| Help with adding subprograms to post processor I'm want to add subprograms to my post processor. As the supplied post didn't support subprograms, I've started to change the standard MPFAN post to suit. This has worked very well so far but I'm having to move the subprograms from the end of the G code program upto the start of the program manualy. I would really like to change this to it automaticly in the post. Any help would be greatly appriated Cheers Chris |
| Update I think I've found the code that puts the subprograms in, well if I move MERGEAUX up a couple of lines i.e. above line n, "M02", e. Then the subprograms are placed above the line containing M02 but when moving MERGEAUX so it is just below the program no. i.e. below line *progno, e. The subprograms dissapear totaly. Thanks Chris |
| Still can't do it. Someone help please even if you just tell me it is not possible. Cheers Chris |
| Hi Chris, for sure that is possible. Mastercam has a great handling with subprogs. But in order to define them into your post, it´s very complicated. It depends on a lot of variables and settings inside the post. The answer for you question is not so simple, not even short. but yes, is possible to get subprogs in Mastercam (And they works perfectly when proper configured in the post), but is complicated to define them also. Get in touch with your dealer and ask for him about the MP Guide, available in CD-ROM. Cheers
__________________ Kind Regards Daniel - Camfun |
| Thanks for the reply, I'll look out for the CD. Just thought someone would be using subprograms on a brigdeport with there very limited memory and there been so many of them around. Cheers Chris |
| I have a post but it's for a fanuc if you like I can e-mail it to and maybe you could get an idea of how they are used and edit your own pp I have mine just the the way i like it.. just pm me and i'll e-mail it to you. here is a sample of how it posts. O0015(ITEM 1 -OP2 WHAT HAPPEN FIXTURE.NC) (DATE= 16-03-06 TIME=17:29) (DRILL) ( 1/4 SPOTDRILL TOOL - 1 DIA. OFF. - 31 LEN. - 1 DIA. - .25) N1G0G40G49G80G90Z0 M107 T1M6 G54X-.3001Y-3.4943S6000M3 M8 G43H1Z.2M8 M98P0001 (DRILL) G90G55X-.3001Y-3.4943 Z.2 M98P0001 (DRILL) G90G56X-.3001Y-3.4943 Z.2 M98P0001 G90G54X.21Y-2.745 Z.2 M98P0002 G90G55X.21Y-2.745 Z.2 M98P0002 G90G56X.21Y-2.745 Z.2 M98P0002 G0Z1.M9 G49Z0M5 G28G91Y0 M01 (10-32 PILOT HOLES) ( #21 DRILL TOOL - 2 DIA. OFF. - 32 LEN. - 2 DIA. - .159) N2G0G40G49G80G90Z0 M107 T2M6 G54X-.3001Y-3.4943S3000M3 M8 G43H2Z.2 M98P0003 (10-32 PILOT HOLES) G90G55X-.3001Y-3.4943 Z.2 M98P0003 (10-32 PILOT HOLES) G90G56X-.3001Y-3.4943 Z.2 M98P0003 G0Z1.M9 G49Z0M5 G28G91Y0 M01 (6-32 PILOT HOLES) ( #36 DRILL TOOL - 3 DIA. OFF. - 33 LEN. - 3 DIA. - .1065) N3G0G40G49G80G90Z0 M107 T3M6 G54X.21Y-2.745S6000M3 M8 G43H3Z.2 M98P0004 (6-32 PILOT HOLES) G90G55X.21Y-2.745 Z.2 M98P0004 (6-32 PILOT HOLES) G90G56X.21Y-2.745 Z.2 M98P0004 G0Z1.M9 G49Z0M5 G28G91Y0 M01 (10-32 PILOT HOLES TAP) ( #10-32 TAPRH TOOL - 4 DIA. OFF. - 34 LEN. - 4 DIA. - .19) N4G0G40G49G80G90Z0 M107 T4M6 G54X-.3001Y-3.4943S1000M3 M8 G43H4Z.2 M98P0005 (10-32 PILOT HOLES TAP) G90G55X-.3001Y-3.4943 Z.2 M98P0005 (10-32 PILOT HOLES TAP) G90G56X-.3001Y-3.4943 Z.2 M98P0005 G0Z1.M9 G49Z0M5 G28G91Y0 M01 (6-32 PILOT HOLES) ( #6-32 TAPRH TOOL - 5 DIA. OFF. - 35 LEN. - 5 DIA. - .138) N5G0G40G49G80G90Z0 M107 T5M6 G54X.21Y-2.745S1000M3 M8 G43H5Z.2 M98P0006 (6-32 PILOT HOLES) G90G55X.21Y-2.745 Z.2 M98P0006 (6-32 PILOT HOLES) G90G56X.21Y-2.745 Z.2 M98P0006 G0Z1.M9 G49Z0M5 G28G91Y0 M30 O0001 G81G98Z-.1R.1F20. Y.0857 X5.2799 Y-3.4943 G80 M99 O0002 G81G98Z-.07R.1F20. Y-.62 X4.82 Y-2.745 G80 M99 O0003 G83G98Z-.6R.1Q.1F15. Y.0857 X5.2799 Y-3.4943 G80 M99 O0004 G83G98Z-.6R.1Q.1F18. Y-.62 X4.82 Y-2.745 G80 M99 O0005 G84G98Z-.5R.15F31.25 Y.0857 X5.2799 Y-3.4943 G80 M99 O0006 G84G98Z-.5R.15F31.25 Y-.62 X4.82 Y-2.745 G80 M99 % |
| It would be easier to start with a post that already supports subprograms. Then modify it to suit your machine and controller. I'm pretty sure the Fadal post supports subprograms as you describe them.
__________________ ObrienDave. MasterCam since V6. Gcode since 1983. Be careful, the nose you punch today may belong to the butt you have to kiss tomorrow. |
| If your using a current MPFan (V9 & up) it already supports subs. It's all in what you pick on the Parameter page, when your doing your toolpath. Contour: Pick Depth Cuts and check the Subs box. If your doing a toolpath Transformation. Same thing. Look for the Subs check box. You shouldn't have to modify the post to get subs. You might need to modify it for a particular format, but it should be there already. Mike Mattera
__________________ Tips For Manufacturing Training CD's, DVD's for Mastercam, SolidWorks, Inventor, G-Code Training & More http://www.tipsforcadcam.com |
| Thanks for the comments even though most of you got the wrong end off the stick, I do still appreciate the help. A big thanks to ObrienDave thats exactly what I was after, I just copied loads of that post into mine not really sure which bit made it work but it does so I'm happy. This is what I wanted to get (simple program milling a square a few times for a example) #1 N112X50. N114Y0. N116X0. N118Y50. $ N100G71G17 N102G0G90T1M6S1909 N104X0.Y50. N106Z50. N108Z2. N110G1Z-2.F382 =#1 N120G90Z-4. =#1 N130G90Z-6. =#1 N140G90Z-8. =#1 N150G90Z-10. =#1 N160G0G90Z50. N162M02 What I was getting before which doesn't work N100G71G17 N102G0G90T1M6S1909 N104X0.Y50. N106Z50. N108Z2. N110G1Z-2.F382 =#1 N120G90Z-4. =#1 N130G90Z-6. =#1 N140G90Z-8. =#1 N150G90Z-10. =#1 N160G0G90Z50. N162M02 #1 N112X50. N114Y0. N116X0. N118Y50. $ And last but not least the original Post version .N100G70G75G90 N102G0X0.Y0.T1M6 N104X0.Y50. N106Z50. N108Z2. N110G1Z-2.F3818 N112X50. N114Y0. N116X0. N118Y50. N120G0Z-4. N122X50. N124Y0. N126X0. N128Y50. N130G0Z-6. N132X50. N134Y0. N136X0. N138Y50. N140G0Z-8. N142X50. N144Y0. N146X0. N148Y50. N150G0Z-10. N152X50. N154Y0. N156X0. N158Y50. N160G0Z50. N162G0Y0.M2 |
#10
| Sub-programs for lathe Has anyone used sub-programs to send the machine to it's index position? I want to program a vtl where I can use different subprograms for the index position for different jobs. What is the format like and how does it work? Thanks. |
