Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > Mastercam > Post Processors for MC
Old 10-26-2011, 10:12 AM
longo is on a distinguished road
ROUGH TURN
Hi all,
Been years since I have been in here
I work with 30-60 inch diameters
Mastercam X5
Is there any way to make the roughing cut from OD towards the Center.
Right Now if I have a part that is 40 inch Diameter and has a Hub on ity @ 10 X 1/4 deep, Mastercam will only cut in the Z direction making for a LOT of cuts. I would like to be able to cut in the X direction
Larry
Old 10-26-2011, 12:00 PM
Technical Ted is on a distinguished road
You'd probably get more help if this was posted in the main Mastercam forum instead of the Post Processor sub-forum.
I'm somewhat new to Mastercam but I think you change this under 'Rough Parameters' > 'Rough Direction/Angle'.
Old 10-27-2011, 06:47 AM
Superman's Avatar
Superman is on a distinguished road
You will have to "Face" instead of "OD turn"
- tool shape should still be the same,
- contour chain to select is from OD going to Hub
Old 10-27-2011, 07:21 AM
rough turn
Hi, Thanks for answering. I had tried that and MC does locks up or just cuts on the od
I need a better way to rough HY-80 AKcrabber General Metalwork Discussion 6 07-25-2010 03:10 PM
Z Level rough with multipule rough tools mbi FeatureCAM CAD/CAM 2 02-25-2010 10:45 PM
Rough Movement jhwatts Xylotex 2 09-28-2006 03:07 PM
Rough Cut of a thread Slythar Test Forum 0 04-09-2006 08:00 PM
truemill and z-rough and srm championp Surfcam 1 02-22-2006 09:51 PM
