Results 1 to 7 of 7
Thread: I need a little help setting up Mastercam X4 with Mach3
    May 2007
    Since this is my first post, I thought I would introduce myself. I am a high school phyisics teacher who runs a robotics club (tahomarobotics.org). Unfortunately, I have no formal training in CNC. I am self taught and have taught my students enough so that they can do a fair amount of 2.5D milling. We have been using Mastercam X4 with a small TechnoDavinci 3 axis router for about 6 months.
    We recently purchased a large mill from Industrial Hobbies and are excited to use it for our larger parts. I have a few questions regarding the set up within Mastercam.
    First, I went to the ArtSoft website and downloaded the Mastercam post processor file and put it in the mcamx\mill\posts directory.
    However, I am a little confused on which machine to choose in mastercam which will use the post. It appears that I need a .MMD file and a .control file as well to put in the mcamx\cnc_machines directory. I'm assuming these files would make use of the post that I downloaded for Mach3.
    My question is, do I need to write these files myself or are there files that I can download?
    I hope that I have articulated my issue clearly. Please excuse my ignorance. Any help would be greatly appreciated. Thanks.
    Darren
    Jun 2008
    Darren,
    X4 posts have 3 files *.mmd, *.control and *.pst.
    May 2007
    Ok, thank you. I was able to convert the .pst file into both the needed .control and .mmd files using mastercam.
    Jun 2007
    Malaysia
    Hi 8ABagel,
    Hope you doing well Mastercam X4, if you have any doubts still you can contact:
    camscad@hotmail.com
    Rao
    Apr 2010
    Another X4 post processor question
    Quote Originally Posted by 8ABagel View Post
    I have also downloaded the three files for the post processor but I dont know exactly where to put the files, that is what files in what folder.
    Currently I am using the fanuc post processor and it seems to be working ok but I know its not right.
    Thanks for any help.
    Flies Superman's Avatar
    Dec 2008
    Krypton
    Generally, the machine and control definition files reside together and are placed in the C;\Mcamx\cnc_machines\ dir, and the post in the C:\Mcamx\"machine type"\posts\ dir ---(machine type meaning mill, lathe or wire). This is the standard layout on instalation.
    Placing them is not overly critical, as when you define the machine (this one should reside in the cnc_machines dir ), you actually browse to attach both the contol file and the post, the path to these files is recorded in the full filename, if you later move these files, then the machine definition file needs to be updated with the correct path
    Nov 2010
    I would like to know how to modify the post for the 3 axis vmc Fanuc(Generic POST) in MC X4. I just want to add some g code lines at the beginning of the program, each tool change, and the ending of the program.
    1. Setting up Spindle Control in mach3
      By UKRobotics in forum Mach Mill
      Last Post: 10-18-2009, 05:34 PM
    2. Setting up Mach3 + CNC4PC BOB + VSD-A-r2
      By ftec in forum Granite Devices
      Last Post: 10-13-2009, 07:04 PM
    3. Tool setting mach3
      By kayo in forum Mach Software (ArtSoft software)
      Last Post: 12-22-2008, 06:20 PM
    4. Basic Q's / Setting up Mach3
      By Thorpydo in forum Mach Mill
      Last Post: 09-24-2008, 08:25 PM
    5. setting 0,0,0 in Mach3 Mill
      By sdantonio in forum Mach Mill
      Last Post: 04-01-2007, 01:30 PM
