Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > Mastercam > Post Processors for MC
Old 11-15-2010, 04:29 PM
Exodus8931 is on a distinguished road
MHP S-24 Hydrapath III - post
i'm looking for a mastercam post
that will work on this machine. i take any standard post for most of programing but i run into a errors on the machine when i'm milling anything with Radius,
i tried I and J, and i tried just R.
the fu.... pice of old junk machine keeps getting errors .... i don't know what the fu... is it's problem
anyone ? please
Old 11-15-2010, 06:20 PM
Superman's Avatar
Superman is on a distinguished road
I'm not going to "give" you a post (don't have one), but we ( the forum ) could "help" you to getting the post correct, and instruct you on modifying it.
#1 ---what version of Mastercam do you have ? and what machine control ?
#2 ---create a 1" circle in mastercam and interpolate the bore with a 5/8" cutter using a 2D contour -tool #1
---spotdrill 2 holes -tool #2
#3 ---post all ( use " TEST-POST" as the NC filename )
#4 ---manually modify the NC program to run correctly on the machine ( save as "TEST-MACHINE" as the filename )
After you have done this
#5 ---create a compressed ZIP folder on your desktop, and copy into it
--the MCX file
--the post you used
--the un-edited NC file from #3
--the edited NC file from #4
#6 ---on your next message, upload that compressed file as an attachment, and then we may know what your next step would be ( use the "paper clip" icon at the top of this box, browse for your ZIP folder, then upload -you may have to wait a little)
Old 11-21-2010, 08:01 PM
thanks, but there is too much code to change, realy, ill be looking around to see if anyone has it.....
on a side note .... i can't belive there is only few post on the mcpost forum.... ???????? guess i'll start posting what i got....
Tags
hydrapath iii, mhp, post, s-24
Problem- HydraPath III & DNC krema Controller & Computer Solutions 11 12-06-2010 04:52 AM
Need Help!- MHP Hydrapath help maniactrm General CNC (Mill and Lathe) Control Software (NC) 2 08-18-2010 08:20 AM
Need Help!- MHP Hydrapath help maniactrm General Metal Working Machines 0 08-13-2010 04:16 PM
DNC Questions about MHP B-22 with Hydrapath III Jim Estes Machine Problems, Solutions , Wireless DNC, serial port 18 12-28-2009 03:47 PM
Hydrapath Documentation pheyden General CNC (Mill and Lathe) Control Software (NC) 0 03-21-2009 07:47 PM
