Results 1 to 4 of 4
Thread: 9.1 post
    Jan 2007
    9.1 post
    We have a2002 haas vf3 we are trying to do a 4axis program for.The post does not index to the next feature,It just wants to do all the work on the same side.Any help would be greatly appreciated.
    Attached Files Attached Files
    May 2004
    Might not be the post. Are you assigning a new work plane with a new work offset number for each side?
    http://www.kirkcon.com/
    Registered Superman's Avatar
    Dec 2008
    Krypton
    Have you set-up the CNC-machine to have a 4th axis ? ( Version X or later )
    the machine is a vertical, so, is the 4th axis around the X-axis ?
    Are you using the same WCS for each of the toolpath operations for that set-up ( & altering the T/C planes only ) ?
    ( ie working on a vertical :-
    -top face machining, then WCS=TOP, T/C plane=TOP ----this outputs A0
    -front face machining, then WCS=TOP,T/C planes=FRONT ----this outputs A-90 )
    -----the WCS view maintains the setup as being A0, the T/C planes allow Mcam to output the angles from the WCS
    BACK & BOTTOM views are not machining views but for drafting only (rotated 180°), you will need to re-define those views correctly as seen by the tool, looking down at the table, to get the A90 & A180 to output correctly.
    HORIZONTALS are very different, your main face to be machined must be on the FRONT view
    -front face machining, then WCS=TOP, T/C plane=FRONT ----this outputs B0
    -right face machining, then WCS=TOP,T/C planes=RIGHT ----this outputs B90
    -back face machining, then WCS=TOP,T/C planes=BACK ----this outputs B180
    -left face machining, then WCS=TOP,T/C planes=LEFT ----this outputs B270
    Jan 2007
    Thanks I will check all that out.I am sure I missed somethong there.Thanks again
  1. Special post for presentation! Laser manufacturers/dealers post their contacts here!
    By Litografa in forum General Laser Engraving & Cutting Machine Discussion
    Last Post: 06-22-2010, 02:23 PM
  2. Replies: 0
    Last Post: 10-26-2006, 05:59 PM
