I'm trying to get a new to me 97 BP VMC1000 up and running. My programmer had an ISO PP that he used the update util in MC to bring up to date(V9 from older CD to X3 with postupdater and control def.). We couldn't get to far with that one. He also had the conversational PP that we can get a little farther on. Some code samples to follow. Seems it's the tool change that's the biggest problem. We can get this one to load and run,
This one runs fine, it came on the machine when I bought it, but even if a different tool # is in the spindle, it won't change to the tool called in this program. I've edited the program by hand to several different #'s and it just goes right past the tool call. Any thoughts on what we're doing wrong? |
Found a different post on a an older MC cd, works ok in some aspects. This portion, the first tool works ok; BEGIN PGM 0 INCH TOOL CALL 3 Z S4500 L R F M06 L X+0 Y+0 R F MAX M L X-2.4465 Y-.55 R F MAX M03 L Z+.25 R F MAX M L Z-.25 R F MAX M8 L Z-.3643 R F64 M Makes the tool change, turns the spindle on, turns the coolant on. Next tool changes, turns coolant on but does not turn the spindle on; C X+2.4345 DR+ R F M L X+2.452 R F M L Z+.25 R F MAX M TOOL CALL 2 Z S4000 L R F M06 L X-2.461 Y-.55 R F MAX M L Z+.25 R F MAX M L Z+.1 R F MAX M8 L Z-.025 R F64 M L X-2.511 R F150 M CC X-2.45 Y-0.55 C X-2.389 DR+ R F M CC X-2.45 Y-0.55 C X-2.511 DR+ R F M L X-2.461 R F M L Z-.05 R F64 M and then the drilling cycle is backwards I think, Puts the parameters before the tool call or doesn't properly call the cycle after the tool call, nor does it turn the spindle on. CC X2.45 Y-0.55 C X+2.5125 DR+ R F M CC X2.45 Y-0.55 C X+2.3875 DR+ R F M L X+2.4375 R F M L Z+.25 R F MAX M CYCL DEF 1.0 PECKING CYCL DEF 1.1 SET UP -0.1 CYCL DEF 1.2 DEPTH 1. CYCL DEF 1.3 PECKG -0.1 CYCL DEF 1.4 DWELL 0. CYCL DEF 1.5 F41 L Z0.1 R F MAX M L Z0.1 R F MAX M8 L Z0.1 R F MAX M99 TOOL CALL 12 Z S1711 L R F M06 L X-2.45 Y-.55 R F MAX M L R F M25 END PGM 0 INCH Is there anyone who can point me in the right direction in editing this post? I have never edited a post before, not really a programmer, I outsource it to a guy who has never needed to do it either. I found several other posts in a google search. They have some nice features people have added(tool lists, etc.) but are not even as close as this one. Edit: I had my programmer send me the files to post. I've attached them for anyone who would like to see them. Remove the .txt I had to add it to upload the files. MPHEID-1.control.txt MPHEID-1.MMD.txt MPHEID-1.pst.txt 500BOTTESTMPH1.H.txt This is the program as written in whole. Edit # 2 When he posts each sub program/tool individually, they do post correctly(not the drill program, that doesn't change). Anyone? Last edited by KevinV_MEI; 03-04-2011 at 04:35 PM. |
this is "original" but i can send my tweaked post |
| my post:GENERIC HEIDENHAIN_TNC530 3X MILL.zip |
| X4? Try the ones I posted. Let us know what they do and we'll see if we can help tweak them. It's tough for anyone to comment unless you post what you've tried and what the results were. Use the update post utility. |
#10
Machine with TNC620 isnt delivered yet to our company so I cant be sure is it working or not. So I'm preparing on dry xD I just tried some tests with TNC620 software for PC. 4 now... seams good. Can you tell me what are the major settings to be configured for other machine? In my case it will be Fehlman Picomax 56 TOP. I will spend more time testing in next few days... |
#12
I'm using MasterCAM X5... an all files should be *.xxx-5 extension. Every time I start SolidWorks with MasterCam in startup I get warning msgs that update is needed. I did update but still its showing up. I think its because mastercam load files which are specified in pp, so I think I should change those links to files from MPHEID-1.MMD to MPHEID-1.MMD-5, same with *.control file... but I cant find those lines. Also I dont know what viewer I should use to open *.MMD an *.control , cause when I open it with Notepad ... some encoding isnt good. |
| Tags |
| heidenhain tnc 426, mastercamx3 |
| Heidenhain TNC 530 | Matth3w | SolidCam | 2 | 06-18-2010 01:16 AM |
| Need Help!- Heidenhain DRO | mmri1 | Bridgeport and Hardinge Mills | 1 | 10-27-2009 10:34 AM |
| Need Help!- heidenhain DRO | mmri1 | General Metal Working Machines | 0 | 10-20-2009 08:58 AM |
| Heidenhain 426 | anuevo | Post Processor Files | 2 | 10-01-2009 05:20 AM |
| heidenhain 151 or 155 | delbert | Post Processor Files | 8 | 07-10-2009 02:18 AM |
