we have alot of old mastercam version 7 parts that we need posted for one of our new machines. It is a five axis with a c axis that rotates in the xy plane and a A axis that rotates in the xz plane. we have severel old post for version 7 but am unable to figure out how to change the way the machine figures the angles. i thing this line is what is needing changed, but not sure to what pgetab # Get A and B axis angles b=90-atan2(vtoolz,vtoolx) a=atan(-vtooly/(sqrt(vtoolx^2+vtoolz^2))) pchkab whole post: # --------------------------------- #| MASTERCAM MP POST PROCESSOR | #| CNC Software, Inc. | #| Control Model: Cincinnati | #| Machine Model: v30 | #| PST File Name: MPCINC.PST/TXT | #| Executable : MP.EXE 3.06 | # --------------------------------- # # --------------- #| REVISION LOG | # ------------------------------------------------------------------------ # Programmers Note: # CNC 5/12/94 - Initial post setup for Mill5 # 1.0 Jph 08/19/94 Initial source control check-in # 1.1 jph 08/24/94 Correct coolant text # 1.2 jph 09/02/94 Ques. 86. was 0.2 delay # 1.3 pdr 09/06/94 Updated and corrected numbered questions # 1.4 pdr 09/07/94 Updated reverse post name (q 93.) # 1.5 bkr 10/02/95 fixed drill 5axis problem # 1.6 BPH MODIFIED TO RAMB PST # # --------------- #| FEATURES: | # ------------------------------------------------------------------------ # Users Note: # # -------------------------------------------------------------------------- # DEBUG/PROGRAM SWITCHES, debugging and program switches # -------------------------------------------------------------------------- bug1 : 1 # 1 = Output post to screen, 2 = output leader to screen bug2 : 0 # Append postline labels, non-zero is column position? bug3 : 0 # Append whatline no. to each NC line? bug4 : 0 # Append NCI line no. to each NC line? whatno : 0 # Do not perform whatline branches? rpd_typ_v7 : 1 #Use Version 7 style contour flags? strtool_v7 : 2 # Use Version 7 toolname, 1= path components, 2=string get_1004 : 1 # Find gcode 1004 with getnextop? # -------------------------------------------------------------------------- # FORMAT STATEMENTS - n=nonmodal, l=leading, t=trailing, i=inc, d=delta # -------------------------------------------------------------------------- fs 1 0.3 #Decimal, absolute, 4 place fs 2 0.4d #Decimal, delta fs 3 1 0 #Integer, not leading fs 4 2 0l #Integer, two leading fs 5 3 0l #Integer, three leading fs 6 4 0l #Integer, four leading fs 7 0.1 #Decimal, absolute, 1 place fs 8 0.2 #Decimal, absolute, 2 place fs 9 0.3 #Decimal, absolute, 3 place fs 10 0 4t #No decimal, absolute, four trailing fs 11 0.4t #Decimal, absolute, four trailing # -------------------------------------------------------------------------- # FORMAT ASSIGNMENTS # -------------------------------------------------------------------------- # Axis output formats - Linear # -------------------------------------------------------------------------- fmt X 1 xd # X delta axis position x+(vtoolx*(gauge+pivot)) fmt Y 1 yd # Y delta axis position y+(vtooly*(gauge+pivot)) fmt Z 1 zd # Z delta axis position z-(vtoolz*(gauge+pivot))-(gauge+pivot) fmt X 1 xdd # X axis position feed in and out of part along tool axis fmt Y 1 ydd # Y axis position " " fmt Z 1 zdd # Z axis position " " fmt X 1 xrd # X delta rapid position from tc xr+(vtoolx*(gauge+pivot)) fmt Y 1 yrd # Y delta rapid position from tc yr+(vtooly*(gauge+pivot)) fmt Z 1 zrd # Z delta rapid position from tc zr+(vtoolz*(gauge+pivot)) fmt X 1 xfd # X delta feedto position fmt Y 1 yfd # Y delta feedto position fmt Z 1 zfd # Z delta feedto position fmt X 1 x # X axis position fmt Y 1 y # Y axis position fmt Z 1 z # Z axis position fmt X 1 xr # X rapid position from tool change fmt Y 1 yr # Y rapid position from tool change fmt Z 1 zr # Z rapid position from tool change fmt X 1 xh # X home position fmt Y 1 yh # Y home position fmt Z 1 zh # Z home position # -------------------------------------------------------------------------- # Axis output formats - Circular # -------------------------------------------------------------------------- fmt I 2 i # Arc center description in X fmt J 2 j # Arc center description in Y fmt K 2 k # Arc center description in Z fmt R 1 arcrad # Arc Radius fmt R- 1 arcradm # Arc Radius over 180 degree sweep # -------------------------------------------------------------------------- # Axis output formats - 5 axis ( 2 tilting heads ) # -------------------------------------------------------------------------- fmt A 9 a # A axis mounted on b ( A axis rotation about x axis ) fmt B 9 b # B axis rotation ( B axis rotation about y axis) fmt A 9 aa # A axis mounted on b ( A axis rotation about x axis ) fmt B 9 bb # B axis rotation ( B axis rotation about y axis) fmt A 9 atv # A axis mounted on b ( A axis rotation about x axis ) fmt B 9 btv # B axis rotation ( B axis rotation about y axis) fmt 9 xangle fmt 9 yangle # -------------------------------------------------------------------------- # Program & Sequence number format # -------------------------------------------------------------------------- fmt "O" 6 progno # Program number fmt N 3 n # Sequence nos. # -------------------------------------------------------------------------- # Tool format # -------------------------------------------------------------------------- fmt T 3 t # Tool No fmt T 3 first_tool# First Tool Used (bldnxtool: yes) fmt T 3 next_tool # Next Tool Used (bldnxtool: yes) fmt D 3 diacomp # Diameter Offset No fmt H 3 tlngno # Length Offset No fmt "TOOL " 4 tnote # Note format fmt "DIA. OFF. - " 4 toffnote # Note format fmt "LENGTH - " 4 tlngnote # Note format fmt 11 tldia # Note format fmt "MSG, GAUGE LENGTH = " 11 gauge # Note format fmt "MSG, PIVOT DISTANCE = " 11 pivot # Note format fmt 3 awarn # Note format fmt 3 bwarn # Note format # -------------------------------------------------------------------------- # Spindle Speeds & Feedrate output formats # -------------------------------------------------------------------------- fmt S 6 speed # Spindle Speed fmt F 7 fr # Feedrate fmt F 7 frx # Tool tip Feedrate 5 axis fmt F 7 rapidfr # Rapid Feedrate fmt F 7 frdeg # Feedrate for rotary fmt M 3 gear # Gear range fmt 3 chrdif # character count differance # -------------------------------------------------------------------------- # Drill variable formats # -------------------------------------------------------------------------- fmt G 3 drillref # Initial / Reference Toggle (G98/G99) fmt P 1 dwell # Dwell fmt X 1 initx # Initial Height X Point ( 5 - axis drill ) fmt Y 1 inity # Initial Height Y Point ( 5 - axis drill ) fmt Z 1 initz # Initial Height Z Point ( 5 - axis drill ) fmt Z 1 initht # Initial Height fmt X 1 refx # Reference Height X Point ( 5 - axis drill ) fmt Y 1 refy # Reference Height Y Point ( 5 - axis drill ) fmt Z 1 refz # Reference Height Z Point ( 5 - axis drill ) fmt R 1 refht # Reference Height fmt X 1 depthx # Depth X Point ( 5 - axis drill ) fmt Y 1 depthy # Depth Y Point ( 5 - axis drill ) fmt Z 1 depthz # Depth Z Point ( 5 - axis drill ) fmt Z 1 depth # Depth fmt K 1 peck1 # First peck increment (positive) fmt 1 peck2 # Second or last peck (positive) fmt 1 peckclr # Safety distance fmt 1 retr # Retract height fmt F 8 frplunge # Plunge feedrate in drill cycles # -------------------------------------------------------------------------- # Miscellaneous output formats # -------------------------------------------------------------------------- fmt M 5 ssrange # Spindle Speed Range # -------------------------------------------------------------------------- # INITIALIZE - initialize system variables and define user variables # -------------------------------------------------------------------------- andflag : 0 # boolean modalflg : 0 # Molal Flag for coolant ask : 0 # Flag whether to ask question #1 arcoutput : 0 # 0 = IJK, 1 = R no sign, 2 = R signed neg. over 180 breakarcs : 1 #Break arcs, 0 = no, 1 = quadrants, 2 = 180deg. max arcs stagetool : 0 # 0 = Do not pre-stage tools, 1 = Stage tools use_gear : no # Set to yes to output gear range codes getnextop : yes # Get next OP code in NEXTOP? yes/no rotaxtyp : 4 # 5-axis toolplane rotation (not tombstone) omitround : yes # Omit initial rounding of -.NCI data? yes/no linarc : no # Linearize arcs? yes/no qtoolpln : no # MP386 - Enable tool plane option qtoolopt : no # MP386 - Enable tool optimization arctype : 1 # Arc center 1=abs, 2=St-Ctr, 3=Ctr-St, 4=unsigned inc. do_full_arc : 0 #Allow full circle output? 0=no, 1=yes helix_arc : 0 #Support helix arc output, 0=no, 1=all planes, 2=XY plane only bldnxtool : no # Build next tool table (**** WARNING ****) #(*** DO NOT SET TO YES IF DOING FIXED AXIS SURFACE CONTOURING ***) ldrcode : 65 # Leader character dec. equiv. (fleader outputs code) ncldr : 20 # No. of leader characters (fleader outputs code) nobrk : no # Omit breakup of x/y & z rapid moves omitcrlf : no # Omit CR/LF omitrefht : no # Don't use reference height on first non-canned Z move omitseq : no # Omit sequence no. omitz : no # Omit first Z movement for non-canned-cycles progname : 1 # Use uppercase for program name scalex : 1.0 # Scaling of .NCI at input - x,y,z,i,j,k scaley : 1.0 # Scaling of .NCI at input - x,y,z,i,j,k scalez : 1.0 # Scaling of .NCI at input - x,y,z,i,j,k seqmax : 9999 # Max. sequence no. skipmotest: no # Skip motion test in linear spaces : 0 # No. of spaces to add between fields tooltable : 0 # Read for tool table and pwrtt (**** WARNING ****) #(*** DO NOT SET TO YES IF DOING FIXED AXIS SURFACE CONTOURING ***) absswp : 0 # Absolute sweep drlgsel : -1 # Drill Select Initialize maxfrdeg : 999 # Limit for feed in deg/min absinc : 0 # Absolute/Incremental toggle for modality tcnt : 0 # Count the number of tool changes adelta : 0 # Calculation for deg/min ldelta : 0 # Calculation for deg/min zdelta : 0 # Calculation for deg/min alzdelta : 0 # Calculation for deg/min frdelta : 0 # Calculation for deg/min frdegcalc : 0 # Calculation for deg/min circum : 0 # Calculation for deg/min rotstrt : 1 # Flag for first rotary position rapidfr : 300 # Rapid feedrate tpln : 0 # 1=Tool Plane used 0=Tool plane not used atv : 0 # Tool angle from tool plane btv : 0 # Tool angle from tool plane xa : 0 # ya : 0 # za : 0 # lx : 0 # ly : 0 # lz : 0 # lxd : 0 # lyd : 0 # lzd : 0 # len1 : 0 # len2 : 0 # frx : 0 # 5-axis calculated feedrate frxnci : 0 # 5-axis nci feedrate xdd : 0 # 5-axis x value ydd : 0 # 5-axis y value zdd : 0 # 5-axis z value rpnlxdd : 0 # 5-axis rapid z plane x value rplnydd : 0 # 5-axis rapid z plane y value rplnzdd : 0 # 5-axis rapid z plane z value rl : 0 # retract to clearance plane length typ : 0 # 5-axis cut type prvx : 0 prvy : 0 prvz : 0 prvxd : 0 prvyd : 0 prvzd : 0 fedratmin : 0 # minimize feedrate chances gauge : 0 # tool gauge length chrexced : 3200000# Total number of charaters chrdif : 0 # difference between nchar and current char count aaxexced : 20 # A axis max angle baxexced : 20 # B axis max angle chka : 0 # A axis check variable chkb : 0 # B axis check variable atc : 0 # Tool change toggle d : 0 # A AXIS + or - arcerror : 0 # ERROR FLAG FOR ARCS OVER 650 RADIUS awarn : 0 # FLAG FOR A AXIS OVERTRAVEL bwarn : 0 # FLAG FOR B AXIS OVERTRAVEL vtlngx : 0 # vector tool length (used when 1014 line is used) vtlngy : 0 # vector tool length (used when 1014 line is used) vtlngz : 0 # vector tool length (used when 1014 line is used) pivot : 5. # Machine Pivot Distance # Parameters for lead-in and lead-out - 5 axis only # See LEADIN.MAN # ************************************************************** # ** DOT NOT CHANGE ANY OF THE LEAD-IN OR LEAD-OUT VALUES ** # ************************************************************** ldinl1 : .0000001 #lead-in 1 length (no output if zero) ldina1 : 90 #lead-in 1 angle (90 = along tool axis) ldinl2 : 0 #lead-in 2 length (no output if zero) ldina2 : 90 #lead-in 2 angle (90 = along tool axis) ldoutl1 : .0000001 #lead-out 1 length (no output if zero) ldouta1 : 90 #lead-out 1 angle (90 = along tool axis) ldoutl2 : 0 #lead-out 2 length (no output if zero) ldouta2 : 90 #lead-out 2 angle (90 = along tool axis) # -------------------------------------------------------------------------- # FORMULAS - global formulas # -------------------------------------------------------------------------- ssrange = mi3 # Gear Range Select speed = abs ( ss ) # Absolute spindle speed arcradm = arcrad # Negative arcrad spdlsel = fsg3(ss) # Spindle on selector based on pos. or neg. ss diacomp = tloffno+20 # Tool dia offset Number # -------------------------------------------------------------------------- # CANNED CYCLES - select long or short code # -------------------------------------------------------------------------- usecandrill : yes # Use canned cycle for drill usecanpeck : yes # Use canned cycle for Peck usecanchip : yes # Use canned cycle for Chip Break usecantap : yes # Use canned cycle for Tap usecanbore1 : yes # Use canned cycle for Bore1 usecanbore2 : yes # Use canned cycle for Bore2 usecanmisc1 : yes # Use canned cycle for Misc1 usecanmisc2 : yes # Use canned cycle for Misc2 # -------------------------------------------------------------------------- # Lookup table definitions - for math functions FLOOK and FRANGE # -------------------------------------------------------------------------- flktbl 1 3 # Lookup table definitions - table no. - no. entries 40 1000 # Low gear range 41 2500 # Med gear range 42 5000 # Hi gear range # -------------------------------------------------------------------------- # Strings - String labels must start with 's' - they are not pre-assigned # -------------------------------------------------------------------------- #Select operation note sop00 NULL # String definition sop01 2D-CONTOUR # " " sop02 3D-CONTOUR # " " sop03 DRILL/MISC # " " sop04 POCKET # " " sop05 RULED # " " sop06 2D-SWEPT # " " sop07 3D-SWEPT # " " sop08 REVOLVED # " " sop09 LOFT # " " sop10 COONS # " " sop11 TRIM # " " sop12 FILLET # " " sop13 ROUGH # " " sop14 OP14 # " " sop15 OP15 # " " sopnote # Target string fstrsel sop00 opcode sopnote # -------------------------------------------------------------------------- # Select motion G code sg00 G0 # Linear movement at rapid feedrate sg01 G1 # Linear movement at feedrate sg02 G2 # Circular interpolation CW sg03 G3 # Circular interpolation CCW sg04 # * sg05 # * sg06 # * sg07 # fillers sg08 # * sg09 # * sg10 # * sg11 G1 # 5 axis linear move sgcode # Target string fstrsel sg00 gcode sgcode # -------------------------------------------------------------------------- # Select incremental or absolute G code sg90 G90 # Absolute G code sg91 G91 # Incremental G code sgabsinc # Target string fstrsel sg90 absinc sgabsinc # -------------------------------------------------------------------------- # Select spindle start sm04 M4 # Spindle reverse sm05 M5 # Spindle off sm03 M3 # Spindle forward spdlon # Target string fstrsel sm04 spdlsel spdlon # -------------------------------------------------------------------------- # Cutter compensation code scc0 "" # Cutter compensation state not changed sg40 G40 # Cancel cutter compensation sg41 G41 # Cutter compensation left sg42 G42 # Cutter compensation right sg140 G40 # Last linear move cancel cutter comp (see note) # Note: to cancel comp after last move, remove G40 string # with sg140 and remove "#" at the postline call "pcancelcc" sccomp # Target string fstrsel scc0 ccomp sccomp # -------------------------------------------------------------------------- # Select work plane G code sg17 G17 # XY plane code sg19 G19 # XZ plane code sg18 G18 # YZ plane code sgplane # Target string fstrsel sg17 plane sgplane # -------------------------------------------------------------------------- # Work coordinate system sg50 G92 # Work coordinate system G code sg51 G92 # " " " " " sg52 G92 # " " " " " sg53 G92 # " " " " " sg54 G54 # " " " " " sg55 G55 # " " " " " sg56 G56 # " " " " " sg57 G57 # " " " " " sg58 G58 # " " " " " sg59 G59 # " " " " " sgwcs # Target string fstrsel sg50 mi1 sgwcs # -------------------------------------------------------------------------- # Canned drill cycle string select sg81 G81 # drill - no dwell sg81d G82 # drill - with dwell sg83 G83 # peck drill - no dwell sg83d G83 # peck drill - with dwell sg73 G73 # chip break - no dwell sg73d G73 # chip break - with dwell sg84 G84 # tap - no dwell sg84d G74 # tap - with dwell (selects left hand) sg85 G85 # bore #1 - no dwell sg85d G89 # bore #1 - with dwell sg86 G86 # bore #2 - no dwell sg86d G86 # bore #2 - with dwell sgm1 G81 # misc #1 - no dwell sgm1d G82 # misc #1 - with dwell sgm2 G81 # misc #2 - no dwell sgm2d G82 # misc #2 - with dwell sgdrill # Target string drlgsel = drillcyc * 2 + fsg2 ( dwell ) # 16 possible combinations: # drillcyc = 0..7 # dwell = 0 or non-zero (2 states) fstrsel sg81 drlgsel sgdrill # -------------------------------------------------------------------------- # Generate 'sgear' string # -------------------------------------------------------------------------- sgear0 M** # auto gear range sgear1 M41 # Low gear range sgear2 M42 # Med gear range sgear3 M43 # High gear range - selected in parameters by mi3 sgear fstrsel sgear0 gear sgear # -------------------------------------------------------------------------- # Generate 5 axis cut type string # -------------------------------------------------------------------------- styp0 UNKNOWN # Unknown tool path styp1 ZIG-ZAG # zig-zag tool path styp2 ONE-WAY # one-way tool path styp3 CIRCULAR # Circular tool path styp4 SWARF # Swarf tool path scutyp # Target String fstrsel styp0 cuttyp scutyp # -------------------------------------------------------------------------- # Question Definitions - set up questions to be posed during postprocessing # -------------------------------------------------------------------------- fq 1 gauge Enter gauge length for 5-axis tool path: fq 2 omitseq Omit line numbers (0=no, 1=yes): # -------------------------------------------------------------------------- # POSTLINES, USER-DEFINED - Postline labels start with 'p'. # End a line with ',' to continue on the next line. # End a line with ', e' to generate carriage return and linefeed. # -------------------------------------------------------------------------- # Program general output control, user defined # -------------------------------------------------------------------------- pinit # Initialize Vars prv_fr = 999.999 prv_frdeg = 999.999 prv_frplunge = 999.999 prv_x = 0 prv_y = 0 prv_z = 0 a = 0.00 b = 0.00 linarc = 0 rotstrt = 1 whatline = 0 pchkab # CHECK A & B AXIS FOR OVERTRAVEL chka = abs(a) chkb = abs(b) if chka > aaxexced , awarn = awarn+1 if chkb > baxexced , bwarn = bwarn+1 pgetab # Get A and B axis angles b=90-atan2(vtoolz,vtoolx) a=atan(-vtooly/(sqrt(vtoolx^2+vtoolz^2))) pchkab p5engage0 # 5 axis engage parameters NO TOOL CHANGE pgetab p5engage1 # 5 axis engage parameters at tool change gauge=t q1 ask = 1 n,"(",*gauge,")",e n,"(",~pivot,")",e n,"(",*scutyp," TOOL PATH)",e fr = 22.9 p5engage # 5 axis select engage type !xr,!yr andflag = 0 if atc = 0 , andflag = 1 # psof if ask = 0, andflag = andflag+1 if ask = 1, andflag = andflag+2 if atc = 1, andflag = andflag+4 # ptlchg0 if atc = 2, andflag = andflag+8 # ptlchg if andflag = 2, p5engage1 # ask for gauge length if andflag = 5, p5engage1 # ask for gauge length if andflag = 9, p5engage1 # ask for gauge length if andflag = 3, p5engage0 # don't ask for gauge length if andflag = 6, p5engage0 # don't ask for gauge length if andflag = 10, p5engage0 # don't ask for gauge length pcooloff # Coolant off "M" code output "M09" modalflg = 0 pcoolon # Coolant "M" code output andflag = 0 if coolant >= 1 , andflag = 1 if modalflg = 0, andflag = andflag+1 if andflag = 2, "M08" # Flood modalflg = 1 pcomment # Manual Entry - COMMENTS (on a block by itself) 1005,1006 n, "(MSG,", scomm, ")" presetab # Reset A and B axis to 0.00 if a <> 0, "A0." if b <> 0, "B0." presetab1 # Reset A and B axis to 0.00 andflag = gcode gcode = 0 if a <> 0, a = 0 if b <> 0, b = 0 n, sgcode, a, b, e gcode = andflag presetab0 # Reset A and B axis to 0.00 (at tool change / no tool change) andflag = 0 if prv_a <> 0 , andflag = 1 if prv_b <> 0 , andflag = andflag+1 if andflag > 0, presetab1 ptoolaxis # Get tool axis from tool plane if tpln = 1, p5engage andflag = 0 if tpln = 0 , andflag = 1 if nextop <> 11 , andflag = andflag+1 if andflag = 2, presetab0 andflag = 0 if atc = 0 , andflag = 1 if atc = 1 , andflag = 1 if atc = 2 , andflag = 1 if tpln = 0 , andflag = andflag+1 if nextop = 11 , andflag = andflag+1 if andflag = 3, p5engage pfixedax # FIXED AXIS CONTOURING CODE rl = (1/vtoolz)*(zh-zr) # retract to clearance plane lngth xd = xr+(vtoolx*(gauge+pivot+rl)) # 5 axis x rapid position yd = yr+(vtooly*(gauge+pivot+rl)) # 5 axis y rapid position n,xd,yd,e ptllnth # Output correct tool length comp codes if tpln = 0, n,xr,yr,e if nextop = 11, ptoolaxis,e if tpln = 1, ptoolaxis,e if tpln = 1, pfixedax andflag = 0 if tpln = 0 , andflag = 1 # no tool plane used if tpln = 1, andflag = 2 # tool plane used if nextop = 11, andflag = andflag+2 # 5-axis tool path if nextop < 11, andflag = andflag+4 # not 5-axis if andflag = 3, n, *zh, pcoolon,e if andflag = 5, n, *zr, pcoolon if andflag = 6, n, *zh, pcoolon,e if andflag = 4, "*** Cant use tool plane with 5-axis tool path ***" pabs # Absolute G code output absinc = 0 sgabsinc pinc # Incremental G code output absinc = 1 sgabsinc pfr # Feedrate W/O Negative Feedrates and if fr > 0, fr pfrx # Calculate Feedrate Changes on 5 -axis moves (tip speed) lx = x-prvx ly = y-prvy lz = z-prvz !x,!y,!z lxd = xd-prvxd lyd = yd-prvyd lzd = zd-prvzd len1 = sqrt((lx*lx)+(ly*ly)+(lz*lz)) len2 = sqrt((lxd*lxd)+(lyd*lyd)+(lzd*lzd)) frx = 10/(int(10*((fr*len2)/len1))) fedratmin = int(frx-prv_frx) if fedratmin = 0 , frx = prv_frx if frx > 0, fr = frx if whatline = 2 , fr = rapidfr #if whatline = 3 , *frx fr pcan # Canned text - cantext = 0, 1, 2, 3 if cantext = 1, "M01" #optional stop if cantext = 2, " " #user option if cantext = 3, " " #user option pentry # Feed to part from rapid z plane along tool axis pgetab gcode = 0 xrd = x+(vtoolx*(gauge+pivot+rl)) # 5 axis x rapid position yrd = y+(vtooly*(gauge+pivot+rl)) # 5 axis y rapid position zrd = zh+(vtoolz*(gauge+pivot))-(gauge+pivot) # 5 axis z rapid pos n,sgcode,xrd,yrd,zrd,e n,sgcode,a,b,e gcode = 11 prv_xfd = xrd prv_yfd = yrd prv_zfd = zrd xfd = xd #x+(prv_vtoolx*(gauge+pivot)) # 5 axis x feedin position yfd = yd #y+(prv_vtooly*(gauge+pivot)) # 5 axis y feedin position zfd = zd #z+(prv_vtoolz*(gauge+pivot))-(gauge+pivot) # 5 axis z feedin position fr = 60 n,sgcode,xfd,yfd,zfd,pfr prv_xd = xfd prv_yd = yfd prv_zd = zfd p5retract # 5 axis retract parameters a = 0 b = 0 n,sgcode,x,y,zh,a,b,fr pstZig # Start of 5 - axis Zig-zag "5-AXIS ZIG-ZAG START" pstOne # Start of 5 - axis One-way "5-AXIS ONE-WAY" pstCir # Start of 5 - axis Circular "5-AXIS CIRCULAR" pstSwf # Start of 5 - axis Swarf frxnci = fr pchkab pentry fr = frxnci !x,!y,!z pmidZig # Middle of 5 - axis Zig-zag (THERE IS NO MIDDLE ON ZIG-ZAG) pmidOne # Middle of 5 - axis One-way pmidCir # Middle of 5 - axis Circular pmidSwf # Middle of 5 - axis Swarf pgetab pchkab n,sgcode,xd,yd,zd,a,b,pfrx pendZig # end of 5 - axis Zig-zag "ZIG-ZAG END" pendOne # end of 5 - axis One-way "ONE-WAY END" pendCir # end of 5 - axis Circular "CIRCULAR END" pendSwf # end of 5 - axis Swarf pgetab pchkab n,sgcode,xd,yd,zd,a,b,pfrx,e fr = 100 #!rl prv_xrd = xd prv_yrd = yd prv_zrd = zd xrd = x+(vtoolx*(gauge+pivot+rl)) # 5 axis x rapid position yrd = y+(vtooly*(gauge+pivot+rl)) # 5 axis y rapid position zrd = zh+(vtoolz*(gauge+pivot))-(gauge+pivot) # 5 axis z rapid pos n,sgcode,xrd,yrd,zrd,a,b,pfr pseltyp # Select type of cut (5 - axis) rl = (1/vtoolz)*(zh-z) # retract to clearance plane lngth xd = x+(vtoolx*(gauge+pivot)) # 5 axis x position yd = y+(vtooly*(gauge+pivot)) # 5 axis y position zd = z+(vtoolz*(gauge+pivot))-(gauge+pivot) # 5 axis z position typ = 0 if cutpos = 1 , typ = typ + 10 if cutpos = 2 , typ = typ + 20 if cutpos = 3 , typ = typ + 30 if cuttyp = 1 , typ = typ + 1 if cuttyp = 2 , typ = typ + 2 if cuttyp = 3 , typ = typ + 3 if cuttyp = 4 , typ = typ + 4 if typ = 11 , gauge = t if typ = 11 , q1 if typ = 11 , pstZig # Start of 5 - axis Zig-zag if typ = 12 , pstOne # Start of 5 - axis One-way if typ = 13 , pstCir # Start of 5 - axis Circular if typ = 14 , pstSwf # Start of 5 - axis Swarf if typ = 21 , pmidZig # Middle of 5 - axis Zig-zag if typ = 22 , pmidOne # Middle of 5 - axis One-way if typ = 23 , pmidCir # Middle of 5 - axis Circular if typ = 24 , pmidSwf # Middle of 5 - axis Swarf if typ = 31 , pendZig # end of 5 - axis Zig-zag if typ = 32 , pendOne # end of 5 - axis One-way if typ = 33 , pendCir # end of 5 - axis Cricular if typ = 34 , pendSwf # end of 5 - axis Swarf # -------------------------------------------------------------------------- # Work coordinate output, user defined # -------------------------------------------------------------------------- pwcs # G54+ coordinate setting if mi1 >= 4, *sgwcs # -------------------------------------------------------------------------- # Gear selection control, user defined # -------------------------------------------------------------------------- pgear # Find spindle range gear = frange ( 1, speed ) *gear prange # Find spindle range if use_gear = 1, pgear # -------------------------------------------------------------------------- # Cutter comp. output control, user defined # -------------------------------------------------------------------------- pccdia2 # Cutter Compensation2 # if ccomp <> 4, *diacomp pccdia # Cutter Compensation # if ccomp <> 0, pccdia2 # -------------------------------------------------------------------------- # Axis substitution motion, user defined # -------------------------------------------------------------------------- pdrlxyrot # Substitute Axis X/Y with Rotary axis w/ drilling xangle = xs yangle = ys if rotaxis = 0, x, y if rotaxis = 1, y, xangle if rotaxis = 2, x, yangle pfrd # Feedrate W/O Negative Feedrates (deg/min) if frdeg > maxfrdeg, frdeg = maxfrdeg if frdelta > .5, *frdeg #Value to exceed to output frdeg # -------------------------------------------------------------------------- # Axis linear/circular motion, user defined # -------------------------------------------------------------------------- parctyp2 # Arc output for R w/ sign over 180 degree sweep absswp = abs ( sweep ) if absswp <= 180, *arcrad if absswp > 180.0001, *arcradm if arcrad > 650, arcerror = 1 parctyp1 # Arc output for R w/ no sign *arcrad parctyp0 # Arc output for IJK if plane = 0, *i, *j, k if plane = 1, i, *j, *k if plane = 2, *i, j, *k parctyp # Select the arc output if arcoutput = 0, parctyp0 if arcoutput = 1, parctyp1 if arcoutput = 2, parctyp2 prapidm # Linear line movement - at rapid feedrate n, sgplane, sccomp, pccdia, sgcode, x, y, z, pcan plinm # Linear line movement - at feedrate !coolant n, sccomp, pccdia, sgcode, x, y, z, pfr, pcan plin5ax # 5 - axis toolplane Linear line movement - at feedrate !coolant,!x,!y,!z xd = x+(vtoolx*(gauge+pivot)) # 5 axis x position yd = y+(vtooly*(gauge+pivot)) # 5 axis y position zd = z+(vtoolz*(gauge+pivot))-(gauge+pivot) # 5 axis z position n, sgcode, xd, yd, zd, a, b, pfr plin5ax1 # 5 - axis toolplane Linear line movement - at zhome plane !coolant,!x,!y,!z rl = (1/vtoolz)*(zh-zr) # retract to clearance plane lngth xd = x+(vtoolx*(gauge+pivot+rl)) # 5 axis x position yd = y+(vtooly*(gauge+pivot+rl)) # 5 axis y position zd = zh+(vtoolz*(gauge+pivot))-(gauge+pivot) # 5 axis z position n, sgcode, a, b, pfr pcirm # Circular interpolation n, sgplane, sccomp, pccdia, sgcode, x, y, z, parctyp, pfr, pcan # -------------------------------------------------------------------------- # Drilling, user defined # -------------------------------------------------------------------------- pdrillref # Determine G98 or G99 if initht <> refht, drillref = 98 if initht = refht, drillref = 99 if initht = zr, n, *initht, ptoolaxis, pcoolon,e if initht <> zr, n, *zr, ptoolaxis, pcoolon,e pdwell # Determine whether to output dwell if dwell <> 0, *dwell ptlchg0dr3 # Null tool change for drilling gcode = 6 if zr < prv_zr, n, sgcode, *xr, *yr, e if zr < prv_zr, n, sgcode, *zr, e ptlchg0dr2 # Null tool change for drilling if zr <> prv_zr, ptlchg0dr3 ptlchg0drl # Null tool change for drilling if prv_opcode = 3, ptlchg0dr2 # -------------------------------------------------------------------------- # POSTLINES, PRE-DEFINED - Postline names are pre-assigned. # Lines do not need to end with ', e' for carriage return and linefeed. # -------------------------------------------------------------------------- pq # get initial values q2 pheader # File header if progno = 0 ,progno = 1 ":", e "(MSG, PROGRAM NAME ", progname, ")" "(MSG, POSTED FOR CINCINNATI-3)" "(MSG,PROGRAMMER - DJA)" "(MSG, ", time,", ",month,"-",day,"-",year,")" psof0 # Start of file for tool zero psof psof # Start of file for non-zero tool number pinit atc = 0 !opcode if tcnt = 1, stagetool = 2 comment gcode = 0 n, *sgcode,"G70G90G94" ":", *t, "M06" n, *speed, *spdlon n, *sgcode, pabs, pwcs, *xh, *yh, speed, spdlon ptllnth # !coolant ptlchg0 # Null tool change atc = 1 whatline = 0 if opcode = 3, ptlchg0drl if prv_speed <> speed, n, speed if coolant <> prv_coolant, n, pcoolon !opcode, !zr ptoolaxis ptlchg # Tool change pinit gcode = 0 ask = 0 atc = 2 !opcode n, pcooloff presetab0 n, "G98", "Z24." n, "G90M05" ":", *t, "M06" comment n, *speed, *spdlon n, *sgcode, pabs, pwcs, *xr, *yr, speed, spdlon ptllnth pmx0 # Calculate tool axis # b=90-atan2(vtoolz,vtoolx) # a=atan(-vtooly/(sqrt(vtoolx^2+vtoolz^2))) pmx1 # Retract - first point of cut (reads leadin length and adjusts) if whatline = 2, pseltyp pmx2 # Rapid to start of cut at retract height pmx # 5-Axis tool path pseltyp peof0 # End of file for tool zero peof peof # End of file for non-zero tool n, pcooloff n, "G98", "Z24." n, "G90", "M5" n, "G0", "X0.", "Y0.", "A0.", "B0." n, pabs n, "M2" if nchar > chrexced , chrdif = nchar-chrexced if nchar > chrexced , "(** WARNING! **)","(number or characters ","exceeded by ",chrdif,")" if awarn > 0 , "** WARNING **"," EXCEEDED A TRAVEL",awarn,"TIMES" if bwarn > 0 , "** WARNING **"," EXCEEDED B TRAVEL",bwarn,"TIMES" if arcerror = 1 , "** WARNING **","(exceeded max radius of 650 R)" # -------------------------------------------------------------------------- # Axis motion # -------------------------------------------------------------------------- prot0 # Toolplane postline - Custom post required tpln = 0 prot # Toolplane postline - Custom post required prot0 prapid # Linear line movement - at rapid feedrate if tpln = 0, prapidm pzrapid3 # 3-axis Linear movement in Z axis only - at rapid feedrate n, sgcode, z pzrapid5 # 5-axis using tool plane return to clearance plane !coolant,!x,!y rl = (1/vtoolz)*(zh-prv_z) # retract to clearance plane lngth xd = x+(vtoolx*(gauge+pivot+rl)) # 5 axis x position yd = y+(vtooly*(gauge+pivot+rl)) # 5 axis y position zd = zh+(vtoolz*(gauge+pivot))-(gauge+pivot) # 5 axis z position n, sgcode, xd, yd, zd, pfr pzrapid # Linear movement in Z axis only - at rapid feedrate if tpln = 0, pzrapid3 if tpln = 1, pzrapid5 plin1 # First linear movement after SOF/toolchg, whatno must be set if tpln = 0, plinm if tpln = 1, plin5ax1 plin2 # Second linear movement after SOF, whatno must be set plin plin # Linear line movement - at feedrate if tpln = 0, plinm if tpln = 1, plin5ax pz # Linear movement in Z axis only - at feedrate n, sgcode, z, pfr pcir1 # First circular movement after SOF, whatno must be set pcir pcir2 # Second circular movement after SOF, whatno must be set pcir pcir # Circular interpolation if rotaxis = 0, pcirm # -------------------------------------------------------------------------- # Drilling # -------------------------------------------------------------------------- pdrill3 # 3 - axis drilling # pdrillref !coolant n, pdrlxyrot z = refht - depth n, *sgdrill, pdrlxyrot, z, *refht, pdwell, *frplunge pdrill5 # 5 - axis drilling !depth,!refht,!initht,!fr gauge = t q1 n,"(",*gauge,")",e n,"(",*pivot,")",e n,"(MSG, 5-AXIS DRILL TOOL PATH)",e n, *zh, pcoolon,e initx = u+(vtoolx*(gauge+pivot+initht-refht)) inity = v+(vtooly*(gauge+pivot+initht-refht)) initz = w+(vtoolz*(gauge+pivot+initht-refht))-(gauge+pivot) refx = u+(vtoolx*(gauge+pivot)) refy = v+(vtooly*(gauge+pivot)) refz = w+(vtoolz*(gauge+pivot))-(gauge+pivot) depthx = u+(vtoolx*(gauge+pivot+depth-refht)) depthy = v+(vtooly*(gauge+pivot+depth-refht)) depthz = w+(vtoolz*(gauge+pivot+depth-refht))-(gauge+pivot) b=90-atan2(vtoolz,vtooly) a=atan(-vtoolx/(sqrt(vtooly^2+vtoolz^2))) pchkab frxnci = fr gcode = 0 n,sgcode,initx,inity n,sgcode,a,b gcode = 11 fr = 100 n,sgcode,*initx,*inity,*initz,fr,e n,sgcode,*refx,*refy,*refz,fr,e fr = frxnci n,sgcode,*depthx,*depthy,*depthz,fr,e n,sgcode,*refx,*refy,*refz,fr,e fr = 100 n,sgcode,*initx,*inity,*initz,fr,e fr = frxnci pdrill # Canned Drill Cycle if drill5 = 0, pdrill3 if drill5 > 0, pdrill5 ppeck # Canned Peck Drill Cycle # pdrillref n, pdrlxyrot z = refht - depth n, *sgdrill, pdrlxyrot, z, *refht, *peck1, "J1", *frplunge pchpbrk # Canned Chip Break Cycle # pdrillref n, *sgdrill, pdrlxyrot, *depth, *refht, *peck1, *frplunge ptap # Canned Tap Cycle # pdrillref n, pdrlxyrot z = refht - depth n, *sgdrill, pdrlxyrot, z, *refht, *frplunge pbore1 # Canned Bore #1 Cycle # pdrillref z = refht - depth n, *sgdrill, pdrlxyrot, z, *refht, pdwell, *frplunge pbore2 # Canned Bore #2 Cycle # pdrillref z = refht - depth n, *sgdrill, pdrlxyrot, z, *refht, *frplunge pmisc1 # Canned Misc #1 Cycle (User Option) pdrill pmisc2 # Canned Misc #2 Cycle (User Option) pdrill pdrill_25 # Canned Drill Cycle 5-axis initx = u+(vtoolx*(gauge+pivot+initht-refht)) inity = v+(vtooly*(gauge+pivot+initht-refht)) initz = w+(vtoolz*(gauge+pivot+initht-refht))-(gauge+pivot) refx = u+(vtoolx*(gauge+pivot)) refy = v+(vtooly*(gauge+pivot)) refz = w+(vtoolz*(gauge+pivot))-(gauge+pivot) depthx = u+(vtoolx*(gauge+pivot+depth-refht)) depthy = v+(vtooly*(gauge+pivot+depth-refht)) depthz = w+(vtoolz*(gauge+pivot+depth-refht))-(gauge+pivot) b=90-atan2(vtoolz,vtoolx) a=atan(-vtooly/(sqrt(vtoolx^2+vtoolz^2))) pchkab frxnci = fr gcode = 0 n,sgcode,a,b,e gcode = 11 fr = 100 n,sgcode,*initx,*inity,*initz,fr,e n,sgcode,*refx,*refy,*refz,fr,e fr = frxnci n,sgcode,*depthx,*depthy,*depthz,fr,e n,sgcode,*refx,*refy,*refz,fr,e fr = 100 n,sgcode,*initx,*inity,*initz,fr,e fr = frxnci pdrill_23 # Canned Drill Cycle 3-axis n,x,y,refht pdrill_2 # Canned Drill Cycle if drill5 = 0, pdrill_23 if drill5 > 0, pdrill_25 ppeck_2 # Canned Peck Drill Cycle pdrill_2 pchpbrk_2 # Canned Chip Break Cycle pdrill_2 ptap_2 # Canned Tap Cycle pdrill_2 pbore1_2 # Canned Bore #1 Cycle pdrill_2 pbore2_2 # Canned Bore #2 Cycle pdrill_2 pmisc1_2 # Canned Misc #1 Cycle pdrill_2 pmisc2_2 # Canned Misc #2 Cycle pdrill_2 pcandc3 # Cancel canned drill cycle 3-axis n,"G80" pcandc5 # Cancel canned drill cycle 5-axis !gcode gcode = 0 a = 0 b = 0 n,sgcode,a,b,zfd pcanceldc # Cancel canned drill cycle if drill5 = 0, pcandc3 if drill5 > 0, pcandc5 pcancelcc # Cancel cutter comp. #n, "G40" pwrtt # Write tool table, scans entire file, null tools are negative tnote = t toffnote = tloffno tlngnote = tlngno if t >= 0, "(", *tnote," ", *tldia, " DIA. ", *sopnote, ")" if t >= 0, tcnt = tcnt + 1 # -------------------------------------------------------------------------- # Numbered questions for Mastercam -- Used by Mill 5 # -------------------------------------------------------------------------- 38. Rapid feedrate? 300.0 1538. Rapid feedrate (metric)? 10000.0 70. Chaining tolerance? 0.0002 74. Minimum arc length? 0.0002 #76. Startup configuration file? MILL5 78. Name of startup C-Hook program? NONE 79. Name of exit C-Hook program? NONE 80. Communications port number for receive and transmit (1 or 2) ? 1 81. Data rate (110,150,300,600,1200,2400,4800,9600,14400,19200,38400)? 4800 82. Parity (E/O/N)? E 83. Data bits (7 or 8)? 7 84. Stop bits (1 or 2)? 2 85. Strip line feeds? y 86. Delay after end of line (seconds)? 0.1 87. Ascii, Eia, or Binary (A/E/B)? A 88. Echo keyboard to screen in terminal emulation? n 89. Strip carriage returns? N 90. Drive and subdirectory for NC files?C:\ANTONIO'S\mill7\NC 91. Name of executable post processor? MP 92. Name of reverse post processor? RP 93. Reverse post PST file name? RPFAN 97. Number of places after decimal for analyze (2-6)? 5 98. Number of places after decimal for NCI files (3-7)? 7 99. System tolerance? 0.000005 100. Number of places BEFORE the decimal point for sequence numbers? 3 101. Number of places AFTER the decimal point for sequence numbers? 0 103. Maximum spindle speed? 3500 104. Default starting sequence number? 1 105. Default sequence number increment? 1 107. Average time for tool change (seconds)? 2.0 #110. Default tool library? TOOLS.MTL 111. Maximum number of tools? 100 161. Enable Home Position button? y 162. Enable Reference Point button? n 163. Enable Misc. Values button? y 164. Enable Rotary Axis button? n 165. Enable Tool Plane button? n 166. Enable Construction Plane button? n 167. Enable Tool Display button? y 168. Check tplane during automatic work origin creation? n 190. Display the tool? y 191. Display the toolpath? y 192. Default tool display: 1 = animated, 2 = static? 2 193. Default tool display: 1 = interpolate, 2 = endpoints? 2 194. Default tool display: 1 = run, 2 = step? 1 195. Default tool display step size? 0.1 196. Default tool display delay? 0.0 197. Repaint the toolpath? Y 201. Default Misc. Real [1]? 301. Default Misc. Int. [1]? 0 9999. General NC parameters 1001. Display solid toolpath (y = solid, n = striped)? y 1002. Cutter compensation in computer (L, R or blank)? L 1003. Compensate to tip? Y 1004. Amount of stock to leave? 0.0 1005. Cutter compensation in control (L, R or blank)?L 1006. Default tool plane (0 = none, 1 = T, 2 = F, 5 = S)? 0 1007. Tool origin: X? 0.0 1008. Tool origin: Y? 0.0 1009. Tool origin: Z? 0.0 1010. Rotary axis (X, Y or blank)?N 1011. Rotary axis diameter? 2.0 1012. Rapid depth? 0.0 1014. Roll cutter around (0 = no, 1 = sharp, 2 = all) corners? 2 1015. Coolant on? Y 1016. Number of times to step and repeat in X? 1 1017. Amount to step and repeat in X? 0.0 1018. Number of times to step and repeat in Y? 1 1019. Amount to step and repeat in Y? 0.0 1020. Number roughing depth cuts? 0 1021. Amount of roughing depth cut? 0.0 1022. Number of finishing depth cuts? 0 1023. Amount of finishing depth cut? 0.0 1024. Entry line length? 0.05 1025. Entry arc radius? 0.0 1026. Entry arc angle? 90.0 1027. Use "infinite" look-ahead in cutter compensation? y 1028. Entry line direction (1 = perpendicular, 0 = parallel)? 1 9999. Contour 1040. Number of roughing cuts? 0 1041. Rough cut amount? 0.0 1042. Number of finish cuts? 1 1043. Finish cut amount? 0.0 9999. Drilling 1050. Drilling cycle (0=drill,1=peck,2=c.b.,3=tap,4=b1,5=b2,6=m1,7=m2)? 0 1051. Dwell? 0.0 1052. Initial height? 6.0 1053. Reference height? 0.05 1054. Use incremental depth? n 1055. Incremental drill depth? 0.0 1056. First peck increment? 0.1 1057. Subsequent peck increment? 0.1 1058. Peck clearance? 0.01 1059. Retraction amount? 0.0 9999. Pocket 1070. Cutting method (0 = zig-zag, 1 = spiral out, 2 = spiral in)? 0 1071. Find multiple collapse points for spiral pocket? y 1072. Roughing angle for zig-zag pocketing? 0.0 1073. Roughing step over? 0.1 1074. Number of finish passes? 0 1075. Finish pass step over? 0.0 9999. Ruled surface 1080. Cutting method (0 = zig-zag, 1 = one way, 2 = circ., 3 = EDM)? 0 1081. Across cut distance? 0.05 1082. Taper angle for Wire EDM cutting? 0.0 1083. Constant z cutting? n 1084. Initial z for constant z cutting? 0.0 1085. Final z for constant z cutting? -1.0 1086. Z increment for constant z cutting? -0.25 9999. Swept surface 1095. Translate the across contour for 3d swept? n 1096. Along cut distance? 0.1 1097. Across cut distance? 0.1 1098. Cutting method (0=zig,1=one w.,2=circ.,3=5 zig,4=5 one,5= 5 cir)? 0 1099. Cutting direction (0 = along, 1 = across)? 0 9999. Surface of revolution 1110. Step over? 0.1 1111. Concave (y/n)? y 1112. Retract to the reference height? n 1113. Reference height for surface of revolution? 0.1 9999. Projection 1120. Minimum step size? 0.001 1121. Maximum step size? 100.0 1122. Maximum error? 0.0002 1123. Step over for project onto surface? 0.02 1124. Does the toolpath lie partially off the surface? n 9999. Lofted surface 1130. Along cut distance? 0.1 1131. Across cut distance? 0.1 1132. Cutting method (0=zig,1=one w.,2=circ,3=zig5,4=one5,5=circ5)? 0 1133. Cutting direction (0 = along, 1 = across)? 0 9999. Coons 1140. Along cut distance? 0.1 1141. Across cut distance? 0.1 1142. Blending (0 = lin, 1 = par, 2 = cubic, 3 = cubic w. slope match)? 0 1143. Cutting method (0=zig,1=one w.,2=circ,3=zig5,4=one5,5=circ5)? 0 1144. Cutting direction (0 = along, 1 = across)? 0 1145. Number of along patches? 1 1146. Number of across patches? 1 9999. NURBS surface 1160. File options (1 = surface, 2 = ofs, 3 = both, 4 = nci, 5 = ofs & nci)? 4 1161. Stepping method (1 = distance, 2 = chord. dev and scallop height)? 2 1162. Step distance in along direction? 0.05 1163. Step distance in across direction? 0.05 1164. Maximum chordal deviation? 0.001 1165. Maximum scallop height? 0.001 1166. Cutting method (0 = zig zag, 1 = one way, 2 = circular)? 0 1167. Cutting direction (0 = along, 1 = across)? 0 9999. Fillet 1180. Starting fillet radius? 0.1 1181. End fillet radius? 1.0 1182. Surface selection (1=lFf,2=lF,3=fF,4=F,5=l,6=f)? 1 1183. Cutting method (0 = one way, 1 = zig zag)? 1 9999. Roughing 1190. Cutting direction (-1 = CCW, 1 = CW)? -1 1191. 1 = Pocket at each level, 2 = contour only? 2 1192. 1 = mountain, -1 = cavity? 1 1193. Cut top down (y/n)? y 1194. Z step increment? 0.1 1195. Top clearance? 0.01 1196. Stock to leave on bottom? 0.05 9999. Recomp 1200. Write the NCI file? y 1201. Cutting method (0=zig,1=one w.,2=circ.,3=5 zig,4=5 one,5= 5 cir)? 0 1202. Cutting direction (0 = along, 1 = across)? 0 9999. Reverse surface 1210. Surfaces to reverse (1 = surf and ofs, 2 = surf, 3 = ofs)? 1 1211. Write the NCI file (y/n)? y 1212. Cutting method (0=zig,1=one w.,2=circ.,3=5 zig,4=5 one,5= 5 cir)? 0 9999. Gouge checking 1220. Perform gouge check in the along direction (y/n)? y 1221. Method for gouge elimination (1 = closest approach, 2 = proj. plane)? 1 1500. Chook to execute from 'Misc. values' button? 1501. Insert parameter information in the ascii NCI? n 1502. Write operation information to binary file (.ops)? n 1520. Display a warning when cutter compensation in control simulation finds an error? n # Do NOT manually change the answer for Q.1999 ! 1999. Product major version number that post supports? 9 3001. Machine acceleration? 2 3002. timing size? .1 # -------------------------------------------------------------------------- # Default Miscellaneous Real Values # -------------------------------------------------------------------------- 201. Default miscellaneous real variable 1 (mr1)? 0.0 202. Default miscellaneous real variable 2 (mr2)? 0.0 203. Default miscellaneous real variable 3 (mr3)? 0.0 204. Default miscellaneous real variable 4 (mr4)? 0.0 205. Default miscellaneous real variable 5 (mr5)? 0.0 206. Default miscellaneous real variable 6 (mr6)? 0.0 207. Default miscellaneous real variable 7 (mr7)? 0.0 208. Default miscellaneous real variable 8 (mr8)? 0.0 209. Default miscellaneous real variable 9 (mr9)? 0.0 210. Default miscellaneous real variable 10 (mr10)? 0.0 # -------------------------------------------------------------------------- # Default Miscellaneous Real Values (METRIC) # -------------------------------------------------------------------------- 1601. Default miscellaneous real variable 1 (mr1) (metric)? 0.0 1602. Default miscellaneous real variable 2 (mr2) (metric)? 0.0 1603. Default miscellaneous real variable 3 (mr3) (metric)? 0.0 1604. Default miscellaneous real variable 4 (mr4) (metric)? 0.0 1605. Default miscellaneous real variable 5 (mr5) (metric)? 0.0 1606. Default miscellaneous real variable 6 (mr6) (metric)? 0.0 1607. Default miscellaneous real variable 7 (mr7) (metric)? 0.0 1608. Default miscellaneous real variable 8 (mr8) (metric)? 0.0 1609. Default miscellaneous real variable 9 (mr9) (metric)? 0.0 1610. Default miscellaneous real variable 10 (mr10) (metric)? 0.0 # -------------------------------------------------------------------------- # Enable/Disable Miscellaneous Real Variable switches # -------------------------------------------------------------------------- 1611. Enable miscellaneous real variable 1? y 1612. Enable miscellaneous real variable 2? y 1613. Enable miscellaneous real variable 3? y 1614. Enable miscellaneous real variable 4? y 1615. Enable miscellaneous real variable 5? y 1616. Enable miscellaneous real variable 6? y 1617. Enable miscellaneous real variable 7? y 1618. Enable miscellaneous real variable 8? y 1619. Enable miscellaneous real variable 9? y 1620. Enable miscellaneous real variable 10? y # -------------------------------------------------------------------------- # Default Miscellaneous Integer Values # -------------------------------------------------------------------------- 301. Default Work Coordinate System (0 thru 3=G92, 4 thru 9=G54-G59)? 1 302. Miscellaneous integer variable 2 (mi2)? 0 303. Miscellaneous integer variable 3 (mi3)? 0 304. Miscellaneous integer variable 4 (mi4)? 0 305. Miscellaneous integer variable 5 (mi5)? 0 306. Miscellaneous integer variable 6 (mi6)? 0 307. Miscellaneous integer variable 7 (mi7)? 0 308. Miscellaneous integer variable 8 (mi8)? 0 309. Miscellaneous integer variable 9 (mi9)? 0 310. Miscellaneous integer variable 10 (mi10)? 0 # -------------------------------------------------------------------------- # Enable/Disable Miscellaneous Integer Variable switches # -------------------------------------------------------------------------- 1621. Enable miscellaneous integer variable 1? y 1622. Enable miscellaneous integer variable 2? y 1623. Enable miscellaneous integer variable 3? y 1624. Enable miscellaneous integer variable 4? y 1625. Enable miscellaneous integer variable 5? y 1626. Enable miscellaneous integer variable 6? y 1627. Enable miscellaneous integer variable 7? y 1628. Enable miscellaneous integer variable 8? y 1629. Enable miscellaneous integer variable 9? y 1630. Enable miscellaneous integer variable 10? y # -------------------------------------------------------------------------- # Configuration File association parameters (default is "y") # -------------------------------------------------------------------------- #400. Name of associated cfg file? 401. Read SYSTEM COLORS section? y 402. Read ALLOCATIONS section? y 403. Read TOLERANCES section? y 404. Read DATA PATHS section? y 405. Read COMMUNICATIONS section? y 406. Read DRAFT SETTINGS section? y 407. Read MISCELLANEOUS section? y 408. Read NC SETTINGS section? y 409. Read DIALOG SCRIPTS section? y 410. Read DESIGN SETTINGS section? y 411. Read PLOTTER SETTINGS section? y 412. Read ALT-KEY ASSIGNMENTS section? y 413. Read CAD section? y 414. Read START/EXIT section? y 415. Read SCREEN section? y 416. Read FILE NAMES section? y |
| A couple questions... 1) Are you still using Version 7 to create programs? 2) What exactly is wrong with the output that you need to change the way the angles are calculated?
__________________ It's just a part..... cutter still goes round and round.... |
| No longer using version 7, just have bunch of old programs we would still like to make use of. The post i posted is for a machine with a A and B axis with limits set to 25 degrees and are about the x and y plane. I need one to calculate it with the c axis about the z. |
| Tags |
| mastercam, post |
| Need help editing post | bugzpulverizer | Post Processors for MC | 5 | 08-25-2008 11:35 AM |
| Need Help!- Editing post | WingNutz | Mastercam | 1 | 08-14-2008 09:43 PM |
| Post Editing Help! | jeffliu2 | GibbsCAM | 4 | 02-25-2008 07:24 PM |
| Help with Editing a Post | Chris Rand | Post Processor Files | 6 | 06-05-2006 03:07 PM |
