Results 1 to 8 of 8
Thread: PostHaste, Rigid Tap, Spindle Speed, Direction
    Jun 2009
    Question PostHaste, Rigid Tap, Spindle Speed, Direction
    Ok, I know this is asking a lot but, if there is a PostHaste god out there I am sure it will be nothing for them to figure out. Of course any help will be greatly appreciated. This is what I am trying to do. I want PostHaste & GibbsCam V8.5 to output a rigid tap code like this. Oh, and I am not trying to yell by putting what I say in bold. It is to distinguish between code and what I am saying. I know all CAPS and Bold annoy some people.
    M06
    G00G90G43G54H5X0Y0Z1.T15
    M08
    G00Z0.1
    M29S130
    G99G84R0.1Z-1.F10.
    X1.Y1.
    G00Z1.
    Our Machine requires that the intro line has no spindle speed or direction in it.
    So first I put this in PostHaste
    Tap Tapping cycle
    M29 S[Speed]
    G[RetPlane] G84 R[RLevel] Z[D] F[Frate]
    end cancel
    1stToolChange First tool change
    G00 G80 G40 G28 G91 Z00 T[Tool] M6
    G00 G90 G43 H[Lcomp] G[Work] X[H] Y[V] Z[D] M[Direct] S[Speed] T[NextTool]
    M[Cool]
    End
    ToolChange Secondary tool changes
    M6
    G0 G90 G43 H[Lcomp] G[Work] X[H] Y[V] Z[D] M[Direct] S[Speed] T[NextTool]
    M[Cool]
    End
    That produces...
    M06
    G00G90G43G54H5X0Y0Z1.M03S130T15
    M08
    G00Z0.1
    M29S130
    G99G84R0.1Z-1.F10.
    X1.Y1.
    G00Z1.
    Note the "M03S130" in the intro line of the drill cycle. That is what I am trying to get rid of.
    So I changed sequences to
    Tap Tapping cycle
    M29 S[Speed]
    end cancel
    IF [Cycle] = [tap]
    G0 G90 G43 H[Lcomp] G[Work] X[H] Y[V] Z[D] T[NextTool]
    ELSE
    ENDIF
    M[Cool]
    End
    IF [Cycle] = [tap]
    M6
    ELSE
    M6
    ENDIF
    M[Cool]
    End
    Then that gives me an error saying...
    Internal Error <VC>: Unrecognized Maching Mode in CL File...
    Problem on line 14 of CL file...
    Error at APPLY / MILL...
    Does anybody have any idea how to fix this???
    I have included all the files that may shed some light on the issue(CL file, .vnc file, PostHaste templates, and Posthaste Log). Plus if I get this done it will be a GREAT template for other fanuc machines that use M29. And of course I would offer it to anyone that asks.
    Attached Files Attached Files
    Jun 2009
    Did I post this in the right section?? I thought I'd get some sorta response...
    Registered cadman's Avatar
    Jun 2003
    I'll take a look at it this weekend. I made all of my templates while I worked for my last employer.
    Jun 2009
    Thank You. I'll appreciate any help you can offer. I think I got the idea down but am missing a detail.
    Jun 2003
    The only problem I found was the speed for the tap. You set the spindle clamp at 150 to 12000 rpm, but only had 130 rpm for the tap. Once I changed that your modified template worked fine just like you wanted.
    Looking at your CL file, are you trying to post with CS using a standard Posthaste template? This section near the top indicates you are and is probably what is giving you the mode error:
    $$-> CS NUMBER 1.
    $$-> CSYS / 1.000000000, 0.000000000, 0.000000000, 0.000000000, $
    0.000000000, 1.000000000, 0.000000000, 0.000000000, $
    0.000000000, 0.000000000, 1.000000000, 0.000000000
    To post using CS, you need to purchase the upgrade from Posthaste. The standard Posthaste plug-in only works with up to 3 axis and no CS.
    Anyways, I see no problem. I'm using GibbsCAM V9.3.14, but I still would have experienced the same errors if there were any in your template, but it works.
    Jun 2009
    Ok, this is really weird. I just tried to recreate the error msg. I was going to take a screen shot of it to show you. But it worked. The only msg I get was the spindle speed warning as you mentioned (that it something I want to stay). I am totally confused now. The only thing I can think of is that the Gibbs and the computer were restarted. But, either way it is working just the way I was trying to get it to. Anyway, on a unrelated note. Which is not near as important. Is there a way to eliminate the "G00Z1." at the end of every drill cycle. Is that something you change in the PostHaste.cfg file?
    (TOOL 3)
    (13/32 DRILL)
    (OPERATION 1)
    G00G80G40G28G91M06T03
    G00G90G43G54H3X0Y0Z1.M03S893T05
    M08
    G00Z0.1
    G99G81R0.1Z-1.3721F7.
    X1.Y1.
    G00Z1.
    (TOOL 5)
    (1/2-13 CUT TAP)
    (OPERATION 2)
    M06
    M08
    G00Z0.1
    M29S130
    G99G84R0.1Z-1.F10.
    X1.Y1.
    G00Z1.
    (TOOL 15)
    (1/2 FINISHER)
    (OPERATION 3)
    M06
    Thank you so much for your help over the weekend.
    Jun 2003
    Look at the cycle cancel line in the template and tab the G0 line over a couple places or delete it.
    Jun 2009
    I do not have a G0 in that line. It looks like this.
    Cancel
    end
    From what I can see, the CL file tells it to retract to 1.0000000 three times, at the end.
    $$ StartNewTool...
    CUTTER / 0.406250, 0.000000, 2.000000
    LOAD / TOOL, 3, ADJUST, 3
    $$ TOOLID / 3
    CUTCOM / ON, LENGTH, 3
    SPINDL / RPM, 893.000000, CLW
    COOLNT / FLOOD
    RAPID
    GOTO / 0.0000000, 0.0000000, 1.0000000
    $$ ...end StartNewTool.
    $$ ...end StartFirstOp.
    RAPID
    RAPID
    GOTO / 0.0000000, 0.0000000, 0.1000000
    RAPID
    $$ Starting Drill cycle (DoDrill)...
    RAPID
    CYCLE / DRILL, DEPTH, 1.372100, PERMIN, 7.000000, $
    CLEAR, 0.099950
    GOTO / 0.0000000, 0.0000000, 0.0000500
    GOTO / 1.0000000, 1.0000000, 0.0000500
    CYCLE / OFF
    RAPID
    GOTO / 1.0000000, 1.0000000, 1.0000000
    RAPID
    RAPID
    $$ StartNewOp...
    Either way, you have helped alot. If this is something I have to deal with I can. It was just kinda annoying. I will do some more tweaking to get everything as perfect as I can and then post this as a good Fanuc 16M - 21M template. I am basing this on the last job I had with 3 Leblond Makino w/16Ms and now this job with a NTC w/ 21M. I hope it will help someone. If at some point you can find a way to eliminate that "G00Z1." let me know. Did you see anything else stupid in the template?
    1. Need Help!- FR-SE AC Spindle Drive - speed & direction input
      By kudos in forum Mazak, Mitsubishi, Mazatrol
      Last Post: 06-16-2009, 06:01 PM
    2. Spindle speed and left/right direction
      By caniggia_100 in forum Bridgeport and Hardinge Mills
      Last Post: 11-13-2008, 08:52 PM
    3. Spindle direction
      By deji in forum Haas Mills
      Last Post: 02-23-2007, 12:53 PM
    4. BPSeriesI / Centroid control- Spindle speed all out of whack with speed dial?
      By peter.blais in forum Bridgeport and Hardinge Mills
      Last Post: 08-08-2006, 04:29 AM
    5. Different speed for different direction.
      By ihkim in forum Hobbycnc (Products)
      Last Post: 07-31-2005, 09:34 AM
