Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > Mastercam > Post Processors for MC
Old 08-20-2011, 11:08 AM
peakeng is on a distinguished road
where to start
Hi
I read the post about trying to get post processors, I get it.
I would like to know more about processors. Not having much luck finding info, besides this site.
What I want to do is have a post for my plasma table. the g code is real simple. no work offset, marco, z moves, just G0 G1. any hints or where to start?
thank you
Old 08-20-2011, 08:50 PM
Superman's Avatar
Superman is on a distinguished road
Never used a plasma, but
I asssume it is just a goto a lead in position, turm ON, do the 2D shape, lead OUT, then turm OFF, (go home, if required)
if this is the principle, then a 2D wirecut post is possibly the way to go ( wire would be the simplest for programming ease )
try using a Generic Fanuc 2-axis Wirecut post ( example only, try the others that may give code closer to your needs- less mods needed ) & go from there
- create a mastercam session for a shape, & multiple shapes ( circle, square, holes, etc )
- post them
- modify the code to make it run on your machine
- adjust the selected post to give the same code as the proven ( running ) NC-code
Old 08-21-2011, 04:19 PM
thanks i'll start there.
my plasma table starts a cut automatically when the code changes from to G1 from G0. So my biggest issue (i think) will be not posting a M3. but there is only one way to find out. heres to trying something and going from there.
ACME rods - normal start and multi-start shaffin Canadian Club House 0 12-20-2010 07:19 AM
Disadvantages of 2 start vs. 5 start? Biff DIY-CNC Router Table Machines 8 05-22-2010 04:42 PM
Arrow 750 Failed to start when I Push start Bottom in fornt of control ! mte.jalal Cincinnati CNC 4 01-06-2009 10:20 AM
Newbie- one start or two start lead screw Pinhead DIY-CNC Router Table Machines 5 11-22-2008 10:32 PM
Single start vs double start ballscrew. darik Linear and Rotary Motion 13 03-21-2007 07:53 PM
