If you need the D value "gone" just comment it out in the file.----#
Robert
i have a small change i would like to make to my post
when i put a wear comp in it kicks this out
N60 G54
N70 G00 G90 X-2.1514 Y-.5 S6000 M03
N80 G43 Z.25
N90 Z.1
N100 G01 Z-.1 F6.42
N110 G41 D3 X-1.6514 F40. <------- on a regular machine this would be fine
N120 G03 X-1.1514 Y0. I0. J.5
N130 G02 X1.1514 I1.1514 J0.
I need that "D" value gone JUST after the G41 or G42
any help would be greatly appreciated
thanks
Robert
The beaten path, is exclusively for beaten men.
First...make a backup of your current post
If anything stuffs up in editing, you can restore it back to original
Open the PST file with any text editor,
and find
change it toCode:pccdia #Cutter Compensation #Force Dxx# if prv_cc_pos$ <> cc_pos$ & cc_pos$, prv_tloffno$ = c9k sccomp if cc_pos$, tloffno$
The # at this position stops the tloffno$ from being output on the block but still allows the G40/G41/G42 to be oututted to the NC code.Code:pccdia #Cutter Compensation #Force Dxx# if prv_cc_pos$ <> cc_pos$ & cc_pos$, prv_tloffno$ = c9k sccomp # if cc_pos$, tloffno$
thanks superman, it was just that simple. I have the post dialed in perfect now.
