Hi All, Is there a relatively easy way to have my posts use different Format Statement values under different conditions? I am forced to really shrink my programs for some older Fanuc controllers and I'd like to use 2 or 3 decimal places for coordinates while roughing, and 4 decimal places for finish passes (as one example). Thanks in advance, Jeff MasterCAM X |
| I think this is managed in your post-processor(s). The setting to look for and change will be for "Trailing Zeros". This will change Z1.000 to Z1. or X4.500 to X4.5 . Oh, and to force resolution, X.XX instead of X.XXXX you probably will have to make one Machine Group for roughing and one Machine Group for finishing. Edit the Machine Control for each to the resolution you desire. The problem with this is you will run into circumstances where the round off on the roughing will not leave material for finish. So, then you will be forced to adjust your XY and Z Stock to leave to compensate.
__________________ http://www.kirkcon.com/ Last edited by txcncman; 09-21-2011 at 05:00 PM. |
| Right txcncman, I know how to change the values in the post. What I'd like to be able to do is have some way to change it with variables in the particular Mastercam operation I am working with. That way I don't have to keep swapping posts every time I switch from a roughing to a finishing routine. |
| I am pretty knowledgeable of MasterCAM X3. I cannot imagine any way to do what you are wanting to do automatically. If you do not want to edit your tolerances for each cutting condition every time, you could build one machine control and name it Fanuc Mill Rough and another for Fanuc Mill Finish. That would simplify the process a little. Are you already utilizing sub programs to "shrink" the memory used?
__________________ http://www.kirkcon.com/ |
| Format Statements | Xavior | Mastercam | 5 | 09-08-2011 06:28 AM |
| Need Help!- comment statements | compfranon | ArtCam Pro | 0 | 09-03-2011 08:13 PM |
| Conditional and Loop Statements in Mach3 | Monotoba | LittleMachineShop CNC Machines | 5 | 04-24-2010 09:12 PM |
| PRINT / MSG statements using AXIS front end | bogflap | LinuxCNC (formerly EMC2) | 9 | 03-16-2009 08:43 AM |
| If / Then Statements | Nanker | G-Code Programing | 6 | 10-23-2004 12:11 AM |
