| Post Processor Files Discuss post processor files here! |
| If you go to file>new and it has the option for new manufacturing file, you should be set. If it doesn't say manufacturing as a type of file then you will probably need an extention. I have programmed quite a bit in pro-e 2001 and wildfire and every machine that i have programmed on has been able to do manufacturing files. Just make sure that it has the correct post processor, pro-e seems to be a bit limited on post processors. Jeremiah |
| Hi Pro-E is not limited in Post since i have excellant experience on Pro-E for part manufacturing specially for 5-axis. I have worked on number of machine with all most all kind of combination. I find it 100% working. If you find any problem specially in G-Post you are free to ask for any kind of hlep. Sohail Abbas |
I am new to posts. Just bought new cam software. Where do you learn about posts? Do buy them? Do you write them? Can you buy a book on the subject? thanks dxxx_athena@yahoo.com dxxx Last edited by dxxx; 07-25-2006 at 12:33 PM. |
If you have any post procesor development technique in Pro/Engineer as well as FIL Macro send it to me. Raj |
| Pro/e has unlimited control of your posts. That being said you need to find the best post processor for your control, you can usually find it on the ptc website and tweak it for your needs Pro/e is not the best way to machine parts you will find lots of air cuts and unnecessary motion and a steep learning curve not to say there isn't anything you can't do with pro it's just a matter of how long you want to work on it.Wildfire is alot easier to use with the pro/manufacture add on it has feature recognition and some automatic tool paths but the interface is somewhat lacking, and confusing. at best get training or buy some machining software like mastercam. |
#12
I am currently starting on customizing a post for DMG Twin500 Linear machine. I find my tape file has a lot of difference from what we created using the program by the controller (Siemens840D). Do you have any idea which aspects I should first look at, and also which additional stuff I should add in to complete the GPost? Thanks... IAWH |
| Emco Compact 5 PC...have ???? | Double G | Mini Lathe | 42 | 08-22-2010 07:26 PM |
| Upgrading control hardware - Emco | eDudlik | General CNC (Mill and Lathe) Control Software (NC) | 21 | 12-08-2009 01:52 AM |
| v2xt post | jrrhotrod | Post Processors for MC | 25 | 12-10-2008 06:20 PM |
| MC9 to Mach2 Lathe post? | HogDog | Mach Software (ArtSoft software) | 16 | 10-09-2005 11:28 PM |
| post processor help | jrrhotrod | Post Processor Files | 8 | 01-14-2005 04:45 PM |
