Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > Mastercam > Post Processors for MC
Old 06-17-2010, 05:55 PM
gogego is on a distinguished road
Want to remove G94/95.....
I am using X4 at work and update.dll doesnt quite give us the results we need and our reseller is quite busy. I have been able to modify most of the post to get to code output in a format we are familiar with yet I cant figure out how to remove G94/95 from being output. I am using the debugger so I have an idea of where to go to make changes, but I seem to be missing something. Its either a sgfeed, pdrlcommonb, or pdrill$, or so I thought.
These are the line(s) I thought I needed to modify
pbld, n$, sgabsinc, e$
pbld, n$, sgfeed, e$
any advice would be appreciated.
Old 06-26-2010, 10:48 PM
psychomill is on a distinguished road
sgfeed is what outputs G94/95.
but rather than arbitrarily removing the line, simply place a "#" symbol at the beginning of that line to and post to make sure you're getting what your're looking for.
# pbld, n$, sgfeed, e$
Many posts also use a variation of the "sgfeed" string so you may need to look for those if this doesn't do it for ya'...
It's just a part..... cutter still goes round and round....
Need to remove 4th axis from MV-40! Prism Maker Mori Mills 1 06-04-2010 07:37 AM
How to remove way covers? damae Bridgeport and Hardinge Mills 8 01-09-2006 03:50 PM
How to remove THK carriages? samualt DIY-CNC Router Table Machines 2 08-12-2004 06:04 PM
