Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Post Processor Files
Post Processor Files Discuss post processor files here!
Old 09-17-2009, 02:19 PM
PROGRAMERDAVE is on a distinguished road
CAN POST COLLECT TOOL INFO AND ASSEMBLE IT AT HEADER?
HELLO,
RECENTLY I HAVE STARTED CONFIGURING POST PROCESSORS AND CAN NOT FIGURE OUT OR UNDERSTAND HOW TO CREATE THE HEADER I WANT. I WANT IT TO POST OUT A LIST OF TOOLS AT THE HEADER WITH THE TOOL COMMENTS NEXT TO IT. BASICALLY LOOKING LIKE THIS:
O12345
(236555 ROD END, OP 3)
(HOLD WITH .875 HARD COLLET AND STOP)
(HOLD AS DEEP AS POSSIBLE AVOIDING FILLET RADIUS)
(G55= X/Y: CENTER OF BORE LOCATION)
(G55= Z: ROTARY CENTER LINE, A: MILLED SURFACE IS PARALLEL TO TABLE)
(T1= 2.00 DIA FACE MILL)
(T2= .500 SPOT DRILL)
(T3= .531 DIA DRILL)
(T4= .500 FLAT END MILL)
(T5= BORING HEAD -- .8755 DIA)
T1 M06 (2.00 DIA FACE MILL)
M01
T2 M06 (.500 SPOT DRILL)
ETC.
I ONLY HAVE A 10 POSITION T/C AND I WAS THINKING OF DOING A IF THEN STATEMENT ONLY ALLOWING THE "T3=......" TO BE THERE IF THE POST FOUND A T3 M06 IN THE PROGRAM.
IS THIS POSSIBLE OR AM I DREAMING TOO LARGE.
Old 09-18-2009, 01:49 AM
Brakeman Bob is on a distinguished road
What CAM software are you using? I use SolidCAm and what you want is possible in that. Or do you use GPost to create code from a CL file; if you do then once again what you want is possible. However a lot of CAM programs lock the user out of editing the post and then charge for changes to meet your requirements.
By the way, there's no need to SHOUT!
Old 09-18-2009, 04:42 PM
I AM NEW TO THE WHOLE FORUM CHATTING REALM, I DIDNT REALIZE THAT CAPS R OFFENSIVE. I HAVE A STRONG HABBIT OF HAVING TO TYPE WITH THEM ON SO SORRY FOR THE MISINTERPRETATION.
I USE MASTERCAM 9.1 AND IM TRYING TO POST OUT FOR A HAAS.
WOULD YOU HAVE AN IDEA ON HOW THE POST GENERATES THE HEADER?
[IMG] code is Off
Need Help!- SurfCam Post -repeat tool header info MMTechi Surfcam 12 07-01-2011 06:16 PM
Assemble linear-actuator using off-the-shelf parts for < $600? offtherack Linear and Rotary Motion 3 04-22-2008 02:42 AM
Fist fight at work, can the employee collect unemployment? Edster CNCzone Club House 33 08-31-2006 08:33 AM
How hard is it to assemble? svon89 Hobbycnc (Products) 14 05-14-2006 08:59 AM
ready to assemble at last! sixpence DIY-CNC Router Table Machines 5 04-13-2004 01:59 PM
