA. - "      1   tldianote   # Note format
fmt  D 17 tldia                   # Note format
fmt  R 17 tcr                     # Note format
fmt  D  2 tldia_pred              # Predator VCNC format
fmt  C  2 tcr_pred                # Predator VCNC format
fmt  D  2 tldia_meta              # MetaCut View format
fmt  R  2 tcr_meta                # MetaCut View format
fmt  F  2 flute_meta              # MetaCut View format
fmt  L  2 oa_meta                 # MetaCut View format
fmt  A  2 ta_meta                 # MetaCut View format
fmt TD  2 td_meta                 # MetaCut View format
fmt CD  2 cd_meta                 # MetaCut View format
fmt CL  2 cl_meta                 # MetaCut View format
fmt SD  2 sd_meta                 # MetaCut View format
fmt  C  4 tipcomp                 # MetaCut View format
fmt     2 slot                    # 20004 Parameter line
fmt     2 tool_type
fmt     2 matl_type
fmt     2 corner_rad_type
fmt     2 diameter
fmt     2 corner_rad
fmt     2 threads
fmt  A  2 tip_angle
fmt     2 dia_off
fmt     2 len_off
fmt     2 tool_feed
fmt     2 plunge
fmt     2 retract
fmt     2 rpm
fmt     2 coolant1
fmt     2 n_flutes1
fmt  A  2 tip_angle_ch
fmt     2 cut_ability             # 20006 Parameter line
fmt     2 step_r_xy
fmt     2 step_r_z
fmt     2 step_f_xy
fmt     2 step_f_z
fmt     2 tip_dia
fmt     2 min_dia
fmt     2 thd_ang
fmt     2 pilot_dia               # 20007 Parameter line
fmt  H  2 flute_len
fmt     2 oa_len
fmt     2 shldr_len
fmt     2 arbor_dia
fmt     2 hldr_dia
fmt     2 hldr_len
fmt     2 spindle_ccw
fmt     2 sfm
fmt     2 fpt
fmt     2 metric
fmt    2 stock      # Amount of Stock left on drive surfs
fmt    2 check      # Amount of Stock left on check surfs
fmt  S 4 cyl_typ    # Predator Cylindral Stock Type
fmt  L 2 stck_ht
fmt  W 2 stck_wdth
fmt  H 2 stck_thck
fmt  D 2 stck_diam
fmt  X 2 stck_x
fmt  Y 2 stck_y
fmt  Z 2 stck_z
fmt  X 2 stck_x_min
fmt  Y 2 stck_y_min
fmt  Z 2 stck_z_min
fmt  X 2 stck_meta_ht
fmt  Y 2 stck_meta_wdth
fmt  Z 2 stck_meta_thck
fmt OX 2 stck_meta_ox
fmt OY 2 stck_meta_oy
fmt OZ 2 stck_meta_oz
fmt  X 2 x_tmin     # Total x_min
fmt  X 2 x_tmax     # Total x_max
fmt  Y 2 y_tmin     # Total y_min
fmt  Y 2 y_tmax     # Total y_max
fmt  Z 2 z_tmin     # Total z_min
fmt  Z 2 z_tmax     # Total z_max
fmt  Z 2 min_depth  # Tool z_min
fmt  Z 2 max_depth  # Tool z_max
fmt    2 vers_no     # Mastercam version
fmt    2 m_vers_no   # Minor version number
# Tool Comment / Manual Entry Section
ptoolcomment    #Comment for tool
      tnote = t
      toffnote = tloffno
      tlngnote = tlngno
      tldianote = tldia
      ";", pstrtool, *tnote, *toffnote, *tlngnote, *tldianote, e
pstrtool        #Comment for tool
      if strtool <> sblank,
        strtool = ucase(strtool)
        *strtool, " "
pcomment        #Comment from manual entry (must call pcomment2 if booleans)
      pcomment2
pcomment2       #Comment from manual entry
      spaces = 0
      scomm = ucase (scomm)
      #1005 - Comment option 1
      #1006 - Comment option 2
      #1007 - Define comment with output line
      #1008 - Define NC parameter comment
      #1026 - ?
      if gcode = 1005, pbld, n, pspc, ";", scomm
      if gcode = 1006, pbld, n, pspc, ";", scomm  #Comments
      #if gcode = 1006, pbld, n, pspc, scomm  #Codes
      if gcode = 1007, ";", scomm
      if gcode = 1008, pbld, n, pspc, ";", scomm
      if gcode = 1026, pbld, scomm
      if gcode <> 1007 & gcode <> 1026, e
      spaces = sav_spc
ptoolcomm  # Comments from tool library
           spaces = 0
           strtool=ucase(strtool)
           if strtool<>snull, pspc1, ";", *strtool, e
           else, pspc1, ";", "DEFINE TOOL NAMES", e
           spaces = sav_spc
plistcomm  # Comments from tool library
           if strtool<>snull, *strtool
           else, "DEFINE TOOL NAMES"
           if strtool=snull, stest1=snocomm+stilde
           else, stest1=strtool+stilde
           nstrlen = strstr(stilde,stest1)-1
           counter = 1
           while counter <= (25-nstrlen), pspace
pmetacomm  # Comments from tool library
pspace     # Creates spaces based on tool comment length
           counter = counter + 1
ptspace    # Creates spaces based on tool number
           if t<10, " "
phspace    # Creates spaces based on length offset number
           if tlngno<10, " "
pdspace    # Creates spaces based on diameter offset number
           if tloffno<10, " "
pdiamspc   # Creates spaces based on diameter offset number
           if tldia<10, " "
pspc       # Creates spaces based tool level setting
           if sav_spc = one & omitseq = no, " "
pspc1      # Creates spaces based tool level setting
           if sav_spc = one, " "
popnote    # Operation note for tool table
           if opcode = 3, *sdrnote
           else, *sopnote
pstock     # Comment amount of stock to leave
           spaces=0
           if (opcode=13 | opcode=14),
             pbld, n, pspc, ";TOOLPATH - ", *stoper, e
             pbld, n, pspc, ";STOCK LEFT ON DRIVE SURFS = ", *stock, e
             if check<>0, pbld, n, pspc, ";STOCK LEFT ON CHECK SURFS = ", *check, e
           spaces=sav_spc
ppredstck  # Predator stock
           spaces=0
           q1
           if stock_typ = 1,
             cyl_typ = rot_on_x
             q2
           if stock_typ = 0, ppredbox
           if stock_typ = 1,
             if cyl_typ = 1, ppredcylx
             if cyl_typ = 2, ppredcyly
             if cyl_typ = 3, ppredcylz
           spaces=sav_spc
ppredbox   # Predator Box Stock
           if stck_crnr = 0,
             stck_x_min = stck_x - stck_ht/2
             stck_y_min = stck_y - stck_wdth/2
           if stck_crnr = 1 | stck_crnr = 5,
             stck_x_min = stck_x
           if stck_crnr = 2 | stck_crnr = 6,
           if stck_crnr = 3 | stck_crnr = 7,
             stck_y_min = stck_y
           if stck_crnr = 4 | stck_crnr = 8,
             stck_x_min = stck_x
             stck_y_min = stck_y
           if stck_crnr <= 4, stck_z_min = stck_z - stck_thck
           else, stck_z_min = stck_z
           "(SBOX ", *stck_x_min, " ", *stck_y_min, " ", *stck_z_min, " ", *stck_ht, " ", *stck_wdth, " ", *stck_thck, ")"
ppredcylx  # Predator Cyl-X Stock
           if stck_crnr = 0,
             stck_y_min = stck_y
             stck_x_min = stck_x
             stck_y_min = stck_y + stck_wdth/2
             stck_x_min = stck_x
           if stck_crnr <= 4, stck_z_min = stck_z - stck_thck/2
           else, stck_z_min = stck_z + stck_thck/2
           stck_diam = stck_wdth
           if stck_thck > stck_wdth, stck_diam = stck_thck
           stck_ht = stck_ht
           "(SCYL ", *cyl_typ, " ", *stck_x_min, " ", *stck_y_min, " ", *stck_z_min, " ", *stck_diam, " ", *stck_ht, ")"
ppredcyly  # Predator Cyl-Y Stock
           if stck_crnr = 0,
             stck_x_min = stck_x
             stck_x_min = stck_x + stck_ht/2
             stck_y_min = stck_y
             stck_y_min = stck_y
           stck_diam = stck_ht
           if stck_thck > stck_ht, stck_diam = stck_thck
           stck_ht = stck_wdth
ppredcylz  # Predator Cyl-Z Stock
           if stck_crnr = 0,
             stck_x_min = stck_x
             stck_y_min = stck_y
           stck_diam = stck_ht
           if stck_wdth > stck_ht, stck_diam = stck_wdth
           stck_ht = stck_thck
pmetastck  # MetaCut View stock
           if stck_crnr = 0,
             stck_meta_ox = stck_x * m_one - (tox * m_one)
             stck_meta_oy = stck_y * m_one - (toy * m_one)
             stck_meta_ox = (stck_x + stck_ht/2) * m_one - (tox * m_one)
             stck_meta_oy = (stck_y - stck_wdth/2) * m_one - (toy * m_one)
             stck_meta_ox = (stck_x - stck_ht/2) * m_one - (tox * m_one)
             stck_meta_oy = (stck_y + stck_wdth/2) * m_one - (toy * m_one)
           if stck_crnr <= 4, stck_meta_oz = stck_z * m_one - (toz * m_one)
           else, stck_meta_oz = (stck_z + stck_thck) * m_one - (toz * m_one)
           stck_meta_ht = stck_ht
           stck_meta_wdth = stck_wdth
           stck_meta_thck = stck_thck
           #(NWDSTOCK X8. Y8. Z1.25 OTC OX-4. OY-4. OZ0.)
           spaces=0
           "(NWDSTOCK ", *stck_meta_ht, " ", *stck_meta_wdth, " ", *stck_meta_thck,
           " OTC ", *stck_meta_ox, " ", *stck_meta_oy, " ", *stck_meta_oz, ")"
           spaces=sav_spc
pstop      # Stop routine
           pretract
           pcom_moveb
           if mi10=one, n, *sm00, e
           pbld, n, pwcs, e
           sav_absinc = absinc
           if wcstype > one, absinc = zero
           if lock_codes = 1 & not(index) & rot_on_x, pbld, n, *sunlock, ";UNLOCK", e
           pcan1, pbld, n, *sgcode, *sgabsinc, pfxout, pfyout,
             pfcout, *speed, *spindle, pgear, strcantext, e
           if lock_codes = 1 & not(index) & rot_on_x & cuttype = 0, pbld, n, *slock, ";LOCK", e
           pbld, n, "G43", *tlngno, pfzout, scoolant, next_tool, e
           sav_coolant = coolant
           if coolant = 1, sm09 = sm09_0
           if coolant = 2, sm09 = sm09_1
           if coolant = 3, sm09 = sm09_2
           absinc = sav_absinc
# Misc. Output
pparameter # Run parameter table
           if opcode=13 | opcode=14, result = fprm (opcode)
           if prmcode = 10000, stoper = ucase(sparameter)
           if prmcode = 10055, spostname = ucase(sparameter)
           if stoper=snull, stoper = snullop
pwrttparam #Information from parameters
           if prmcode = 20004, slot = rpar(sparameter, 16)
           if prmcode = 20006, cut_ability = rpar(sparameter,8)
           if prmcode = 20007, pilot_dia = rpar(sparameter, 11)
# Start of File and Toolchange Setup
psof0           #Start of file for tool zero
      psof
psof            #Start of file for non-zero tool number
      ptravel
      pwritbuf5
      pcuttype
      toolchng = one
      if ntools = one,
        #skip single tool outputs, stagetool must be on
        #stagetool = m_one
        !next_tool
      tooltotal = rbuf(4,0)  #Reads total tool and null tool changes
      if toolcountn <= tooltotal, nexttool = rbuf(4,toolcountn)
      else, nexttool = first_tool
      if tool_table = 2, ppredstck
      if tool_table = 3, pmetastck
      spaces=0
      if output_z = yes & tcnt > 1,
        ";OVERALL MAX : ", *z_tmax, e
        ";OVERALL MIN : ", *z_tmin, e
      spaces=sav_spc
      if plane < 0, plane = 0
      pbld, n, *sgcode, *sgplane, "G40", "G44", *smetric, "G80", *sgabsinc, e
      sav_absinc = absinc
      if wcstype <= one, #Work coordinate system
        absinc = one
        pfbld, n, sgabsinc, "G28", "Z0.", e
        pfbld, n, "G28", "X0.", "Y0.", e
        pfbld, n, "G92", *xh, *yh, *zh, e
        absinc = sav_absinc
      sav_mi9 = mi9
      sav_workofs = workofs
      if sav_workofs < 0, sav_workofs = 0
      ptlchg_com
ptlchg_com      #Tool change common blocks
      pcom_moveb
      c_mmlt #Multiple tool subprogram call
      #ptoolcomment
      comment
      pcan
      if stagetool >= zero,
        pbld, n, *t, ptoolcomm, e
        pbld, n, "M06", e
      spaces=0
      if output_z = yes,
        preadbuf5
        if (opcode > 0 & opcode < 16) | opcode = 19,
          n, pspc, ";", "MAX : ", *max_depth, e
          n, pspc, ";", "MIN : ", *min_depth, e
      spaces=sav_spc
      pstock
      pindex
      pbld, n, pwcs, e
      sav_absinc = absinc
      absinc = sav_absinc
      pcom_movea
      toolchng = zero
      c_msng #Single tool subprogram call
      last_op_id = op_id
      last_cuttype = cuttype
ptlchg0         #Call from NCI null tool change (tool number repeats)
      pcuttype
      pcom_moveb
      toolcount = toolcount + 1
      prvtp = rbuf(3,toolcountp)
      if mi10=one & op_id<>last_op_id | (tlplnno <> prvtp & ret_on_indx), pstop
      comment
      pcan
      pbld, n, sgplane, e
      pspindchng
      if coolant <> 0 & coolant <> sav_coolant, pbld, n, sm09, e
      pbld, n, scoolant, e
      if op_id<>last_op_id, pstock
      if sav_mi9 = 1, workofs = sav_workofs
      if (wcstype > one & workofs <> prv_workofs) | (tlplnno <> prvtp & ret_on_indx),
        pbld, n, pwcs, e
        sav_absinc = absinc
        absinc = zero
        if fmtrnd(prv_cabs) <> fmtrnd(cabs),
          pbld, n, sgabsinc, pfxout, pfyout, pfzout, pfcout, e
        else,
          pbld, n, sgabsinc, pfxout, pfyout, pfzout, pcout, e
        pe_inc_calc
        ps_inc_calc
        absinc = sav_absinc
      if lock_codes = 1 & cuttype <> last_cuttype & cuttype > 0, pbld, n, *sunlock, ";UNLOCK", e
      if cuttype = zero, ppos_cax_lin
      if lock_codes = 1 & cuttype <> last_cuttype & cuttype = 0 & fmtrnd(prv_cabs) = fmtrnd(cabs), pbld, n, *slock, ";LOCK", e
      if gcode = one, plinout
      else, prapidout
      pcom_movea
      last_op_id = op_id
ptlchg          #Tool change
      pcuttype
      toolchng = one
      if wcstype = one, #Work coordinate system
      pbld, n, *sm01, e
      ptlchg_com
pretract        #End of tool path, toolchange
      sav_absinc = absinc
      absinc = zero
      coolant = zero
      #cc_pos is reset in the toolchange here
      cc_pos = zero
      gcode = zero
      pcan
      pbld, n, sccomp, *sm05, psub_end_mny, e
      pcan1, pbld, n, sgabsinc, sgcode, "G44", "G53", "Z0.", scoolant, strcantext, e
      #if lock_codes = 1 & rot_on_x, pbld, n, *sunlock, ";UNLOCK", e
      #pbld, n, "G53", "X0.", "Y0.", protretinc, e
      #if lock_codes = 1 & rot_on_x & cuttype = 0, pbld, n, *slock, ";LOCK", e
      if abs(cabs) > 360 & nextop <> 1003,
       if lock_codes = 1, pbld, n, *sunlock, ";UNLOCK", e
       pbld, n, 'G53', protretinc, e
       if lock_codes = 1 & cuttype = 0, pbld, n, *slock, ";LOCK", e
      pcan2
      absinc = sav_absinc
      coolant = sav_coolant
protretinc      #Reset the C axis revolution counter
      if frc_cinit & rot_on_x,
        rev = zero
        sav_rev = zero
        cabs = zero
        csav = zero
        indx_out = zero
        if index, e, pindxcalc, pindex
        else, *cabs
        prvcabs = zero
        !csav, !cabs
peof0           #End of file for tool zero
      peof
      pretract
      if lock_codes = 1 & rot_on_x, pbld, n, *slock, ";LOCK", e
      comment
      n, *sg90, e
      n, "M30", e
      mergesub
      clearsub
      mergeaux
      clearaux
      27  #ESC Escape Character
      #26  #EOF Enf of File Character
      #128 #Reported to work by Jax Mold
      #4  #EOT End of Tape Character
      #fleader  #Outputs 20 Null Characters if needed
pwcs            #G54+ coordinate setting at toolchange
      if wcstype = two | wcstype > three,
        sav_frc_wcs = force_wcs
        if sub_level, force_wcs = zero
        if workofs < 0, workofs = 0
        if workofs <> prv_workofs | (force_wcs & toolchng),
          if workofs < 6,
            g_wcs = workofs + 54
            *g_wcs
          else,
            p_wcs = workofs - five
            "G54.1", *p_wcs
        force_wcs = sav_frc_wcs
        !workofs
pgear           #Find spindle gear from lookup table
      if use_gear = one,
        gear = frange (one, speed)
        *gear
#Toolchange setup
pspindchng      #Spindle speed change
      if prv_spdir2 <> spdir2 & prv_speed <> zero, pbld, n, *sm05, e
      if prv_speed <> speed | prv_spdir2 <> spdir2,
        if speed, pbld, n, *speed, *spindle, pgear, e
      !speed, !spdir2
pspindle        #Spindle speed calculations for RPM
      speed = abs(ss)
      if maxss = zero | maxss > max_speed, maxss = max_speed
      #zero indicates spindle off (not a mistake)
      if speed,
        if speed > max_speed, speed = maxss
        if speed < min_speed, speed = min_speed
      spdir2 = fsg3(spdir)
pq              #Setup post based on switch settings
      sav_spc = spaces
      if stagetool = one, bldnxtool = one
      #Rotaxtyp = 1 sets initial matrix to top
      #Rotaxtyp = -2 sets initial matrix to front
      if vmc, rotaxtyp = one
      else, rotaxtyp = -2
      #Shut off rotary axis if, Q164. Enable Rotary Axis button? n
      if ucase(sq164) = strn, rot_on_x = zero
      if arctype = one | arctype = four,
        result = newfs(two, i)
        result = newfs(two, j)
        result = newfs(two, k)
      else,
        result = newfs(three, i)
        result = newfs(three, j)
        result = newfs(three, k)
      if usecanned = yes, pusecannedyes
      else, pusecannedno
pheader         #Call before start of file
      if met_tool = one, #Metric constants and variable adjustments
        ltol = ltol_m
        vtol = vtol_m
        maxfeedpm = maxfeedpm_m
      result = nwadrs(srotary, cabs)
      result = nwadrs(srotary, cinc)
      result = nwadrs(srotary, indx_out)
      spaces=0
      #"%99996"
      #if progno = 0, progno = 99999
      #"%", *progno, e
      "%", *progname, ",MX,", e
      spathnc = ucase(spathnc)
      smcname = ucase(smcname)
      #";PROGRAM NAME - ", sprogname, e
      #";DATE=DD-MM-YY - ", date, " TIME=HH:MM - ", time, e
      ";MASTERCAM - V", *vers_no, e
      ";MC9 FILE  - ", smcpath, smcname, smcext, e
      ";POST      - ", spostname, e
      stck_matl = ucase(stck_matl)
      ";MATERIAL  - ", stck_matl, e
      ";PROGRAM   - ", sprogname, sextnc, e
      ";DATE      - ", *smonth, "-", *day, "-", *year, e
      ";TIME      - ", *time, e
      ";POST DEV  - ", *slicense, e
      spaces=sav_spc
      if seqno = 0, omitseq = yes
      sav_rot_on_x = rot_on_x
      rot_on_x = 0
      sav_progno = progno
      #seqno = 10
      #seqinc = 10
      #n = seqno
ptoolend        #End of tool path, before reading new tool data
      !speed, !spdir2
ptlchg1002      #Call at actual toolchange, end last path here
      if op_id <> last_op_id,
        sav_rev = rev #Axis Sub does not update to rev
        if one_rev = one, sav_rev = 0
      pspindle
      whatline = four #Required for vector toolpaths
      if gcode = 1000,
        #Null toolchange
      else,
        #Toolchange and Start of file
        if gcode = 1002,
          #Actual toolchange
          pretract
        if stagetool = one, prv_next_tool = m_one
        prv_xia = vequ(xh)
        prv_feed = c9k
# Motion NC output
#The variables for absolute output are xabs, yabs, zabs.
#The variables for incremental output are xinc, yinc, zinc.
prapidout       #Output to NC of linear movement - rapid
      pcan1, pbld, n, sgplane, `sgcode, sgabsinc, pccdia,
        pxout, pyout, pzout, pcout, strcantext, scoolant, e
plinout         #Output to NC of linear movement - feed
      pcan1, pbld, n, sgfeed, sgplane, `sgcode, sgabsinc, pccdia,
        pxout, pyout, pzout, pcout, `feed, strcantext, scoolant, e
pcirout         #Output to NC of circular interpolation
      if hel_2100 = one, pcirout2
      else, pcirout1
pcirout1        #Output to NC of circular interpolation
      pcan1, pbld, n, `sgfeed, sgplane, sgcode, sgabsinc, pccdia,
        pxout, pyout, pzout, pcout, parc, feed, strcantext, scoolant, e
pcirout2        #Output to NC of circular interpolation
      if (plane = zero & abs(zinc)>=0.0005)
       | (plane =  one & abs(xinc)>=0.0005)
       | (plane =  two & abs(yinc)>=0.0005), phelout
      else, pcirout1
phelout         #Output to NC of helical interpolation
      lead = abs(zinc/sweep*360)
      if plane = zero, result = nwadrs(strk, lead)
      if plane = one,  result = nwadrs(stri, lead)
      if plane = two,  result = nwadrs(strj, lead)
        pxout, pyout, pzout, *lead, pcout, parc, feed, strcantext, scoolant, e
pcom_moveb      #Common motion preparation routines, before
      pxyzcout
      ps_inc_calc
pncoutput       #Movement output
      pcom_moveb
      comment
        pbld, n, sm09, e
      if cool_zmove = yes & (nextop=1003 | (nextop=1011 & t<>abs(nexttool))), coolant = zero
      pcan
      if cuttype = zero, ppos_cax_lin #Toolplane rotary positioning
      if gcode = zero, prapidout
      if gcode > one & gcode < four, pcirout
      if mr_rt_actv, #Restore absolute/incremental for G51/G68
        absinc = sav_absinc
        mr_rt_actv = zero
      pcom_movea
pcom_movea      #Common motion preparation routines, after
      pcan2
      pe_inc_calc
pdwl_spd        #Call from NCI gcode 4
      pspindle
      comment
      pspindchng
      pcan
      if fmtrnd(dwell), pcan1, pbld, n, *sgcode, *dwell, strcantext, e
      else, pcan1, pbld, n, strcantext, e
      pcan2
prapid          #Output to NC of linear movement - rapid
      pncoutput
pzrapid         #Output to NC of linear movement - rapid Z only
      pncoutput
plin            #Output to NC of linear movement - feed
      pncoutput
pz              #Output to NC of linear movement - feed Z only
      pncoutput
pmx             #Output to NC of vector NCI
      pncoutput
pcir            #Output to NC of circular interpolation
      pncoutput
#Pre-process rotary motion control flags
pmx0            #5 axis gcode setup
      if drillcur = zero,
        if fr = -2, gcode = zero
        else, gcode = one
plin0           #Linear movement, mill motion test
      pmotion_su
pcir0           #Circular interpolation, mill arc motion test
      pmotion_su
# Motion output components
pbld            #Canned text - block delete
      if bld, '/'
pfbld           #Force - block delete
pccdia          #Cutter Compensation
      #Force Dxx#
      if prv_cc_pos <> cc_pos & cc_pos, prv_tloffno = c9k
      sccomp
      if cc_pos, tloffno
pfxout          #Force X axis output
      if absinc = zero, *xabs, !xinc
      else, *xinc, !xabs
pxout           #X output
      if absinc = zero, xabs, !xinc
      else, xinc, !xabs
pfyout          #Force Y axis output
      if absinc = zero, *yabs, !yinc
      else, *yinc, !yabs
pyout           #Y output
      if absinc = zero, yabs, !yinc
      else, yinc, !yabs
pfzout          #Force Z axis output
      if absinc = zero, *zabs, !zinc
      else, *zinc, !zabs
pzout           #Z output
      if absinc = zero, zabs, !zinc
      else, zinc, !zabs
pfcout          #Force C axis output
      if index = zero & rot_on_x,
        if absinc = zero, *cabs, !cinc
        else, *cinc, !cabs
pcout           #C axis output
        if absinc = zero, cabs, !cinc
        else, cinc, !cabs
pindex          #Index output
      if index & rot_on_x,
        if fmtrnd(prv_indx_out) <> fmtrnd(indx_out),
          pbld, n, `sindx_mc, indx_out, e
        !cabs, !cinc
parc            #Select the arc output
      if arcoutput = zero | full_arc_flg | arc_pitch,
        #Arc output for IJK
        # If you do NOT want to force out the I,J,K values,
        # remove the "*" asterisks on the *i, *j, *k 's below...
        if plane = zero, *i, *j, k  #XY plane code - G17
        if plane = one, i, *j, *k   #YZ plane code - G19
        if plane = two, *i, j, *k   #XZ plane code - G18
      else,
        #Arc output for R
        if abs(sweep)<=180 | arcoutput=one, result = nwadrs(srad, arcrad)
        else, result = nwadrs(srminus, arcrad)
        *arcrad
ppos_cax_lin    #Position the rotary axis before move - rapid
      if index, pindex
      else,
        if fmtrnd(prv_cabs) <> fmtrnd(cabs) & rot_on_x,
          sav_gcode = gcode
          gcode = zero
          if lock_codes = 1 & not(index), pbld, n, *sunlock, ";UNLOCK", e
          pbld, n, sgcode, pcout, e
          if lock_codes = 1 & not(index) & cuttype = 0, pbld, n, *slock, ";LOCK", e
          !cia
          ps_cinc_calc
          gcode = sav_gcode
# Drilling
pdrill0         #Pre-process before drill call
      sav_dgcode = gcode #Capture gcode for 5 axis drill
pdrlcommonb     #Canned Drill Cycle common call, before
      if sav_dgcode = 81,
        result = newfs (two, zinc)
        if drillcyc = three, drlgsel = fsg1(-ss) + drillcyc * two
        else, drlgsel = fsg2(dwell) + drillcyc * two
        if initht <> refht, drillref = zero
        else, drillref = one
        prv_refht_a = c9k
        prv_refht_i = c9k
        prv_dwell = zero
      if cuttype = three, sav_dgcode = gcode
      else, z = depth
      if cuttype = one, prv_zia = initht + (rotdia/two)
      else, prv_zia = refht  #Fanuc style - G91 Z depth from R level
      #else, prv_zia = initht  #G91 Z depth from initial height
      feed = fr_pos
      pcom_moveb
      comment
      pcan
      #5 axis must map the true Z, correct Z calculation here
      if cuttype = three,
        prv_zia = zabs + (-depth) + initht
        zia = fmtrnd(zabs)
        zinc = zia - prv_zia
      else, zinc = depth - refht
      result = nwadrs(stri, zabs)
      result = nwadrs(stri, zinc)
      dwell_out = dwell * 100
prdrlout        #R drill position
      if cuttype = one, refht_a = refht + (rotdia / two))
      else, refht_a = refht
      refht_i = refht - initht
      if cuttype = three, refht_a = w
      if absinc = zero, refht_a, !refht_i
      else, refht_i, !refht_a
pdrill          #Canned Drill Cycle
      pdrlcommonb
      pcan1, pbld, n, *sgdrill, *sgdrlref, pxout, pyout, prdrlout, pfzout, pcout,
        dwell_out, *feed, strcantext, e
      pcom_movea
ppeck           #Canned Peck Drill Cycle
      pdrlcommonb
      numpeck = abs((depth - refht)/peck1)
      if frac(numpeck)<>0, numpeck=numpeck+1
      numpeckint = int(numpeck)
      peck1 = (depth - refht)/numpeckint
      pcan1, pbld, n, *sgdrill, *sgdrlref, pxout, pyout, prdrlout, !zabs, !zinc, pcout,
        *peck1, *numpeckint, *feed, strcantext, e
      pcom_movea
pchpbrk         #Canned Chip Break Cycle
      if peck2 = 0, peck2 = 1
      if shftdrl = 0, shftdrl = 1
      bval = peck1
      dval = refht - zdrl
        *bval, *peckclr, *dval, *retr, *peck2, *shftdrl, dwell_out, *feed, strcantext, e
      pcom_movea
ptap            #Canned Tap Cycle
      pdrlcommonb
      #tool_typ = 4 - RH, 5 - LH
      feed = speed/n_tap_thds  #Override V8.1 parameter feed
        prigid, *feed, strcantext, e
      pcom_movea
      tapflg = 1
prigid          #Rigid Tap Cycle Toggle
      if peck1=1, "R1"
      else, "R0"
pbore1          #Canned Bore #1 Cycle
      pdrlcommonb
      pcom_movea
pbore2          #Canned Bore #2 Cycle
      pdrlcommonb
      pcom_movea
pmisc1          #Canned Misc #1 Cycle
      pdrlcommonb
      pcom_movea
pmisc2          #Canned Misc #2 Cycle (User Option)
      pdrill
pdrill_2        #Canned Drill Cycle, additional points
      pdrlcommonb
      pcan1, pbld, n, pxout, pyout, prdrlout, pzout, pcout, dwell_out,
        feed, strcantext, e
      pcom_movea
ppeck_2         #Canned Peck Drill Cycle
      pdrill_2
pchpbrk_2       #Canned Chip Break Cycle
      pdrill_2
ptap_2          #Canned Tap Cycle
      pdrill_2
pbore1_2        #Canned Bore #1 Cycle
      pdrill_2
pbore2_2        #Canned Bore #2 Cycle
      pdrill_2
pmisc1_2        #Canned Misc #1 Cycle
      pdrill_2
pmisc2_2        #Canned Misc #2 Cycle
      pdrill_2
pdrlcst         #Custom drill cycles 8 - 19 (user option)
      #Use this postblock to customize drilling cycles 8 - 19
      pdrlcommonb
      #if drillcyc = 8, pcan1, pbld, n, *sgdrlref, *sgdrill, pxout, pyout, pfzout, pcout,
      #  prdrlout, dwell, *feed, strcantext, e
      if drillcyc = 8,
        sub_prg_call = peck1
        pcan1, pbld, n, *sg00, *sgabsinc, pfxout, pfyout, strcantext, e
        spaces = 0
        pbld, n, pspc, "(", "CALL ", *sub_prg_call, ")", e
        spaces = sav_spc
      else, "CUSTOMIZABLE DRILL CYCLE ", pfxout, pfyout, pfzout, pfcout, e
      pcom_movea
pdrlcst_2       #Custom drill cycles 8 - 19, additional points (user option)
      pdrlcommonb
      #if drillcyc = 8, pcan1, pbld, n, pxout, pyout, pzout, pcout, prdrlout, dwell,
      #  feed, strcantext, e
      if drillcyc = 8,
        spaces = 0
        spaces = sav_spc
      pcom_movea
pcanceldc       #Cancel canned drill cycle
      result = newfs (three, zinc)
      z = initht
      pxyzcout
      !zabs, !zinc
      prv_gcode = zero
      pcan
      if drillcyc <> 8, pcan1, pbld, n, "G80", scoolant, strcantext, e
      if use_pitch & tapflg = 1, pbld, n, "G94", e
      pcan2
      tapflg = 0
#Subprogram postblocks
#sub_trnstyp - 0=mirror, 1=rotate, 2=scale, 3=translate
#sub_trnmthd (mirror) - 0=X axis, 1=Y axis, 2=line
#sub_trnmthd (rotate) - 0=tplane, 1=tplane origin only, 2=coordinates
psub_call_m     #Call to main level, single tool
      psub_call_trans
psub_call_mm    #Call to main level, multiple tools
      psub_call_trans
psub_call_trans #Translate level calls from toolchange, user
      if wcstype <= one, result = mprint(shomeserror)
      sav_absinc = absinc
      pindex
      #Mirror or Rotate Coord's
      if sub_trnstyp = zero | (sub_trnstyp = one & mr_rt_actv),
        #The original pattern is not mirrored or rotated
        if sub_sec_no,
          absinc = zero
          if sub_trnstyp, psub_rotate
          else, psub_mirror
        mr_rt_actv = three
      else, #Translate
        if sub_mny_t,
          pbld, n, pwcs, e
          pbld, n, *sgcode, *sgabsinc, pfxout, pfyout, pfzout,
            pfcout, e
          pe_inc_calc
          ps_inc_calc
      absinc = sav_absinc
      result = nwadrs(snull, main_prg_no)
      main_prg_no = main_prg_no + sav_progno #Add sub number offset
      if sav_progno = main_prg_no, result = mprint(sprgnerror)
      spaces = 0
      pbld, n, pspc, "(", "CALL ", *main_prg_no, ")", e
      spaces = sav_spc
      prv_feed = c9k #Force feed in sub
psub_mirror     #Mirror start code, user
      #Mirror Y axis
      if sub_trnmthd, pbld, n, *sgabsinc, strns_mir_on, *sub_trnsx, e
      #Mirror X axis
      else, pbld, n, *sgabsinc, strns_mir_on, *sub_trnsy, e
psub_rotate     #Rotate start code, user
      pbld, n, *sgcode, *sgabsinc, strns_rot_on, *sub_trnsx, *sub_trnsy,
        [absinc = one], *sgabsinc, *rt_cinc, e
psub_st_m       #Header in main level
      #sav_n1 = n
      #n = seqno
      " ", e
      spaces = 0
      #*main_prg_no, ",MX,", e
      "(SUB ", *main_prg_no, ")", e
      if scomm0 <> snull, ";", *scomm0, e
      spaces = sav_spc
      #G51/G68 requires absolute position on first move
      if mr_rt_actv & absinc = one,
        sav_absinc = absinc
        absinc = zero
        prv_absinc = m_one
        prv_xabs = m_one
        prv_yabs = m_one
      else, pbld, n, sgabsinc, e
psub_end_m      #End in main level
      "(RET)", e
      prv_absinc = -1
      #n = sav_n1
      #Reset update variables for subs at main level
      #Mirror or Rotate cancel, output is forced
      if (sub_trnstyp = zero & esub_sec_no > zero)
        | (sub_trnstyp = one & esub_sec_no = esub_totl_no-one
        & sub_trnmthd = two),
        subout = zero
        no_nc_out = m_one
        sav_absinc = absinc
        #Mirror cancel
        if sub_trnstyp = zero,
          absinc = zero
          pbld, n, *sgabsinc, strns_mir_off, *sub_trnsx, *sub_trnsy, e
        else, #Rotate cancel
          pbld, n, strns_rot_off, e
        absinc = sav_absinc
        no_nc_out = zero
      end_sub_mny = sub_mny_t
psub_end_mny    #End in main level for many tools sub, user
      #Check for coming out of xform with stage tool.
      if end_sub_mny & stagetool = one,
        *t
        end_sub_mny = zero
psub_call_s     #Call to sub level
      result = nwadrs(snull, sub_prg_no)
      sub_prg_no = sub_prg_no + sav_progno + 1000 #Add sub number offset
      if sav_progno = sub_prg_no, result = mprint(sprgnerror)
      spaces = 0
      pbld, n, pspc, "(", "CALL ", *sub_prg_no, ")", e
      spaces = sav_spc
psub_st_s       #Header in sub level
      #sav_n2 = n
      #n = seqno
      " ", e
      spaces = 0
      #*sub_prg_no, ",MX,", e
      "(SUB ", *sub_prg_no, ")", e
      spaces = sav_spc
psub_end_s      #End in sub level
      "(RET)", e
      prv_absinc = -1
      #n = sav_n2
# Canned Text
pcan            #Canned text - before output call
      strcantext = sblank
      if cant_no > zero,
        if cant_pos1 = zero, pcant_1
        if cant_pos2 = zero, pcant_2
        if cant_pos3 = zero, pcant_3
        if cant_pos4 = zero, pcant_4
        if cant_pos5 = zero, pcant_5
        if cant_pos6 = zero, pcant_6
        if cant_pos7 = zero, pcant_7
        if cant_pos8 = zero, pcant_8
        if cant_pos9 = zero, pcant_9
        if cant_pos10 = zero, pcant_10
        strcantext = sblank
pcan1           #Canned text - with move
      strcantext = sblank
      if cant_no > zero,
        if cant_pos1 = one, pcant_1
        if cant_pos2 = one, pcant_2
        if cant_pos3 = one, pcant_3
        if cant_pos4 = one, pcant_4
        if cant_pos5 = one, pcant_5
        if cant_pos6 = one, pcant_6
        if cant_pos7 = one, pcant_7
        if cant_pos8 = one, pcant_8
        if cant_pos9 = one, pcant_9
        if cant_pos10 = one, pcant_10
      if cstop, strcantext = strcantext + sm00
      if cgstop, strcantext = strcantext + sm01
      #Output of strcantext occurs at the end of the output line
pcan2           #Canned text - after output call
      strcantext = sblank
      if cant_no > zero,
        if cant_pos1 = two, pcant_1
        if cant_pos2 = two, pcant_2
        if cant_pos3 = two, pcant_3
        if cant_pos4 = two, pcant_4
        if cant_pos5 = two, pcant_5
        if cant_pos6 = two, pcant_6
        if cant_pos7 = two, pcant_7
        if cant_pos8 = two, pcant_8
        if cant_pos9 = two, pcant_9
        if cant_pos10 = two, pcant_10
        strcantext = sblank
pcant_1         #Canned text - output call
      cantext = cant_val1
      pcant_out
pcant_2         #Canned text - output call
      cantext = cant_val2
      pcant_out
pcant_3         #Canned text - output call
      cantext = cant_val3
      pcant_out
pcant_4         #Canned text - output call
      cantext = cant_val4
      pcant_out
pcant_5         #Canned text - output call
      cantext = cant_val5
      pcant_out
pcant_6         #Canned text - output call
      cantext = cant_val6
      pcant_out
pcant_7         #Canned text - output call
      cantext = cant_val7
      pcant_out
pcant_8         #Canned text - output call
      cantext = cant_val8
      pcant_out
pcant_9         #Canned text - output call
      cantext = cant_val9
      pcant_out
pcant_10        #Canned text - output call
      cantext = cant_val10
      pcant_out
pcant_out       #Canned text - build the string for output
      #Assign string select type outputs
      if cantext = three, bld = one
      if cantext = four, bld = zero
      #Build the cantext string
      if cantext = one, strcantext = strcantext + sm00
      if cantext = two, strcantext = strcantext + sm01
      if cantext > four,
        strtextno = no2str(cantext)
        strcantext = strcantext + strm + strtextno
# Position calculations, generally these do not need to be modified
pmiscint        #Capture the top level absinc for subprograms
      if sub_level <= zero, absinc = mi2
      #Disable cutpos2 if not 4 axis, saves time
      if rot_on_x = zero, cutpos2 = m_one
pusecannedyes # Use canned drilling cycles
             usecandrill = yes  # Use canned cycle for drill
             usecanpeck  = yes  # Use canned cycle for Peck
             usecanchip  = yes  # Use canned cycle for Chip Break
             usecantap   = yes  # Use canned cycle for Tap
             usecanbore1 = yes  # Use canned cycle for Bore1
             usecanbore2 = yes  # Use canned cycle for Bore2
             usecanmisc1 = yes  # Use canned cycle for Misc1
             usecanmisc2 = yes  # Use canned cycle for Misc2
pusecannedno # Use canned drilling cycles
             usecandrill = no   # Use canned cycle for drill
             usecanpeck  = no   # Use canned cycle for Peck
             usecanchip  = no   # Use canned cycle for Chip Break
             usecantap   = no   # Use canned cycle for Tap
             usecanbore1 = no   # Use canned cycle for Bore1
             usecanbore2 = no   # Use canned cycle for Bore2
             usecanmisc1 = no   # Use canned cycle for Misc1
             usecanmisc2 = no   # Use canned cycle for Misc2
pmotion_su      #Motion Setup (Set brklinestype & linarc)
      brklinestype = zero
      linarc = zero
      if rot_on_x,
        if cuttype = one, linarc = one  #Axis subs
        if cuttype = two, #Polar
          brklinestype = rotary_axis + three
          linarc = one
pcuttype   #Determine the cut type
      #cuttype (0 = Tool Plane, 1 = Axis Subs,  2 = Polar, 3 = 4/5 axis)
      cuttype = rotary_type
      if cuttype = three, cuttype = zero
      if mill5,
        if rot_on_x = zero, result = mprint(saxisoff)
        cuttype = three
      if rotary_axis,
        if rotary_axis <> rot_on_x, result = mprint(saxiswarn)
        rot_on_x = rotary_axis
      #Check for Tool Origin in Polar Milling
      if cuttype = two & (tox | toy | toz), result = mprint(stlorgerr)
      #Transform Rotate, set mr_rt_actv if user selected 'coordinates'
      if sub_trnstyp = one & sub_trnmthd = two,
        #Calculate the rotation incremental angle for G68
        rt_csav = atan2(sub_m2, sub_m1)
        rt_cinc = prv_rt_csav - rt_csav
        while rt_cinc > 180, rt_cinc = rt_cinc - 360
        while rt_cinc < -180, rt_cinc = rt_cinc + 360
        if rot_ccw_pos = one, rt_cinc = -rt_cinc
        !rt_csav
        if sub_sec_no, mr_rt_actv = two
        else, mr_rt_actv = one
      else, mr_rt_actv = zero
      pfcalc_u_min
      pmotion_su
pxyzcout        #Map coordinates
      if rot_on_x,
        if cuttype = zero, pxyzcout0    #Toolplane Positioning
        if cuttype = one, pxyzcout1     #Axis Substitution
        if cuttype = two, pxyzcout2     #Polar Conversion
        if cuttype = three, pxyzcout3   #Simulatneous 4 axis (Multi-axis)
        if rot_ccw_pos = one, csav = -csav
        if mr_rt_actv <> two,
          pcoutrev
          if index, pindxcalc
          pfcalc
        else, feed = fr_pos
      else,
        xabs = vequ (x)
        feed = fr_pos
      xabs = vequ (x)
      if cuttype = 2 & rot_on_x = two & vmc, c = atan2(vtoolx,-vtooly)
      if rot_on_x = two, csav = -c
      else, csav = c
pxyzcout1       #Axis substitution
      if rot_on_x = one, #X axis substitution
        xabs = x
        yabs = zero
        zabs = z + (rotdia / two)
        csav =  y * (360 / (pi * rotdia))
      else, #Y axis substitution
        xabs = zero
        yabs = y
        csav = -x * (360 / (pi * rotdia))
      if c <> 0,
        else, csav = c
pxyzcout2       #polar interpolation
      #Drill polar is toolplane drilling toward center
      #if not a coincident axis
      #Also, Capture initial index position for Polar Milling
      if (opcode = three & rot_on_x <> three), pxyzcout0
      else,
        if rot_on_x = one, #X axis rotation
          csav = atan2(y, z)   #Z+ zero
          axisx = vequ(aaxisx)
          xabs = rotp(csav, x)
        if rot_on_x = two, #Y axis rotation
          csav = atan2(-x, z)   #Z+ zero
          axisx = vequ(baxisx)
        if rot_on_x = three, #Z axis rotation
          csav = atan2(-y, x)   #X+ zero
          axisx = vequ(caxisx)
        csav = csav + c
pxyzcout3       #Multisurf rotary axis motion
      if rot_on_x = one, #Multisurf Rotary about X
        csav = atan2 (vtooly, vtoolz)
        axisx = vequ (aaxisx)
      if rot_on_x = two, #Multisurf Rotary about Y
        csav = atan2 (-vtoolx, vtoolz)
        axisx = vequ (baxisx)
      xabs = rotp (csav, x)
      u = rotp (csav, u)
      csav = csav + c
pcoutrev        #Rotary axis revolution calculation (Modify for wind-up)
      cdelta = -(csav - prv_csav)
      while abs(cdelta) > ctol, #If motion exceeds ctol, add wind-up
        if cdelta > zero,
          rev = rev - one
          cdelta = cdelta - 360
        else,
          rev = rev + one
          cdelta = cdelta + 360
      if cuttype <> one, cabs = rev * 360 + csav
      else, cabs = sav_rev * 360 + csav
      if (cuttype = zero | opcode = 3 | (gcode = 0 & cuttype <> one)) & one_rev = one,
        while fmtrnd(cabs) >= 360,
          cabs = cabs - 360
          rev = rev - 1
        while fmtrnd(cabs) < 0,
          cabs = cabs + 360
          rev = rev + 1
        #while fmtrnd(cabs) < -360,
        #  cabs = cabs + 720
        #  rev = rev + 2
        if abs(cdelta) >= 0.0005, prv_cabs = c9k
      !csav
pindxcalc       #Index move calculations, direction is shortest
      #Check if in tolerance
      cdelta = frac(abs(csav)/ctable)
      if cdelta > ixtol & cdelta < 1-ixtol,
        result = mprint(sindxerror)
      cdelta = prvcabs - cabs
      #Phase shift delta 10 revolutions, check odd/even
      if frac(int((cdelta + 3600)/180)/two), indx_mc = one
      else, indx_mc = zero
      #Set range 0-360
      indx_out = csav
      while indx_out < 0, indx_out = indx_out + 360
      while indx_out > 360, indx_out = indx_out - 360
#Feedrate calculations
pfcalc          #Feedrate calculations, gcode 0 does not evaluate
      if gcode <> zero,
        if abs(fmtrnd(cabs)-prvcabs) <= 0.001 | index | not(rot_feed) | opcode = 3, pfcalc_u_min
        else,
          #if cuttype = one & (cutpos2 <= one),  #Proposed change
          if cuttype = one & (cutpos2 <= one | cutpos2 = four & (opcode < 5 & opcode > 12)),
          pfcalc_u_min
          else, pfclc_deg_inv
        if ipr_type <> prv_ipr_type, prv_feed = c9k
pfcalc_u_min    #Feedrate unit/min
      ipr_type = zero
      feed = fr_pos
      if feed > maxfeedpm, feed = maxfeedpm
      prvfrdeg = feed
pfclc_deg_inv   #Feedrate deg/min
      circum = zabs * two * pi
      if circum = zero, circum = c9k          #Don't allow Zero
      ldelta = sqrt((xabs-prv_xabs)^2+(yabs-prv_yabs)^2+(zabs-prv_zabs)^2)
      cdelta = ((abs(cabs - prvcabs))/360)*circum
      if ldelta = zero, cldelta = cdelta
      else, cldelta = sqrt(cdelta^two + ldelta^two)
      if cldelta = zero, cldelta = c9k
      if use_frinv,
        #Feedrate inverse calculation
        ipr_type = two
        prv_feed = c9k #Always force feed
        frinv = fr_pos/cldelta
        if rot_feed & opcode <> 3,
          if frinv > maxfrinv, frinv = maxfrinv
          feed = frinv
      else,
        #Feedrate deg/min control and calculation
        ipr_type = zero  #Change to ipr_type = one to force new DPM
        frdeg = abs(cdelta/cldelta) * abs(fr_pos * (360/circum))
        if abs(frdeg - prvfrdeg) > frdegstp | ipr_type <> prv_ipr_type,
          #Control output of frdeg
            prvfrdeg = frdeg
            feed = frdeg
        if frdeg > maxfrdeg & rot_feed, feed = maxfrdeg
#Incremental calculations
ps_inc_calc     #Incremental calculations, start
      xia = fmtrnd(xabs)
      yia = fmtrnd(yabs)
      zia = fmtrnd(zabs)
      xinc = vsub (xia, prv_xia)
      ps_cinc_calc
ps_cinc_calc    #Incremental calculations, start rotary
      cia = fmtrnd(cabs)
      cinc = cia - prv_cia
pe_inc_calc     #Incremental calculations, end
      prvcabs = fmtrnd(cabs) #Avoid updating until called explicitly
      !xia, !yia, !zia, !cia
      !x, !y, !z
# Tooltable Output
pwrtt      # Write tool table, scans entire file, null tools are negative
           if rotaxis > 0 | rotary_type > 0 | mill5 <> 0,
             rot_on_x = sav_rot_on_x
             output_z = no
           #if vmc = 0 & tlplnno <> 2, rot_on_x = sav_rot_on_x
           #if vmc = 1 & tlplnno > 1, rot_on_x = sav_rot_on_x
           if tlplnno > 1, rot_on_x = sav_rot_on_x
           tlplnno = wbuf(3,wc3)  #Buffers out tool plane values
           t = wbuf(4,wc4)        #Buffers out tool number values
           if tool_table = 1, ptooltable
           if tool_table = 2, ppredtool
           if tool_table = 3, pmetatool
           if t >= zero, tcnt = tcnt + one
           ptravel
           pwritbuf5
ptooltable # Write tool table, scans entire file, null tools are negative
           tnote = t
           toffnote = tloffno
           tlngnote = tlngno
           spaces=0
           if t >= zero, ";", *t, ptspace, " : ", plistcomm, " : ", *tldia, punit, " : ", popnote
           #if t >= zero,
           #  if tcr>0, ";", *t, ptspace, " : ", plistcomm, " : ", *tlngno, phspace, " : ", *tloffno, pdspace, " : ", *tldia, punit, " : ", *tcr, " : ", popnote
           #  if tcr=0, ";", *t, ptspace, " : ", plistcomm, " : ", *tlngno, phspace, " : ", *tloffno, pdspace, " : ", *tldia, punit, " : ", "        : ", popnote
           #if t >= zero,
           #  if tcr>0, ";", *tnote, "  ", *toffnote, "  ", *tlngnote, "  ", *tldia, "  ", *tcr, "  ", popnote
           #  if tcr=0, ";", *tnote, "  ", *toffnote, "  ", *tlngnote, "  ", *tldia, "  ", popnote
           spaces=sav_spc
punit      # Tool unit
           if met_tool, "mm", pdiamspc
           else, 34, pdiamspc
ptravel    # Tool travel limit calculation
           if x_min < x_tmin, x_tmin = x_min
           if x_max > x_tmax, x_tmax = x_max
           if y_min < y_tmin, y_tmin = y_min
           if y_max > y_tmax, y_tmax = y_max
           if z_min < z_tmin, z_tmin = z_min
           if z_max > z_tmax, z_tmax = z_max
ppredtool  # Write tool setup info for Predator Virtual CNC
           #if tool_typ =  1, styp1    # CENTER DRILL     1 - NTG/S4
           #if tool_typ =  2, styp2    # SPOT DRILL       2 - S4
           #if tool_typ =  3, styp3    # DRILL            3 - S4
           #if tool_typ =  4, styp4    # TAP-RH           4 - S4 - MAX 179 ANGLE
           #if tool_typ =  5, styp5    # TAP-LH           5 - S4 - MAX 179 ANGLE
           #if tool_typ =  6, styp6    # REAMER           6 - S3/S1/S2
           #if tool_typ =  7, styp7    # BORING BAR       7 - S3/S1/S2
           #if tool_typ =  8, styp8    # COUNTER BORE     8 - NTG
           #if tool_typ =  9, styp9    # COUNTER SINK     9 - NTG/S4
           #if tool_typ = 10, styp10   # END MILL FLAT   10 - S1
           #if tool_typ = 11, styp11   # END MILL SPHERE 11 - S2
           #if tool_typ = 12, styp12   # CHAMFER MILL    12 - S7/NTG
           #if tool_typ = 13, styp13   # FACE MILL       13 - S7/S9/NTG
           #if tool_typ = 14, styp14   # SLOT MILL       14 - NTG/S1
           #if tool_typ = 15, styp15   # CORNER RAD MILL 15 - S5/FLAT
           #if tool_typ = 16, styp16   # DOVETAIL MILL   16 - DOVETAIL/NTG
           #if tool_typ = 17, styp17   # TAPER MILL      17 - S7/S9/S10
           #if tool_typ = 18, styp18   # LOLLIPOP MILL   18 - S6
           #if tool_typ = 19, styp19   # END MILL BULL   19 - S3
           tcr_pred = tcr
           tldia_pred = tldia
           tip_angle_ch = tip_angle*2
           spaces=0
           if t >= zero,
             # CENTER DRILL
             if tool_typ = 1, "(MTOOL ", *t, " ", *tldia_pred, " ", *tip_angle, " ", *flute_len, " S4)"
             # SPOT DRILL
             if tool_typ = 2, "(MTOOL ", *t, " ", *tldia_pred, " ", *tip_angle, " ", *flute_len, " S4)"
             # DRILL
             if tool_typ = 3, "(MTOOL ", *t, " ", *tldia_pred, " ", *tip_angle, " ", *flute_len, " S4)"
             # TAP-RH
             if tool_typ = 4,
               if tip_angle <= 179, "(MTOOL ", *t, " ", *tldia_pred, " ", *tip_angle, " ", *flute_len, " S4)"
               else, "(MTOOL ", *t, " ", *tldia_pred, " ", "A179.", " ", *flute_len, " S4)"
             # TAP-LH
             if tool_typ = 5,
             # REAMER
             if tool_typ = 6,
               if tcr = 0, "(MTOOL ", *t, " ", *tldia_pred, " ", *flute_len, " S1)"
               if tcr = tlrad, "(MTOOL ", *t, " ", *tldia_pred, " ", *flute_len, " S2)"
               if tcr > 0 & tcr < tlrad, "(MTOOL ", *t, " ", *tldia_pred, " ", *tcr_pred, " ", *flute_len, " S3)"
             # BORING BAR
             if tool_typ = 7,
             # COUNTER BORE
             if tool_typ = 8,
             # COUNTER SINK
             if tool_typ = 9, "(MTOOL ", *t, " ", *tldia_pred, " ", *tip_angle, " ", *flute_len, " S4)"
             # END MILL FLAT
             if tool_typ = 10, "(MTOOL ", *t, " ", *tldia_pred, " ", *flute_len, " S1)"
             # END MILL SPHERE
             if tool_typ = 11, "(MTOOL ", *t, " ", *tldia_pred, " ", *flute_len, " S2)"
             # CHAMFER MILL
             if tool_typ = 12, "(MTOOL ", *t, " ", *tldia_pred, " ", *tip_angle_ch, " ", *flute_len, " S7)"
             # FACE MILL
             if tool_typ = 13, "(MTOOL ", *t, " ", *tldia_pred, " ", *flute_len, " S1)"
             # SLOT MILL
             if tool_typ = 14, "(MTOOL ", *t, " ", *tldia_pred, " ", *flute_len, " S1)"
             # CORNER RAD MILL
             if tool_typ = 15,
               else, "(MTOOL ", *t, " ", *tldia_pred, " ", *tcr_pred, " ", *flute_len, " S5)"
             # DOVETAIL MILL
             if tool_typ = 16, "(MTOOL ", *t, " ", *tldia_pred, " ", *tip_angle, " ", *flute_len, " S8)"
             # TAPER MILL
             if tool_typ = 17,
               if tcr = 0, "(MTOOL ", *t, " ", *tldia_pred, " ", *tip_angle, " ", *flute_len, " S7)"
               if tcr = tlrad, "(MTOOL ", *t, " ", *tldia_pred, " ", *tip_angle, " ", *flute_len, " S9)"
               if tcr > 0 & tcr < tlrad, "(MTOOL ", *t, " ", *tldia_pred, " ", *tcr_pred, " ", *tip_angle, " ", *flute_len, " S10)"
             # LOLLIPOP MILL
             if tool_typ = 18, "(MTOOL ", *t, " ", *tldia_pred, " S6)"
             # END MILL BULL
             if tool_typ = 19, "(MTOOL ", *t, " ", *tldia_pred, " ", *tcr_pred, " ", *flute_len, " S3)"
           spaces=sav_spc
pmetatool  # Write tool setup info for MetaCut View
           tcr_meta = tcr
           if tool_typ = 13 | tool_typ = 17, tldia_meta = tldia + (2 *(flute_len * tan(tip_angle))
           else, tldia_meta = tldia
           if cctotip = 0, tipcomp = 1
           else, tipcomp = 0
           if tool_typ = 10 | opcode = 3, tipcomp = 0
           if tool_typ = 12, td_meta = tip_dia
           else, td_meta = 0
           if tool_typ = 13 | tool_typ = 17, td_meta = tldia
           flute_meta = flute_len
           oa_meta = oa_len
           ta_meta = tip_angle
           cd_meta = hldr_dia
           cl_meta = hldr_len
           sd_meta = cd_meta
           #(NWDTOOL NAME"1/2 CHAMFER MILL" T1 D.5 R0. F2. L3. A45. TD.06 CD2. CL1. SD2. C0)
           # N = "Tool name"
           # T = Tool No.
           # D = Tool Dia.
           # R = Corner Radius
           # F = Flute Length
           # L = Tool over all length
           # A = Tip angle or Taper angle
           # TD = Tip Dia.
           # CD = Colllet/Holder Dia.
           # CL = Collet/Holder Height
           # SD = Spindle Dia. (set equal to Collet Diameter)
           # C = tip or center 0 = tip 1 = center
           spaces=0
           if t >= zero, "(NWDTOOL N", 34, pmetacomm, 34, " ", *t, " ", *tldia_meta, " ",
                          [if tcr_meta > 0, *tcr_meta, " "], *flute_meta, " ", *oa_meta, " ",
                          [if ta_meta<>180, *ta_meta, " "], [if td_meta > 0, *td_meta, " "],
                          *cd_meta, " ", *cl_meta, " ", *sd_meta, " ", *tipcomp, ")"
           spaces=sav_spc
# Buffer 5  Read / Write Routines
pwritbuf5   # Write Buffer 1
            b5_gcode = gcode
            b5_zmin = z_min
            b5_zmax = z_max
            b5_gcode = wbuf(5, wc5)
preadbuf5   # Read Buffer 1
            size5 = rbuf(5,0)
            b5_gcode = 1000
            min_depth = 99999
            max_depth = -99999
            while rc5 <= size5 & b5_gcode = 1000,
              if rc5 <= size5, b5_gcode = rbuf(5,rc5)
              if b5_zmin < min_depth, min_depth = b5_zmin
              if b5_zmax > max_depth, max_depth = b5_zmax
# Numbered questions for Mastercam
38. Rapid feedrate? 300.0
1538. Rapid feedrate (metric)? 10000.0
#76. Configuration file name?
80. Communications port number for receive and transmit (1 or 2) ? 2
81. Data rate (110,150,300,600,1200,2400,4800,9600,14400,19200,38400)? 9600
82. Parity (E/O/N)? E
83. Data bits (7 or 8)? 7
84. Stop bits (1 or 2)? 2
85. Strip line feeds? N
86. Delay after end of line (seconds)? 0
87. Ascii, Eia, or Binary (A/E/B)? A
88. Echo keyboard to screen in terminal emulation? n
89. Strip carriage returns? N
90. Drive and subdirectory for NC files?
91. Name of executable post processor? MP
92. Name of reverse post processor? RP
93. Reverse post PST file name? RPFAN
100. Number of places BEFORE the decimal point for sequence numbers? 0
101. Number of places AFTER the decimal point for sequence numbers? 0
103. Maximum spindle speed? 10000
107. Average time for tool change (seconds)? 2.0
161. Enable Home Position button? y
162. Enable Reference Point button? y
163. Enable Misc. Values button? y
164. Enable Rotary Axis button? y
165. Enable Tool Plane button? y
166. Enable Construction Plane button? y
167. Enable Tool Display button? y
168. Check tplane during automatic work origin creation? y
# Default Miscellaneous Real Values
201. Default miscellaneous real variable 1 (mr1)? 0.0
202. Default miscellaneous real variable 2 (mr2)? 0.0
203. Default miscellaneous real variable 3 (mr3)? 0.0
204. Default miscellaneous real variable 4 (mr4)? 0.0
205. Default miscellaneous real variable 5 (mr5)? 0.0
206. Default miscellaneous real variable 6 (mr6)? 0.0
207. Default miscellaneous real variable 7 (mr7)? 0.0
208. Default miscellaneous real variable 8 (mr8)? 0.0
209. Default miscellaneous real variable 9 (mr9)? 0.0
210. Default miscellaneous real variable 10 (mr10)? 0.0
# Default Miscellaneous Real Values (METRIC)
1601. Default miscellaneous real variable 1 (mr1) (metric)? 0.0
1602. Default miscellaneous real variable 2 (mr2) (metric)? 0.0
1603. Default miscellaneous real variable 3 (mr3) (metric)? 0.0
1604. Default miscellaneous real variable 4 (mr4) (metric)? 0.0
1605. Default miscellaneous real variable 5 (mr5) (metric)? 0.0
1606. Default miscellaneous real variable 6 (mr6) (metric)? 0.0
1607. Default miscellaneous real variable 7 (mr7) (metric)? 0.0
1608. Default miscellaneous real variable 8 (mr8) (metric)? 0.0
1609. Default miscellaneous real variable 9 (mr9) (metric)? 0.0
1610. Default miscellaneous real variable 10 (mr10) (metric)? 0.0
# Enable/Disable Miscellaneous Real Variable switches
1611. Enable miscellaneous real variable 1? y
1612. Enable miscellaneous real variable 2? y
1613. Enable miscellaneous real variable 3? y
1614. Enable miscellaneous real variable 4? y
1615. Enable miscellaneous real variable 5? y
1616. Enable miscellaneous real variable 6? y
1617. Enable miscellaneous real variable 7? y
1618. Enable miscellaneous real variable 8? y
1619. Enable miscellaneous real variable 9? y
1620. Enable miscellaneous real variable 10? y
# Default Miscellaneous Integer Values
301. Miscellaneous integer variable 1 (mi1)? 0
302. Absolute or Incremental [0=ABS,1=INC] (mi2)? 0
303. Miscellaneous integer variable 3 (mi3)? 0
304. Miscellaneous integer variable 4 (mi4)? 0
305. Miscellaneous integer variable 5 (mi5)? 0
306. Miscellaneous integer variable 6 (mi6)? 0
307. Miscellaneous integer variable 7 (mi7)? 0
308. Miscellaneous integer variable 8 (mi8)? 0
309. Lock on First WCS [0=No,1=Yes] (mi9)? 0
310. M00 before operation [0=No,1=Yes] (mi10)? 0
# Enable/Disable Miscellaneous Integer Variable switches
1621. Enable miscellaneous integer variable 1? y
1622. Enable miscellaneous integer variable 2? y
1623. Enable miscellaneous integer variable 3? y
1624. Enable miscellaneous integer variable 4? y
1625. Enable miscellaneous integer variable 5? y
1626. Enable miscellaneous integer variable 6? y
1627. Enable miscellaneous integer variable 7? y
1628. Enable miscellaneous integer variable 8? y
1629. Enable miscellaneous integer variable 9? y
1630. Enable miscellaneous integer variable 10? y
# Configuration File association parameters (default is "y")
#400. Name of associated cfg file?
401. Read SYSTEM COLORS section? y
402. Read ALLOCATIONS section? y
403. Read TOLERANCES section? y
404. Read DATA PATHS section? y
405. Read COMMUNICATIONS section? y
406. Read DRAFT SETTINGS section? y
407. Read MISCELLANEOUS section? y
408. Read NC SETTINGS section? y
409. Read DIALOG SCRIPTS section? y
410. Read DESIGN SETTINGS section? y
411. Read PLOTTER SETTINGS section? y
412. Read ALT-KEY ASSIGNMENTS section? y
413. Read CAD section? y
414. Read START/EXIT section? y
415. Read SCREEN section? y
416. Read FILE NAMES section? y
1500. Chook to execute from 'Misc. values' button?
1501. Insert parameter information in the ascii NCI? n
1502. Write operation information to binary file (.ops)? y
1520. Display a warning when cutter compensation in control simulation finds an error? n
# Do NOT manually change the answer for Q.1999 !
1999. Product major version number that post supports? 9
3001. Machine acceleration? 2
3002. timing size? .1
Old 05-02-2006, 08:19 PM
Alex_Cole's Avatar
Alex_Cole is on a distinguished road
I sent you a pm
Old 07-16-2008, 10:38 AM
felmulo120 is on a distinguished road
i have the same problem with my machine so i modified the post i can send you a copy i took of the line giving the problem also the g54 added a look ahead g51 a255 e0.05 buffer becuase i do a lot of 3d machining and removed the go home command at the end
Old 07-16-2008, 10:42 AM
heres the post for fagor 8055m its renamed felipe
Old 07-16-2008, 12:57 PM
cam1 is on a distinguished road
Here's mine, works great.
regards
Can't Fix Stupid
  #11   Ban this user!
Old 09-03-2009, 10:43 AM
NIKEIME is on a distinguished road
Hi there!
I'm working with mastercam v8 and his post doesn't work well with the drill cycles in fagor 8055 M. Could you help me to change my post or could you give me another one that works well with drill cycles. Thanks!
  #12   Ban this user!
Old 07-20-2010, 09:20 AM
salchez is on a distinguished road
Help editing only one line in post
regards
I have edited this post hoping to get it work with my machine with Fagor 8055 controller, but I have one problem, because I don't know how and where to add a line in a post to get "start clearance" at the beginning of the NC code (see line N160 in 1000.pim). See atachments:
  • 1000.pim shows how posted NC should look like
  • 1009.pim is the NC which is posted with this modified post
  • FAGOR_8055.pst is edited post which still needs editing
So as you noticed I only need a line N160 (in 1000.pim) to be posted with this post. If someone will please help me with this one or at least point me in the right direction! Thank you!
