[POST_VERSION] #DO NOT MOVE OR ALTER THIS LINE# V14.00 E1 P0 T1335330324 M14.00 I0
# Post Name : MPHEID
# Product : MILL
# Machine Name : HEIDENHAIN
# Control Name : HEIDENHAIN
# Description : GENERIC HEIDENHAIN 3 AXIS POST
# Associated Post : NONE
# Mill/Turn : NO
# 4-axis/Axis subs. : NO
# 5-axis : NO
# Subprograms : NO
# Executable : MP 9.0
# WARNING: THIS POST IS GENERIC AND IS INTENDED FOR MODIFICATION TO
# THE MACHINE TOOL REQUIREMENTS AND PERSONAL PREFERENCE.
#| REVISION LOG |
# Programmers Note:
CNC 01/12/01 - Initial post update for V8.1, grt
CNC 01/09/02 - Initial post update for V9.0, rjm
#| FEATURES: |
# Users Note:
# Following Misc_Reals & Misc_Integers are used:
# Options / Usage
#Canned text:
# Entering cantext on a contour point from within Mastercam allows the
# following functions to enable/disable.
# Cantext value:
# 1 = Stop = output the "M00" stop code
# 2 = Ostop = output the "M01" optional stop code
# Format Statements - i=incr, n=nonmodal, l=leave ldg, t=leave trlg, d=delta
fs 1 +1^4
fs 2 +1^4n
fs 3 3 0
fs 4 2 0n
fs 5 4 1t
fs 6 2 0ln
fs 7 3 0ln
fs 8 4 0n
fs 9 1.4
fs 10 1.4ln
fs 11 +1.3ln
fs 12 4 0ln
# Format Assignments
# Axis output formats - Linear
fmt X 1 x$ # X Axis Position
fmt Y 1 y$ # Y Axis Position
fmt Z 1 z$ # Z Axis Position
fmt X 1 xr$ # X Rapid Position
fmt Y 1 yr$ # Y Rapid Position
fmt Z 1 zr$ # Z Rapid Position
fmt X 1 xh$ # X Home Position
fmt Y 1 yh$ # Y Home Position
fmt Z 1 zh$ # Z Home Position
# Axis output formats - Circular
fmt X 1 i$ # Arc center description in X
fmt Y 1 j$ # Arc center description in Y
fmt Z 1 k$ # Arc center description in Z
fmt X 10 xc$ # Arc Center X
fmt Y 10 yc$ # Arc Center Y
fmt R 9 arcrad$ # Arc Radius
fmt 1 sweep$ # Angle between start and end of arc
# Program & Sequence number format
fmt 8 progno$ # Program number
fmt 4 seqno$ # Starting Sequence Number
fmt 4 seqinc$ # Sequence Number Increment
fmt 4 n$ # Main Program Sequence Numbers
# Tool format
fmt 4 t$ # Tool Number
fmt R 2 tldia$ # Tool Diameter
fmt R 2 tlrad$ # Tool Radius
fmt 9 trflat$ # Tool Flat Rad.
fmt 9 tcr$ # Tool Corner Rad
fmt D 4 tloffno$ # Diameter Offset Number
fmt L 2 tlngno$ # Length Offset Number
fmt 1 tlplnno$ # Tool Plane Number.
# Spindle Speeds & Feedrate output formats
fmt S 4 ss$ # Spindle Speed
fmt 4 spprev # Hold previous selspin value for spin change
fmt 4 cc_sav # Hold previous cc_pos value for comp change
fmt 8 selspin # Spindle Dir
fmt 5 fr$ # Feedrate
fmt 5 fr2 # Feedrate 2
fmt 5 frrapid # Rapid
fmt 4 dirchg$ # Feerate Accel/Decel Flag
# Miscellaneous output formats
fmt 4 gcode$ # Format linear G-code selector for modality only
fmt 4 coolant$ # Format coolant M-code selector for modality only
fmt M 6 cantext$ # Canned text output variable
# Drill variable formats
fmt 1 drillcyc$ # drillcyc = 0..7
fmt 1 drillcur$ # Drill with current cycle flag (=1 if true)
fmt G 4 drillref # Initial / Reference Toggle (G98/G99)
fmt 10 dwell$ # Dwell
fmt Z 10 initht$ # Initial Height
fmt Z 10 refht$ # Reference Height
fmt 10 depth$ # Depth
fmt 10 peck1$ # First peck increment (negative)
fmt 10 peck2$ # Second or last peck (negative)
fmt 10 setup # Safety Distance (-initht)
fmt 10 peckg # Feed Depth (peck1)
fmt 2 peckclr$ # Safety distance
fmt 1 retr$ # Retract height
fmt F 5 frplunge$ # Plunge feedrate in drill cycles
# Formulas - Use ':' instead of '=' to initialize variables
m_one : -1 # Define Constant
zero : 0 # Define Constant
one : 1 # Define Constant
two : 2 # Define Constant
three : 3 # Define Constant
c9k : 9999 # Define Constant
tooltable$ : yes$ # Output tool table?
spaces$ : yes$ # Number of spaces to add between fields
nobrk$ : no$ # omit breakup of x/y & z rapid moves
omitcrlf$ : no$ # Omit CR/LF- Used for floppy output of - .NC files
omitrefht : no$ # Don't use reference height on first non-canned Z move
seqmax$ : 9999 # Max. sequence number
omitseq$ : no$ # Omit sequence numbers?
frrapid : 800 # Rapid feedrate? 800.0
frmax : 800 # Maximum feedrate? 800.0
ssmax : 6000 # Maximum spindle speed? 6000
breakarcs$ : 0 # Break arcs, 0 = no, 1 = quadrants, 2 = 180deg. max arcs
arctype$ : 2 # Arc center 1=abs, 2=St-Ctr, 3=Ctr-St, 4=unsigned inc.
do_full_arc$ : 0 # Allow full circle output? 0=no, 1=yes
helix_arc$ : 0 # Support helix arc output, 0=no, 1=all planes, 2=XY plane only
ncldr$ : 20 # Number of leader characters
ldrcode$ : 65 # Leader character dec. equiv.
drlgsel : m_one # Drill Select Initialize
spprev : m_one # Initial value for last spindle state
#Cantext string definitions (spaces must be padded here)
sm00 : "M00"
sm01 : "M01"
strm : "M"
strtextno : ""
strcantext : ""
sblank : ""
# USE CANNED CYCLES?
usecandrill$ : yes$ # Use canned cycle for Drill
usecanpeck$ : yes$ # Use canned cycle for Peck
usecanchip$ : yes$ # Use canned cycle for Chip Break
usecantap$ : yes$ # Use canned cycle for Tap
usecanbore1$ : yes$ # Use canned cycle for Bore1
usecanbore2$ : yes$ # Use canned cycle for Bore2
usecanmisc1$ : yes$ # Use canned cycle for Misc1
usecanmisc2$ : yes$ # Use canned cycle for Misc2
# DEBUG - Switches for debugging purposes
fastmode$ : yes$ # Enable Quick Post Processing, (set to no for debug)
bug1$ : 2 # 0=No display, 1=Generic list box, 2=Editor
bug2$ : 30 # Add postline label to each line at column 'bug2' at ? Columns
bug3$ : 0 # Add whatline to each line? yes/no
bug4$ : 1 # Add -.nci line no. to each line? yes/no
whatno$ : yes$ # Ignore whatline branches to plin1 etc.?
linktolvar$ : 1 #Associate X tolerance variables to V9- variable?
linkplnvar$ : 1 #Associate X plane specific variables to V9- variable?
cant_tlchng$ : 1 #Ignore cantext entry on move with tlchng_aft?
newglobal$ : 0 #Enable error checking for global variables?
strtool_v7$ : 2 # Use Version 7 toolname, 1= path components, 2=string
get_1004$ : 1 # Find gcode 1004 with getnextop?
rpd_typ_v7$ : 1 # Use Version 7 style contour flags?
tlchng_aft$ : no$ #
# Strings - String labels must start with 's' - they are not pre-assigned
sdef : "CYCL DEF" #String Constants
specking : "1.0 PECKING"
stapping : "2.0 TAPPING"
ssetup : "SET UP "
sdepth : "DEPTH "
speckg : "PECKG "
sdwell : "DWELL "
stoolcall : "TOOL CALL "
sbeginpgm : "BEGIN PGM "
sendpgm : "END PGM "
sinch : "MM"
smax : "MAX"
strc : "C"
strcc : "CC"
strf : "F"
strl : "L"
strr : "R"
strr0 : "R0"
sm99 : "M99"
strz : "Z"
sg00 : "L" # Linear movement at rapid feedrate G code
sg01 : "L" # Linear movement at feedrate G code
sg02 : "DR-" # Circular interpolation CW G code
sg03 : "DR+" # Circular interpolation CCW G code
sgcode : "" # Target string for linear/circular motion G code
fstrsel sg00 gcode$ sgcode 4 -1# Select motion G code string
sm09 : "M9" # Coolant off
sm08f : "M8" # Coolant on
sm08m : "M8" # Coolant on
sm08t : "M8" # Coolant on
smcool : "" # Coolant code target string
fstrsel sm09 coolant$ smcool 4 -1# Boolean handles modality
sg40 : "R0" # cancel cutter compensation
sg41 : "RL" # cutter compensation left
sg42 : "RR" # cutter compensation right
sccomp : "" # Select cutter compensation
fstrsel sg40 cc_pos$ sccomp 3 -1
# Misc. Postline labels
pinit # Initialize Vars
prv_fr$ = c9k
prv_fr2 = c9k
prv_frplunge$ = c9k
prv_coolant$ = zero
if opcode$ = three, prv_z$ = initht$
progno$ = prv_progno$
pcomment$ # Manual Entry - COMMENTS (on a block by itself) 1005,1006
n$, strl, ";", scomm$,e$
pcc # cutter comp
if cc_sav <> cc_pos$, *sccomp
else, strr
cc_sav = cc_pos$
pspdl # spindle and coolant state
selspin = fsg2(coolant$) * three + fsg3(ss$)
if spprev <> selspin, "M03" # M03 = spindle on, coolant on
if spprev = selspin, pchk_cool
spprev = selspin
pchk_cool # Output coolant as needed
if coolant$ <> prv_coolant$, smcool
else, strm
pfr # Feedrate
if fr$ >= zero, fr2 = fr$
if gcode$ = zero, fr2 = zero
if fr2 > zero, strf, fr2
if fr2 = zero, strf, smax
psg00 # Output "G00" via String Select Function to maintain modality
gcode$ = zero
*sgcode
# Postline - pre-assigned
# Start / End Tool
pheader$ # File header
n$, sbeginpgm, sprogname$, sinch,e$
psof0$ # Start of file for tool zero 1001
psof$
psof$ # Start of file for non-zero tool number 1001
pcan
n$, stoolcall, t$, strz, *ss$,e$
n$, strl, strr, strf, "M06",e$
n$, strl, pcc, strf, smax, strm,e$
pcan1, n$, strl, pcc, strf, smax, pspdl, strcantext, e$
if opcode$ <> three, n$, strl, pcc, strf, smax, strm,e$
pcan2
pinit
ptlchg0$ # Null tool change 1000
if prv_ss$ <> ss$, n$, stoolcall, t$, strz, *ss$,e$
pcan
ptlchg$ # Tool change 1002
pcan
if opcode$ <> three, n$, strl, pcc, strf, smax, "M03", strm,e$
pcan2
pinit
peof0$ # End of file for tool zero 1003
peof$
peof$ # End of file for non-zero tool 1003
n$, strl, strr, strf, "M25",e$
n$, sendpgm, sprogname$, sinch,e$
17,e$
# Motion Output
prapid$ # Linear line movement - at rapid feedrate 0
pcan
pcan1, n$, sgcode, x$, y$, z$, pcc, pfr, pspdl, strcantext, e$
pcan2
pzrapid$ # Linear movement in Z axis only - at rapid feedrate 0
n$, sgcode, z$, pcc, pfr, pspdl,e$
plin$ # Linear line movement - at feedrate 1
pcan
pcan2
pz$ # Linear movement in Z axis only - at feedrate 1
pcir$ # Circular interpolation 2
pcan
n$, strcc, xc$, yc$, e$
pcan1, n$, strc, x$, y$, z$, *sgcode, pcc, pfr, pspdl, strcantext, e$
pcan2
# Drilling Section
pdrill_calc # Drilling Calculations
setup = abs(refht$) * m_one
peckg = abs(peck1$) * m_one
pdrill$ # Canned Drill Cycle
pdrill_calc
n$, sdef, specking,e$
n$, sdef, "1.1", ssetup, setup,e$
n$, sdef, "1.2", sdepth, depth$,e$
n$, sdef, "1.3", speckg, peckg,e$
n$, sdef, "1.4", sdwell, dwell$,e$
n$, sdef, "1.5", strf, *fr$,e$
n$, strl, *initht$, strr, strf, smax, strm,e$
n$, strl, *refht$, strr, strf, smax, smcool,e$
n$, strl, *refht$, strr, strf, smax, sm99,e$
ppeck$ # Canned Peck Drill Cycle
pdrill$
pchpbrk$ # Canned Chip Break Cycle
pdrill$
ptap$ # Canned Tap Cycle
pdrill_calc
n$, sdef, stapping,e$
n$, sdef, "2.1", ssetup, setup,e$
n$, sdef, "2.2", sdepth, depth$,e$
n$, sdef, "2.3", sdwell, dwell$,e$
n$, sdef, "2.4", strf, *fr$,e$
n$, strl, x$, y$, strr0, strf, smax, "M03",e$
pbore1$ # Canned Bore #1 Cycle
pdrill$
pbore2$ # Canned Bore #2 Cycle
pdrill$
pmisc1$ # Canned Misc #1 Cycle
pdrill$
pmisc2$ # Canned Misc #2 Cycle
pdrill$
pdrill_2$ # Canned Drill Cycle
n$, strl, x$, y$, strr0, strf, smax, sm99,e$
ppeck_2$ # Canned Peck Drill Cycle
pdrill_2$
pchpbrk_2$ # Canned Chip Break Cycle
pdrill_2$
ptap_2$ # Canned Tap Cycle
pdrill_2$
pbore1_2$ # Canned Bore #1 Cycle
pdrill_2$
pbore2_2$ # Canned Bore #2 Cycle
pdrill_2$
pmisc1_2$ # Canned Misc #1 Cycle
pdrill_2$
pmisc2_2$ # Canned Misc #2 Cycle
pdrill_2$
pcanceldc$ # Cancel canned drill cycle
pcancelcc$ # Cancel cutter comp.
# Canned Text
pcan #Canned text - before output call
strcantext = sblank
if cant_no$ > 0,
if cant_pos1$ = 0, pcant_1
if cant_pos2$ = 0, pcant_2
if cant_pos3$ = 0, pcant_3
if cant_pos4$ = 0, pcant_4
if cant_pos5$ = 0, pcant_5
if cant_pos6$ = 0, pcant_6
if cant_pos7$ = 0, pcant_7
if cant_pos8$ = 0, pcant_8
if cant_pos9$ = 0, pcant_9
if cant_pos10$ = 0, pcant_10
n$, strcantext, e$
strcantext = sblank
pcan1 #Canned text - with move
strcantext = sblank
if cant_no$ > 0,
if cant_pos1$ = 1, pcant_1
if cant_pos2$ = 1, pcant_2
if cant_pos3$ = 1, pcant_3
if cant_pos4$ = 1, pcant_4
if cant_pos5$ = 1, pcant_5
if cant_pos6$ = 1, pcant_6
if cant_pos7$ = 1, pcant_7
if cant_pos8$ = 1, pcant_8
if cant_pos9$ = 1, pcant_9
if cant_pos10$ = 1, pcant_10
if cstop$, strcantext = strcantext + sm00
if cgstop$, strcantext = strcantext + sm01
#Output of strcantext occurs at the end of the output line
pcan2 #Canned text - after output call
strcantext = sblank
if cant_no$ > 0,
if cant_pos1$ = 2, pcant_1
if cant_pos2$ = 2, pcant_2
if cant_pos3$ = 2, pcant_3
if cant_pos4$ = 2, pcant_4
if cant_pos5$ = 2, pcant_5
if cant_pos6$ = 2, pcant_6
if cant_pos7$ = 2, pcant_7
if cant_pos8$ = 2, pcant_8
if cant_pos9$ = 2, pcant_9
if cant_pos10$ = 2, pcant_10
n$, strcantext, e$
strcantext = sblank
pcant_1 #Canned text - output call
cantext$ = cant_val1$
pcant_out
pcant_2 #Canned text - output call
cantext$ = cant_val2$
pcant_out
pcant_3 #Canned text - output call
cantext$ = cant_val3$
pcant_out
pcant_4 #Canned text - output call
cantext$ = cant_val4$
pcant_out
pcant_5 #Canned text - output call
cantext$ = cant_val5$
pcant_out
pcant_6 #Canned text - output call
cantext$ = cant_val6$
pcant_out
pcant_7 #Canned text - output call
cantext$ = cant_val7$
pcant_out
pcant_8 #Canned text - output call
cantext$ = cant_val8$
pcant_out
pcant_9 #Canned text - output call
cantext$ = cant_val9$
pcant_out
pcant_10 #Canned text - output call
cantext$ = cant_val10$
pcant_out
pcant_out #Canned text - build the string for output
#Build the cantext string
if cantext$ = 1, strcantext = strcantext + sm00
if cantext$ = 2, strcantext = strcantext + sm01
if cantext$ > 2,
strtextno = no2str(cantext$)
strcantext = strcantext + strm + strtextno
pwrtt$ # Tool table line format
# Numbered questions for Mastercam Mill
38. Rapid feedrate? 800.0
1538. Rapid feedrate (metric)? 10000.0
80. Communications port number for receive and transmit (1 or 2) ? 1
81. Baud rate (110, 150, 300, 600, 1200, 2400, 4800, 9600)? 9600
82. Parity (E/O/N)? E
83. Data bits (7 or 8)? 7
84. Stop bits (1 or 2)? 1
85. Strip line feeds? N
86. Delay after end of line (seconds)? 0.0
87. Ascii, Eia, or Binary (A/E/B)? A
88. Echo keyboard to screen in terminal emulation? n
89. Strip carriage returns? N
90. Drive and subdirectory for NC files?
91. Name of executable post processor? MP
92. Name of reverse post processor? RP
93. Reverse post PST file name? RPFAN
100. Number of places BEFORE the decimal point for sequence numbers? 3
101. Number of places AFTER the decimal point for sequence numbers? 0
103. Maximum spindle speed? 6000
107. Average time for tool change (seconds)? 2.0
161. Enable Home Position button? y
162. Enable Reference Point button? n
163. Enable Misc. Values button? y
164. Enable Rotary Axis button? n
165. Enable Tool Plane button? y
166. Enable Construction Plane button? y
167. Enable Tool Display button? y
168. Check tplane during automatic work origin creation? n
# Default Miscellaneous Real Values
201. Default miscellaneous real variable 1 (mr1)? 0.0
202. Default miscellaneous real variable 2 (mr2)? 0.0
203. Default miscellaneous real variable 3 (mr3)? 0.0
204. Default miscellaneous real variable 4 (mr4)? 0.0
205. Default miscellaneous real variable 5 (mr5)? 0.0
206. Default miscellaneous real variable 6 (mr6)? 0.0
207. Default miscellaneous real variable 7 (mr7)? 0.0
208. Default miscellaneous real variable 8 (mr8)? 0.0
209. Default miscellaneous real variable 9 (mr9)? 0.0
210. Default miscellaneous real variable 10 (mr10)? 0.0
# Default Miscellaneous Real Values (METRIC)
1601. Default miscellaneous real variable 1 (mr1) (metric)? 0.0
1602. Default miscellaneous real variable 2 (mr2) (metric)? 0.0
1603. Default miscellaneous real variable 3 (mr3) (metric)? 0.0
1604. Default miscellaneous real variable 4 (mr4) (metric)? 0.0
1605. Default miscellaneous real variable 5 (mr5) (metric)? 0.0
1606. Default miscellaneous real variable 6 (mr6) (metric)? 0.0
1607. Default miscellaneous real variable 7 (mr7) (metric)? 0.0
1608. Default miscellaneous real variable 8 (mr8) (metric)? 0.0
1609. Default miscellaneous real variable 9 (mr9) (metric)? 0.0
1610. Default miscellaneous real variable 10 (mr10) (metric)? 0.0
# Enable/Disable Miscellaneous Real Variable switches
1611. Enable miscellaneous real variable 1? y
1612. Enable miscellaneous real variable 2? y
1613. Enable miscellaneous real variable 3? y
1614. Enable miscellaneous real variable 4? y
1615. Enable miscellaneous real variable 5? y
1616. Enable miscellaneous real variable 6? y
1617. Enable miscellaneous real variable 7? y
1618. Enable miscellaneous real variable 8? y
1619. Enable miscellaneous real variable 9? y
1620. Enable miscellaneous real variable 10? y
# Default Miscellaneous Integer Values
301. Default miscellaneous integer variable 1 (mi1)? 0
302. Default miscellaneous integer variable 2 (mi2)? 0
303. Default miscellaneous integer variable 3 (mi3)? 0
304. Default miscellaneous integer variable 4 (mi4)? 0
305. Default miscellaneous integer variable 5 (mi5)? 0
306. Default miscellaneous integer variable 6 (mi6)? 0
307. Default miscellaneous integer variable 7 (mi7)? 0
308. Default miscellaneous integer variable 8 (mi8)? 0
309. Default miscellaneous integer variable 9 (mi9)? 0
310. Default miscellaneous integer variable 10 (mi10)? 0
# Enable/Disable Miscellaneous Integer Variable switches
1621. Enable miscellaneous integer variable 1? y
1622. Enable miscellaneous integer variable 2? y
1623. Enable miscellaneous integer variable 3? y
1624. Enable miscellaneous integer variable 4? y
1625. Enable miscellaneous integer variable 5? y
1626. Enable miscellaneous integer variable 6? y
1627. Enable miscellaneous integer variable 7? y
1628. Enable miscellaneous integer variable 8? y
1629. Enable miscellaneous integer variable 9? y
1630. Enable miscellaneous integer variable 10? y
# Configuration File association parameters (default is "y")
#400. Name of associated cfg file?
401. Read SYSTEM COLORS section? y
402. Read ALLOCATIONS section? y
403. Read TOLERANCES section? y
404. Read DATA PATHS section? y
405. Read COMMUNICATIONS section? y
406. Read DRAFT SETTINGS section? y
407. Read MISCELLANEOUS section? y
408. Read NC SETTINGS section? y
409. Read DIALOG SCRIPTS section? y
410. Read DESIGN SETTINGS section? y
411. Read PLOTTER SETTINGS section? y
412. Read ALT-KEY ASSIGNMENTS section? y
413. Read
CAD section? y
414. Read START/EXIT section? y
415. Read SCREEN section? y
416. Read FILE NAMES section? y
1500. Chook to execute from 'Misc. values' button?
1501. Insert parameter information in the ascii NCI? n
1502. Write operation information to binary file (.ops)? n
1520. Display a warning when cutter compensation in control simulation finds an error? y
# Do NOT manually change the answer for Q.1999 !
1999. Product major version number that post supports? 9
[CTRL_TEXT_END]
