Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Post Processor Files
Post Processor Files Discuss post processor files here!
Old 10-26-2004, 06:11 AM
ilst is on a distinguished road
Cool Building My Postprocessor
Hello.
I'd like infos, suggested sources for knowhow,bibliography,
about the matter of building my own post-processor.
I'd like to know how to start.I'm putting some fundamental questions:
1)do i have to concern about the CAD-CAM system i use,which means the
type of generated toolpath files of the CAM system.Different cam systems generate different extension files of toolpaths.For example mastercam creates a file with extension .nci,ideas a file with extension .cl etc.
2)which is the appropriate programming language for creation of
a post-processor file?
3)are there software which i can use to create easy my post-processor under a question and answer window environment.
all these for beginning
kind regards
Old 12-15-2004, 07:01 PM
gjahnke is on a distinguished road
Some CAM software uses propreitary post processor setups. In many cases this is to combat piracy (they only provide posts to registered users).
Either contact the vendor for your software for a post (they will generally provide one to your spec for free) or find a "universal" postprocessor (posthaste comes to mind).
Old 01-02-2005, 11:37 PM
TAB TAB is offline
TAB is on a distinguished road
dude,
Posts vary by software manufacturer. Only companies such as Icam or IMS (Intelligent Manufacturing Software) offer systems which will allow you to build a post but you need their software which costs a lot. If you have some programming experience you might have a shot. I once tried to modify a stock mastercam post and found it confusing and a little difficult. You will first need to choose a software to work with and then work on the post.
Also no one post works with all CAM packages.
It will also help if you have example programs which ran on the machine to help you trouble shoot and fine tune the post.
Let us know which system you are working with and then maybe we can point you in the right direction.
Todd
Old 01-03-2005, 10:06 AM
ty1295 is on a distinguished road
Edgecam has a nice post editing tool built in.
I have done some pretty trick editing for an Anilam controller that uses words instead of g codes, for example RAPID -vs- G00
Old 02-11-2009, 04:44 PM
Grantie is on a distinguished road
Just started working with edgecam R1 2009 code wizard & although it took a few hours to get into it seems the buisness, also if your get stuck the sales men and help desk are quick to offer a hand.
one down four to go, heres hoping the rest are straight forward
[IMG] code is Off
Beginner Troubleshooting and Building Considerations coherent FAQ of CNC Machine building 3 11-10-2011 02:27 PM
Building a stepper motor. tastefulasever Stepper Motors and Drives 13 12-11-2009 11:50 AM
Building CNC Surface grinder - whole lotta questions rashid11 General Metal Working Machines 6 03-09-2006 03:53 PM
Anyone ever lease a building? murphy625 CNCzone Club House 35 06-17-2005 10:23 AM
Should I consider building a cnc or just buy one? johnt CNC Plasma and Waterjet Machines 18 03-28-2005 12:19 PM
