Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > Mastercam > Post Processors for MC
Old 03-27-2010, 10:35 AM
Bala is on a distinguished road
couldn't activate the debugger
I activate the debugger on MCAM3 utility but I can't get the icon for debugging on the post manager. can any one help me with this please?
Old 03-29-2010, 10:57 AM
littlebrewman is on a distinguished road
I have had the same problem on X4 can anyone help on this?
Old 03-29-2010, 11:04 PM
psychomill is on a distinguished road
By "Utility"... you went through the START menu function right? The old switch doesn't work in X3 and X4.
Go to your Windoze Start menu then Programs > Mastercam X(your version) > MCAMX Control Panel Applet. Once there, expand the dialog and select "Post support". Select "enable" and close the window using the check mark.
Open your MCX and when you post, you'll see a little "bug" in the bottom left corner of the pop up. Select the 'bug'.....
X4 is very enhanced so you may want to read over the Help files to get around.
It's just a part..... cutter still goes round and round....
Old 04-04-2010, 06:09 PM
got the bugger to work in X4 just neeed to sit down and learn how to use it.
How do I activate the HPCC??? jsmith2232 Mori Mills 3 02-24-2011 09:39 AM
Problem- Post Debugger littlebrewman Mastercam 1 02-23-2010 08:33 PM
Newbie- Using VB as a G-Code debugger / editor BonusODJ Visual Basic 1 12-22-2008 01:49 AM
Need Help!- Hotkey to activate plugin? bigz1 Screen Layouts, Post Processors & Misc 6 04-24-2008 01:19 PM
How to activate part timer on 10t? Crashmaster Fanuc 12 09-20-2007 07:05 PM
