Results 1 to 9 of 9
Thread: G-code output problem
    Jan 2009
    us
    Cool G-code output problem
    Hello to everyone...new to the forum.
    I was just recently put in charge of programming after a company downsize and the shop uses Virtual Gibbs. Its an old version (4.26) from what I've been reading on these message boards. I've only been using it a couple of days, but I got it to do what I wanted with a little poking around. I just cant get it to output any G-code. Any advice would be appreciated...
    Registered cadman's Avatar
    Jun 2003
    To get the machine code you need to post process the toolpaths. I don't how different the interface of V4.26 is, but there should be an icon to run the post processor.
    Jan 2009
    us
    Cool Icon for post processor
    Thanks Cadman for the reply. There is an icon for the post processor, but when I click on it, there are no files to load. Does that mean I cannot write out a g-code. What are my options? I cant believe they would purchase the software without even a basic post.
    Jun 2003
    There has to be a post somewhere otherwise your company couldn't post any G code. When you click on the post process icon, the dialog box has an icon to locate the .PST (processor) file you want to use and an icon for the location you want to put the NCF (G code) file. You need to search for the .PST file or find out from someone who did the programming where it is.
    Jan 2009
    us
    Cool No .pst files
    I ran a search of the c:/ drive for any .pst files and it came up with nothing.
    I ransacked the office and found the instruction manuals and install disks(actually floppy's which tell me how old the version is). One disk is labeled:
    Library Post
    . I didn't have the time tonight to look at the disk files. Is this disk a generic post?
    Jun 2003
    Yes, your post(s) are on this disc. Copy them to a location on your computer and when you process your toolpaths, navigate here and use this post.
    Jan 2009
    us
    Cool Thanks Cadman
    Thanks for the help and quick replies.
    Jun 2003
    Glad to help. Another good resource for help is the message board at gibbscam.
    Jan 2009
    us
    Library Disk a No-Go
    I couldn't access the disk. I don't know if its a disk problem or a floppy drive problem. I did find some .pst files in another folder(I don't know why they didn't appear during my search of the hard drive but when I found them they were labeled as "office data files"). There were 5 files, but they were All for Yasnac controls. We have 1 Yasnac control and all the other machines are Fanuc, and more able. I was able to process some code for the Yasnac, but it came out like GARBAGE on all 5 files, rapiding into the part and approaching it 3 or 4 different paths far away from the part feeding into air.What a waste! Its almost like somebody just threw them together on the fly and said "these will be good enough for your needs". Of course the salesman was probably talking to someone who had never seen code in his/her life. I'm so irritated right now! I'm gonna try the message boards at gibbs and see what I can learn there. Thanks again.
    1. learning g code or cad-cam code output?
      By slow_rider in forum G-Code Programing
      Last Post: 02-27-2010, 09:48 PM
    2. Replies: 1
      Last Post: 01-28-2008, 07:51 PM
    3. Laser power output problem(unstable)!!!
      By khasabog in forum General Laser Engraving & Cutting Machine Discussion
      Last Post: 12-01-2006, 04:49 AM
    4. Cleaning up vectorized output for g-code.
      By ngr1 in forum General CAM Discussion
      Last Post: 06-07-2006, 08:35 AM
    5. Image embossing & G-Code output example
      By dcarr in forum Virtual Sculptor VS3D / VScad3 Software
      Last Post: 07-31-2004, 08:51 PM
