Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Post Processor Files
Post Processor Files Discuss post processor files here!
Old 01-20-2010, 11:33 AM
metanol is on a distinguished road
postprocessor for hsm-modal
Hello,
i would kindly ask you if someone could provide me the postprocessor for WorkNC v19 for EEW hsm-modal 5-ax CNC mashine. Cnc was build in 1998, and has typ1 osa/cc220 bosch controller.
Many thanks,
Meta
Old 01-20-2010, 11:45 AM
CNCRim's Avatar
Postprocessor is the heart money making of CAD/CAM, and I is require a lot brain power special 5ax. I doubt you will have any luck to ask....... because It's very expensive.
Old 01-20-2010, 12:39 PM
Thanks for your reply.
For my old machine, it was from morbidelli, I have make my own postprocessor. You know, the file that is located in worknc/pospro/ folder and has .dat extension.
Old 02-01-2010, 08:10 PM
Shawn Schwartz is on a distinguished road
Metanol,
You should be able to get this file from your local WorkNC dealer. It is important to get a post from someone who is able to configure this correctly or you may end up crashing your machine. I cannot speak for the reseller in your area but here in the US it is not a lot of money to get this post from the propper place and you can feel comfortable that it will be correct! Hope this helps!
Shawn
[IMG] code is Off
Need Help!- MODAL IS OUT OF G80 ERROR erdemkaraman General Metal Working Machines 4 03-25-2008 08:10 AM
Non-modal G00,G01...G03 cncuser1 Mastercam 4 05-30-2007 01:39 PM
changing values to non modal mmurning Post Processors for MC 5 12-06-2006 07:11 PM
Mach2 G02, G03 Modal? miljnor Mach Software (ArtSoft software) 3 04-27-2005 10:06 PM
Coordinates modal and / for rapids HuFlungDung OneCNC 6 04-04-2003 09:42 PM
