| Post Processor Files Discuss post processor files here! |
This pertains to lathe. The generic post works great for me except when threading. It posts out an "E" instead of an "F". Once I edit to F everything runs good. It only puts the E when threading. All other operations use an F. So where in the post can I change to get the F I need? Phoodieman |
| it easy to do . open the post -> goto here # -------------------------------------------------------------------------- # General Output Settings # -------------------------------------------------------------------------- force_wcs : yes$ #Force WCS output at every toolchange? progname$ : 1 #Use uppercase for program name css_start_rpm : yes$ #Do direct RPM spindle start prior to CSS? css_end_rpm : yes$ #Do direct RPM spindle prior to Retract? prog_stop : 1 #Program stop at toolchange: 0=None, 1=M01, 2 = M00 tool_info : 3 #Output tool information? #0 = Off - Do not output any tool comments or tool table #1 = Tool comments only #2 = Tool table only #3 = Tool comments and tool table use_pitch : 0 #0 = Use feed for tapping (force Feed/Min), 1 = Use pitch for tapping (force Feed/Rev) rigid_tap : 1 #0 = Floating tap output #1 = Rigid tap output (Set parameter 5200 bit 0 to 1 for rigid) #(Set M code for rigid tap in parameter 5210) tap_feed : 1 #0 = 2/1 (in/mm) decimal places, 1 = 4/3 (in/mm) decimal places thread_address :1 #Thread pitch address for lathe threading, 0 = Use F, 1 = Use E change number 1 to 0 at red color, you will got F instead of E . hope it will help . |
# -------------------------------------------------------------------------- # General Output Settings # -------------------------------------------------------------------------- sub_level : 1 #Enable automatic subprogram support breakarcs : 1 #Break arcs, 0 = no, 1 = quadrants, 2 = 180deg. max arcs arcoutput : 1 #0 = IJK, 1 = R no sign, 2 = R signed neg. over 180 arctype : 2 #Arc center 1=abs, 2=St-Ctr, 3=Ctr-St, 4=unsigned inc. do_full_arc : 0 #Allow full circle output? 0=no, 1=yes helix_arc : 0 #Support helix arc output, 0=no, 1=all planes, 2=XY plane only arccheck : 1 #Convert small arcs to linear atol : .01 #Angularity tolerance for arccheck ltol : .002 #Length tolerance for arccheck vtol : .0001 #System tolerance maxfeedpm : 500 #Limit for feed in inch/min lcc_move : .05 #Enter the move in X, Z for lathe canned cycle comp. ltol_m : .05 #Length tolerance for arccheck, metric vtol_m : .0025 #System tolerance, metric maxfeedpm_m : 10000 #Limit for feed in mm/min lcc_move_m : 1.25 #Enter the move in X, Z for lathe canned cycle comp.,mm force_wcs : yes #Force WCS output at every toolchange? spaces : 1 #Number of spaces to add between fields omitseq : no #Omit sequence numbers? (use -1 to enable sequence for LCC) seqmax : 9999 #Max. sequence number nobrk : no #Omit breakup of x, y & z rapid moves progname : 1 #Use uppercase for program name rotaxtyp : 3 #Rotary axis type for toolplane tooltable : 3 #Read for tool table and pwrtt (3 recalls pwrtt at sof) ref_ret : 0 #G29 / G30 return variable from Mi3 css_start_rpm : yes #Do direct RPM spindle start prior to CSS ? Phoodieman |
I did a search for E and F and found this. I noticed the stre and strf callouts # --------------------------------------------------- #String and string selector definitions for NC output # --------------------------------------------------- #Address string definitions stra "A" #String for address A strd "D" #String for address D stre "E" #String for address E strf "F" #String for address F stri "I" #String for address I strk "K" #String for address K Then I searched for stre and found this.... #Format feedrate for lathe thread result = nwadrs(stre, feed) result = newfs (19, feed) When I changed the stre to strf I got the F for feedrate in the posted out program. What a hassle. Phoodieman |
| Need Help!- feedrate wire | qwerty1000 | Post Processors for MC | 3 | 10-25-2009 10:11 PM |
| Need Help!- 0i-MC feedrate is ignored after a tap cycle | jhartleyjr | Fanuc | 9 | 06-27-2009 07:07 PM |
| Need Help!- Could someone post there setting for a HY02D223B | Ed Williams | DIY-CNC Router Table Machines | 6 | 05-20-2009 12:23 PM |
| Need Help!- G02, G03 Feedrate !!!!! | usb | TurboCNC | 2 | 09-15-2008 07:19 PM |
| Newbie- Help setting up post process from TCC to Mach3 | 56speedster | TurboCAD/CAM | 0 | 03-28-2008 10:14 PM |
