Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > Mastercam > Post Processors for MC
Old 09-09-2010, 07:29 AM
ToddF is on a distinguished road
First Rapid movements need changed
Im using MastercamX to program my lathe. When it posts out the first rapid movements, they are posted on the same line. That can be dangerous, especially when using a tailstock. There is a place to check a box in Mastercam to post them out seperate, but it doesnt work. Do I need to change my post? Any help would be great.
Old 09-12-2010, 06:43 AM
thermgood is on a distinguished road
First of all I'm not an expert at this, I've modified a couple of posts. I would check a couple of things. I assume the check box in mastercam that you are refering to is under misc values. If they don't work from there you can edit your post and set the default in it, by searching for the value. The first column is mi1 thru mi10 (misc integers), the second column is mr1 thru mr10 (misc reals). Search your post for example find mi1 there is usually a default setting for it like 0 for off or 1 for on, change that and save your post then make your g code again and see if that changed it.
Another way is to break up the lines, once again you will have to search thru your post to find where those lines are created.
ex.
pcan1, pbld, n$, *sgcode, pwcs, *sgabsinc, *xout, *yout, *p_out, *s_out, *speed, *spindle, pgear, strcantext, e$
change to.
pcan1, pbld, n$, *sgcode, pwcs, *sgabsinc, *xout, *yout, *speed, *spindle, pgear, strcantext, e$
pcan1, pbld, n$, *p_out, *s_out, e$
that would create 2 lines of g code where it was all on 1 line before.
Just make a backup copy of your post before you start changing things, so you can always go back to what you had originally.
jerky movements arrow 750 chaz6966 Cincinnati CNC 1 02-17-2009 09:41 AM
Arc movements for circles ozturbo MadCAM 8 08-05-2007 10:59 PM
precise movements in mach....how do I... cephjedi Mach Software (ArtSoft software) 2 04-04-2007 06:52 PM
Bridges & jerky movements. Moondog Machines running Mach Software 20 07-29-2006 10:28 PM
Z Movements Are he Wrong Way. Why? gopackgo Kellyware CAM 4 05-15-2004 06:10 PM
