Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > Mastercam > Post Processors for MC
Old 03-31-2011, 11:41 AM
weirdharold's Avatar
weirdharold is on a distinguished road
Smile Need correct rotation
Thought I had this fixed. I'm modifying the Generic Fanuc 5X Mill post, ( using X4, MU3) for our HAAS VF-4, with a Tsudakoma\ TN-160 mounted on it. B tilt's in -X(0-90) & A rotates (360). Tweeking for a couple of day's & can't get it correct. I'm uploading a pic of how the 5th axis is on the mill. I know this much is correct, because I've set it up in UG NX5.(lot's easier). Also uploaded a text file with the code I'm getting, & the part of the post I'm tweeking. Y will stay at 0, & X will stay at X-7.5886. Should be only one "B" index, (55deg), & 6 "A" output's, starting with, 0,60,120,180,240, & 300 with the test part I'm using. Steve, if your out there, I need your help on this one, You have helped me in the past with post issues , before. Thank's in advance.
Regard's,
Harold
File Type: txt 64MM_12HOLE[1].txt‎ (806 Bytes, 13 views)
Last edited by weirdharold; 04-02-2011 at 09:07 AM. Reason: Added Txt file of example of how code should be
Old 04-01-2011, 12:40 AM
Smile post help
post help
Old 04-01-2011, 02:21 AM
Superman's Avatar
Superman is on a distinguished road
You callin me??
H, we have similar transom, but the B is aligned along the X axis, which makes it an A address, limits are A20 to A-110
When our 4th axis=0, the 5th axis is perpendicular to the Z, this makes it a C axis address ( C rotates around Z ), limits are C0 to 360
This could be your problem ?
Remember to use the WCS of the part drawn in TOP view of the setup ( with all axes set to zero ), and T/C planes to be how the tool "sees" the part relative to this WCS
You do understand the way to program for a horizontal ?
It may have to be in this sort of setup, ( thinking aloud )
Old 04-01-2011, 09:57 AM
Smile Modify Post
I put a line of star's by the values I may or may not need to modify.
Regard's,
Harold
Old 10-03-2011, 02:55 PM
chestervomkorte is on a distinguished road
Hello,
where can i get the Generic Fanuc 5X Mill post ?
Can someone upload it, because i don't have X2 or X3 here.
Maybe someone has updated the post to X5 ?
It's not on the last X4 or X5 setups anymore.
Thanks,
chester
email:cad-cam-cnc@gmx.de
Need Help!- Coordinate Rotation G68 dougtyler Fanuc 10 09-21-2010 11:00 AM
Need Help!- Rotation angle 1234567 BobCad-Cam 2 03-16-2010 06:45 AM
rotation marcT G-Code Programing 4 01-30-2008 12:12 AM
G&L rotation abigg G-Code Programing 0 10-02-2007 07:26 AM
Correct Pay?? j-radkemachine Employment Opportunity 70 01-21-2007 10:26 AM
