Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > Mastercam > Post Processors for MC
Old 03-25-2011, 09:51 AM
PRINT_FX's Avatar
PRINT_FX is on a distinguished road
misc. values / set op defaults
Hi all,
as the help mention [Choose Set to Op Defaults to read the default values stored in the .DEFAULTS file. You can edit or override the default values by entering new values here.]
where is the default file? I'm on X5
thanks guys
Old 03-25-2011, 10:42 AM
psychomill is on a distinguished road
You can actually do this in a few different places depending on how your post settings are set up. Anyhow, the defaults file is opened through mastercam, it's not a file you just open up in windows.
One way you can set the values is through your Control Definition of the machine you're programming to (see picture).
The Defaults you mention is accessed through your machine settings as well. First you select your machine (MMD) and go to your Operations Manager (where your toolpaths are stored). Then expand the "Properties" tree and select the "Files" button. (see picture). Then select the "!" button and you'll have access to all toolpath types available to set many many things as defaults.
The easiest to adjust or set can be done on the fly. While you're in a toolpath, you can enter all of your info/data for the toolpath, then before you hit the check mark for the toolpath generation, you can press the SAVE button and that toolpath will save it's settings to the default file you're using for 'next time'.... (see picture)
ID:	129823   Click image for larger version
ID:	129824   Click image for larger version
It's just a part..... cutter still goes round and round....
Old 03-25-2011, 11:54 AM
PRINT_FX's Avatar
perfect
thanks again.
Old 03-25-2011, 12:39 PM
PRINT_FX's Avatar
perfect
thanks again.
Old 03-25-2011, 05:17 PM
PRINT_FX's Avatar
Originally Posted by PRINT_FX View Post
perfect
thanks again.
Very strange, I did not post double message, I think someone is playing with me..
first post at 10:54 and second at 11:39, over 30 minutes apart..
very strange...
Misc. stuff on the G540 revwarguy Gecko Drives 6 07-16-2010 08:38 PM
X4 Operation Defaults WingNutz Mastercam 4 12-31-2009 09:29 AM
My KX3, tweaks and misc. stuff Guldberg Benchtop Machines 3 03-26-2009 10:20 AM
Rhino_Tools_Options Defaults? robinsoncr Rhino 3D 2 06-12-2006 11:07 AM
Misc surplus controllers, need help Hobbiest General Electronics Discussion 7 03-19-2005 12:54 AM
