Results 1 to 5 of 5
Thread: Arc output in NC w/mastercam
    May 2009
    us
    I'm having problems, I want I & J values instead of R value.
    I'm using mastercam post processor, I can't find the "arcoutput$" value in my postprocessor file.
    Registered Superman's Avatar
    Dec 2008
    Krypton
    What mastercam version ?
    What modified post ?
    "arcoutput" should be found in the general output settings near the top of the PST file
    looks something like this
    Code:
    breakarcs   : 0     #Break arcs, 0 = no, 1 = quadrants, 2 = 180deg. max arcs
    arcoutput   : 2     #0 = IJK, 1 = R no sign, 2 = R signed neg. over 180
    If version X or later
    There is also an area in the MD ( Machine Definition ) file that requires setting, under "arcs"
    PS: a mastercam forum exists, overseen by those working Mcam
    you would get better / more responses asking the question there.
    May 2009
    us
    Thanks Superman,
    I'm using McamX, there's no that line; i already checked that.
    I'll post in MasterCam forum.
    Regards
    Dec 2008
    UK
    Quote Originally Posted by zelaznog View Post
    see the following code in post file
    arctype$ : 2 #CD_VAR Arc center 1=abs, 2=St-Ctr, 3=Ctr-St, 4=unsigned inc.,
    #5 = R no sign, 6 = R signed neg. over 180
    and set it to 5
    Mar 2008
    Try going to Settings at the top of the window, select "Control Definitions Manager". Select Arc under "Control Topics". Now in the box titled "Arc Center Type" make sure that the XY Plane, YZ Plane, and XZ Plane are set to "Delta start to center".
    With this my .NC files look like this:
    O0000 ( TOOLPATH GROUP-1 )
    ( T O O L T A B L E )
    ( T2 = 5/16 FLAT ENDMILL LJ - H236 - D236 )
    N2 G00 G17 G20 G40 G80 G90
    ( CONTOUR )
    ( T2 = 5/16 FLAT ENDMILL LJ )
    N4 G00 G17 G90 G54
    N6 T2 M06
    N8 X-1.7813 Y-.3125
    N10 S4889 M03
    N12 G43 H236 Z2.
    N14 Z.1
    N16 G01 Z-.25 F30.
    N18 X-1.4688 F78.22
    N20 G03 X-1.1563 Y0. I0. J.3125
    N22 G02 X-1.1563 Y0. I1.1563 J0.
    N24 X-1.1552 Y.05 I1.1563 J0.
    N26 G03 X-1.4539 Y.3757 I-.3122 J.0135
    N28 G01 X-1.7661 Y.3892
    N30 Z-.15 F50.
    N32 G00 Z2.
    N34 M05
    N36 G53 Z0.
    N38 G53 X-10.0 Y0.
    N40 M30
    Lyle
    TM-1P & TL-2
    1. output a D after the G41 or G42...
      By shape in forum Dolphin CADCAM
      Last Post: 04-28-2009, 03:04 PM
    2. Mastercam X, force 4 decimal place output
      By critz in forum General CNC (Mill and Lathe) Control Software (NC)
      Last Post: 05-20-2008, 12:59 AM
    3. Need Help!- Changing Arc Output?
      By Moparmatty in forum Mastercam
      Last Post: 01-30-2008, 09:34 AM
    4. PSU with 2 different Output Voltages ?
      By Joey in forum General Electronics Discussion
      Last Post: 06-09-2007, 09:02 PM
    5. I cant get Mastercam to output "I" and "J"
      By Jeff S in forum Mastercam
      Last Post: 03-27-2007, 06:12 AM
