How would like my post to list a G02 and a G03 with each line? This is the code now. N170 G1 Z2.36 F200. N180 G41 D4 X2.178 Y-.7128 F14.06 (CUTTER COMP) N190 G3 X1.9494 Y-.8075 I-.0669 J-.1616 N200 G2 X1.7493 Y-1.1799 I-1.9494 J.8075 N210 X1.5508 Y-1.2088 I-.1126 J.0767 N220 X1.2088 Y-1.5508 I-1.5508 J1.2088 N230 X1.1799 Y-1.7493 I-.1056 J-.0859 N240 X.4026 Y-2.0712 I-1.1799 J1.7493 N250 X.2418 Y-1.9513 I-.0257 J.1334 N260 X-.2418 I-.2418 J1.9513 N270 X-.4026 Y-2.0712 I-.1351 J.0135 This is where I think it needs to be changed pcirout1 #Output to NC of circular interpolation pcan1, pbld, pn, `sgfeed, sgplane, sgcode, sgabsinc, pccdia, pxout, pyout, pzout, paout, pcout, parc, feed, strcantext, scoolant, pcccomment, pe Thank You |
| use a * in front of the string the force that item into the NC file -----find sgcode, change to *sgcode --> Open the Machine Definition File, --> then open the Control file for that machine, --> go to the NC File tab & uncheck the "Use sequence numbers", --> accept the changes while backing out of the files This is the same area that you go to to alter the actual numbering pattern defaults. ie the default start at N100 and increment by 100, you may want to start at N1 & increase by 1. |
| You are correct with eliminating the N sequence numbers, but to get into where you're talking about, first select SETTINGS in top menu and MACHINE DEFINITION MANAGER.Then find EDIT CONTROL DEFINITION icon at top, then select NC OUTPUT at left. In this page un-select OUTPUT SEQUENCE NUMBERS box. It takes some looking without knowing each step. |
| Modify MasterCam post | jeffrey001 | General CAM Discussion | 3 | 07-03-2009 03:28 AM |
| Need Help!- How to Modify Post Processor? | Stampede | BobCad-Cam | 1 | 09-26-2008 03:00 PM |
| 31i-A5 which post to modify | jrobson | Fanuc | 0 | 02-27-2008 05:34 AM |
| how can i modify the post? | ahmedsamy_81 | Post Processors for MC | 0 | 07-16-2006 02:25 PM |
| Post Processor (ISO G-Code - Non Modal) | CNCadmin | Carken Products (Deskam, DeskCNC etc) | 1 | 01-29-2005 07:32 AM |
