Results 1 to 8 of 8
Thread: outputting program number to NCI maybe a post issue??
    Oct 2011
    Ive been working on getting my post exactly how I want it Im starting with mplfan.pst for fanuc lathe
    Its all good except that I cant get it to post the program number that I enter in the files page of my machine group properties
    I looked at the NCI and didnt see it outputted anywhere but that doesnt mean much because I cant make sense of most of the NCI
    any help would be greatly appreciated
    Nick
    Registered WallyL7's Avatar
    Dec 2008
    I've never done it that way - mainly because I usually only have a group or 2 but will almost always have more than one operation group within the machine group...so
    The way I do it is highlight all toolpaths (that are included in the operation), then right click, then "edit selected operations" then "change program #
    Each of my operation groups has a program number this way - as well as a different name (operation 1, 2, etc...)
    Tim
    Registered Superman's Avatar
    Dec 2008
    Krypton
    Quote Originally Posted by Avsfan135 View Post
    Nick
    Mastercam can use the toolpath group name as the NCI & NC filenames, settngs are in the System config file. You may have to customise your post to have it read the comment, parse it, & place the O#### correctly...but then you are locked into programming in this fashion for this post, call in another MCX file programmed for a different control or by someone else, and your customised post may output a few name &/or O#### errors
    But it is easier to leave all that alone, let the machine & toolpath group names be the descriptive comment zones that they are.
    Then select the operations you want posting as a group to 1 file,
    --> R-click "Change NC file name" ( this is the name of the NC file that you want ),
    --> R-click "Change program #" ....(this is the O#### on the first line of that NC file ).
    Oct 2011
    Thanks guys! I'll give that a try and report back
    Superman the program name and time and date codes are all correct and its posting with no errors the only problem I'm having is with the number.
    Thanks again
    Nick
    Oct 2011
    unfortunately that didnt work..
    i can show the example of my NCI and post and see if you guys see anything
    NCI first section...
    1050
    14 42 22 11 2011 12 24 11 H:\NICKS STUFF\LUBRICATOR\LB-D24NSLT- OP 2.MCX-5
    999
    66 0 1
    1051
    Lathe Default
    1053
    Machine Group-1
    1008
    FACE
    1011
    0. 0. 0. 0. 0. 0. 0. 0. 0. 0.
    1012
    1 0 0 0 0 0 0 0 0 0
    1013
    0 0.03125 0. 0 5 0. 0. 0. 102 OD ROUGH RIGHT - 80 DEG.
    1014
    0. 1. 0. 0. 0. 1. 1. 0. 0.
    1016
    1 0 66 1 0. 0. 0. 41 0 0 0 0 0. 4 1 52 1 13
    1017
    1. 0. 0. 0. 1. 0. 0. 0. 1.
    950
    0 0 0 46 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
    1025
    1027
    1. 0. 0. 0. 1. 0. 0. 0. 1. 0. 0. 0.
    1020
    1.8125 2.64 2.64 -0.84375 0. 0. 0 0. 0. 0. 0. 0 10000 STEEL inch - 1030 - 200 BHN
    20010
    TOP
    20011
    that is the first section thru the first tool
    Here is the part of my post that sets up the format for the program number
    #Move comment (pound) to output colon with program numbers
    fmt O 7 progno$ #Program number
    #fmt ":" 7 progno$ #Program number
    fmt O 7 main_prg_no$ #Program number
    #fmt ":" 7 main_prg_no$ #Program number
    fmt O 7 sub_prg_no$ #Program number
    #fmt ":" 7 sub_prg_no$ #Program number
    and the part that sets up the header
    pheader$ #Start of file
    if miscopflag = zero,
    "%", e$
    sav_spc = spaces$
    spaces$ = 0
    #*progno$, " (", sprogname$, ")", e$
    *main_prg_no$, e$
    "(", sprogname$, ")", e$
    #"(", "DATE=DD-MM-YY - ", date$, time$, ")", e$ #Date and time output Ex. 12-02-05 15:52
    #"(", month$, "-", day$, "-", year$, ")", e$ #Date output as month,day,year - Ex. 02-12-05
    "(", *smonth, " ", day$, " ", *year2, ")", e$ #Date output as month,day,year - Ex. Feb. 12 2005
    #"(", "TIME - ", time$, ")", e$ #24 hour time output - Ex. 15:52
    "(", ptime ")", e$ #12 hour time output 3:52 PM
    and here is an example of a program posted
    O0000
    (T)
    (NOV. 23 2011)
    (6.09 AM)
    G20
    ( FACE )
    G0 X10. Z10.
    G0 T0404
    G97 S726 M03
    G0 X2.84 Z0. M8
    G50 S2500
    G96 S540
    G99 G1 X1.5625 F.006
    G0 Z.1
    ( ROUGH OD )
    G96 S450
    X2.5935
    Z.2092
    G1 Z.1092 F.01
    Z-1.1759
    X2.7664 Z-1.2624
    X2.9078 Z-1.1917
    G0 Z.21
    X2.4205
    G1 Z.11
    Z-1.0894
    X2.6135 Z-1.1859
    X2.7549 Z-1.1152
    G0 Z.21
    X2.2476
    G1 Z.11
    Z-.1473
    G3 X2.27 Z-.1756 I-.03 K-.0283
    G1 Z-1.0142
    X2.4405 Z-1.0994
    X2.582 Z-1.0287
    G0 Z.21
    X2.0746
    G1 Z.11
    Z-.0954
    X2.2287 Z-.1399
    G3 X2.2676 Z-.1657 I-.0206 K-.0358
    G1 X2.409 Z-.095
    G0 Z.21
    X1.9017
    G1 Z.11
    Z-.0455
    X2.0946 Z-.1011
    X2.2361 Z-.0304
    G0 Z.21
    X1.7288
    G1 Z.11
    Z.0045
    X1.9217 Z-.0512
    X2.0631 Z.0195
    ( FINISH )
    G96 S550
    G0 Z.0958
    X1.7188
    G1 Z-.0042 F.006
    X2.2188 Z-.1485
    G3 X2.25 Z-.1756 I-.0156 K-.0271
    G1 Z-1.0183
    X2.741 Z-1.2638
    X2.8825 Z-1.1931
    M9
    G0 X10. Z10. T0400
    M05
    M01
    I know that is a lot of info but if you see anything that would be great.
    I cant find anything else in the post about the program number and I dont see it posted in the NCI it should be #3520
    Oct 2011
    I did just find this at the bottom of the NCI...
    C:\USERS\PUBLIC\DOCUMENTS\SHARED MCAMX5\LATHE\TOOLS\NONE
    20800
    0.
    1002
    3520 100 10 2 2 10000 8 -450 -0.006 1 0.83207792 0. 0.09542208 5. 0. 10. 1 0.
    0 0.83207792 0. 0.09542208 1000. 90000
    1
    0 0.83207792 0. -0.00457792 -0.006 52000
    1
    0 0.78172258 0. -0.05493326 -0.006 1100
    1
    0 0.7110119 0. 0.01577742 -0.006 50200
    0 0.7110119 0. 0.03 1000. 10000
    1003
    5. 0. 10.
    So that is obviously where is outputting the program number I was expecting it at the beginning
    Oct 2011
    OK I fixed it the original suggestion that both of you had was correct but in trying to fix it I had altered my post and never put it back when it didnt work...DOH
    thanks again for all of your help!
    Nick
    it was here
    "%", e$
    sav_spc = spaces$
    spaces$ = 0
    *main_prg_no$, e$ ( I had changed that to main_prg_no and should have left it at progno and just changed my # in mastercam like you suggested)
    Dec 2008
    Krypton
    Code:
    the progno$ is the O#### for the NC file you are creating
    the main_prg_no$ & sub_prg_no$ relate to the subprogram & subroutine area of the newly created NC file, & are created automatically. My post makes the sub numbers +1 to the progno$ so it keeps them together in the control
    ( highlighted blue are my changes )
    Code:
    psub_call_trans #Translate level calls from toolchange, user
          if mi1$ <= one, result = mprint(shomeserror)
          sav_absinc = absinc$
          #Mirror or Rotate Coord's
          if sub_trnstyp$ = zero | (sub_trnstyp$ = one & mr_rt_actv),
            #The original pattern is not mirrored or rotated
            if sub_sec_no$,
              absinc$ = zero
              if sub_trnstyp$, psub_rotate
              else, psub_mirror
            mr_rt_actv = three
          else, #Translate
            if sub_mny_t$,
              if mi1$ > one, absinc$ = zero
              pbld, n$, *sgcode, *sgabsinc, pwcs, pfxout, pfyout, pfzout, e$
              pe_inc_calc
              ps_inc_calc
          absinc$ = sav_absinc
          result = nwadrs(strp, main_prg_no$)
        main_prg_no$ = main_prg_no$ + progno$
        if progno$ = main_prg_no$, result = mprint(sprgnerror)
          pbld, n$, "M98", *main_prg_no$, e$
          prv_feed = c9k #Force feed in sub
    psub_mirror     #Mirror start code, user
          #Mirror Y axis
          if sub_trnmthd$, pbld, n$, *sgabsinc, strns_mir_on, *sub_trnsx$, e$
          #Mirror X axis
          else, pbld, n$, *sgabsinc, strns_mir_on, *sub_trnsy$, e$
    psub_rotate     #Rotate start code, user
          pbld, n$, *sgcode, *sgabsinc, strns_rot_on, *sub_trnsx$, *sub_trnsy$,
            [absinc$ = one], *sgabsinc, e$
    psub_st_m$       #Header in main level
          result = nwadrs(stro, main_prg_no$)
        "()", e$
          *main_prg_no$, "(SUB USED IN", *progno$, ")", e$
          #G51/G68 requires absolute position on first move
          if mr_rt_actv & absinc$ = one,
            absinc$ = zero
            prv_absinc$ = m_one
            prv_xabs = m_one
            prv_yabs = m_one
          else, pbld, n$, sgabsinc, e$
    1. Need Help!- Outputting Common variable values into a program
      By yaji63 in forum Fanuc
      Last Post: 11-14-2011, 08:41 AM
    2. Replies: 0
      Last Post: 12-27-2010, 03:55 AM
    3. outputting variables to a program
      By bob in windsor in forum Fanuc
      Last Post: 03-21-2010, 11:43 AM
    4. How do i get my program number not theirs
      By robertbair in forum Fanuc
      Last Post: 12-06-2007, 12:13 PM
    5. (Brackets) after Program Number (O)
      By alanblackwell in forum G-Code Programing
      Last Post: 08-09-2005, 06:27 PM
