Results 1 to 4 of 4
Thread: Need post processor from Pro-E to Haas
    Mar 2007
    U.S.
    I am a machining instructor at a high school in Wisconsin. Our cam software is Pro-Engineer. I am trying to post to a Haas TM-1 (toolroom mill) and I am having trouble figuring out what processor to use. If there is anyone that can lend a hand it would be greatly appreciated. Thank you.
    Sep 2004
    To edit the post, you need to get into the NC Post Processor utility:
    Applications > NC Post Processor
    On the left side is a list of directories that list the available posts.
    I suggest you put the post you want into your own directory; you can do that by setting gpostpp_dir to a directory in config.pro. For example, I have:
    ! ProNC post processors
    gpostpp_dir D:\ProENGINEER_Root\Directories\NC_GPost
    The default directory is C:\Program Files\proeWildfire 4.0\i486_nt\gpost\. Go there and copy the post you want to your own directory.
    For the TM-1, the Haas VF8 post should be pretty close; that's the one I used to start the post for my MiniMill. Though, you might have to tweak a few things to get it all right. Before you begin to rely on your post, you should probably test it thoroughly. Make sure all the G codes and M codes do what they are supposed to; I had the incorrect check box for G18 orientation selected and the post would output XZ arcs the wrong way (i.e. in CW instead of CCW).
    Next, to use your post inside ProE:
    MFG Setup > Workcell > New
    Give the workcell a new name (HAAS_TM-1) and enter the pertinent information. In the Post Processor Options area, enter the name of the post. It's shown at the top of the NC Post Processor utility when you have the post open for editing. Usually, the PP Name box is "UNCX01" and the ID box is the digits from the suffix; if you use the bundled VF-8 post, it is probably "11".
    Once you've got that, be sure to hit save. That way, you can pull up this workcell (i.e. aka the milling machine) without having to enter all the information again.
    Hope that helps,
    Chris Kirchen
    Mar 2007
    U.S.
    Chris -
    Thank you very much for your help and input, we have now got everything working correctly, I think, so far!!! Thanks again for taking time out of your day to help. Much appreciated.
    Aaron Pokrzywa
    De Pere High School
    Sep 2004
    No problem. Glad I could help.
    Chris Kirchen
  1. haas sl post processor
    By busted bit in forum BobCad-Cam
    Last Post: 09-21-2012, 10:54 AM
  2. Newbie- Haas TM-1 Post processor needed
    By keithki in forum SolidCam
    Last Post: 06-06-2011, 02:25 PM
  3. post processor for HAAS vf2
    By joesimmers in forum BobCad-Cam
    Last Post: 12-10-2007, 09:07 PM
  4. Post Processor for Haas VF
    By biff1212 in forum Post Processor Files
    Last Post: 02-11-2007, 04:00 PM
