| Post Processor Files Discuss post processor files here! |
| Hello everybody. In the shop i'm working to,has been installed a 3 axis milling machine with a HEIDENHAIN TNC 430 controller.As i read in the manual this is not so similar with other contollers which are familliar to me(like YAZNAK FANUK OKUMA).As i use mastercam 8 for creating iso code files(G code) i tried all the default post processors of mastercam to generate g code but the result was pure.Is there a colleague whom i can speak with, about this matter and others like 'creation my own post processor ' for example, and their opinion about using or not the HEIDENHAIN'S or MAZATROL's controller software for creation programs running on the corresponding controllers.(HEIDENHAIN 430 and MAZATROL NEXUS lathe milling are the kinds we have in shop). Personally i prefer iso g code programming but there is a pushing from above to use the specific software of the above controllers for programming. As a new member of this forum i'd like to note that any other messages for relevant matters are welcome. Waiting for reply kind regards |
| Dear friend, I wrote a very good post for Mastercam, and I willl stay glad to share with you.My post do all drill cycles in command, helical circular interpolation, and arcs in all planes: XY/YZ/XZ. I have tested this post extremely, so, I ensure for you that it´s a excellent post for heidenhain 426/430 systems. If you want test, I´m putting in attach with this message. The only problem is that was wrote for V9. I start in V8, but make some changes for V9. Hope that helps. If works for you, let me know.If not, let me know too.Maybe I can help you with the problem. Read the header for additional notes, about the resources included in post. Any doubt, contact me.If necessary, I do the changes for the post to V8 again. Regards Daniel |
| When I operated the TNC 426/430 controllers, I had access to mastercam but rarely used it. Like mouldmaker said, it is a very friendly system. Once you get to know the language, you will do most of the programming at the control, in most cases it is quicker than mastercam. I even used to do a lot of basic 3D stuff at the control using and combination on plane swapping and the "Q" (parametric programming) functions which allow you to have the program calculate variables in a flash. One program I wrote for a previous company is still used today. They are manufacturers of jigging tables for fabricators. The tables have 100's of holes in them and range in 100mm increments from 1m x 1m to 3m x 3m. All the operator has to do to machine the specific size the customer ordered, is to answer 6 questions at the beginning of the program and the entire program self adjusts. Get into it, heidenhain is great stuff, you and the push from above won't regret it, and besides, use the oportunity to learn a new language while you can, as it will boost your position in your current job and also your future employability by others. Good luck with it all.
__________________ "A Helicopter Hovers Above The Ground, Kind Of Like A Brick Doesn't" Greetings From Down Under Dave Drain Akela Australia Pty. Ltd. (Note: The opinions expressed in this post are my own and are not necessarily those of CNCzone and its management) |
| I fished this post off the internet quite a while ago. It's the best one I've used for the 426/430 control in conversational. I also was an ISO code user. Believe me over time you'll see the conversational is much eaiser to use. |
thank you for posting that post I have A guy over from Iceland and he is now using mastercamm but could not find that post. Thank you
| Hi My name is shajee i lookking for tnc 430 heidenhain controller post processor for cnc vertical milling machine. I need ISO code post processer for master cam version 9 or more or ...Please help me to send ...my mail is shajesp@gmail.com |
#10
| Please post your postprocess so that I can try it machine Regards Shajee |
#11
| HI ! i've rescently acquired TNCremont to send files to a TNC426HEIDENHEIN control. i'm trying to use it with mastercamX but i'm unable to postprocess with TNCREMONT. codes are not "G" but "L" like: "L X-11 Y0 FMAX" can some one tell me how to configure it ? i'm very new to this stuff, and i've been working on that machine since 6 months, i work files at home so they can be ready the day after, so i'm trying to make it work with my PC. My bosses dont seem to know how to do it... THANKS! |
#12
HI I NEED HEIDENHAIN POST TNC 430 4 AXIS MASTERCAM V8 PLEASE.... RSALMEIDA2@HOTMAIL.COM |
| Emco Compact 5 PC...have ???? | Double G | Mini Lathe | 42 | 08-22-2010 07:26 PM |
| Upgrading control hardware - Emco | eDudlik | General CNC (Mill and Lathe) Control Software (NC) | 21 | 12-08-2009 01:52 AM |
| Heidenhain 430 post 4 surfcam | coole_jag | Post Processor Files | 0 | 01-29-2005 03:53 PM |
| post processor help | jrrhotrod | Post Processor Files | 8 | 01-14-2005 04:45 PM |
| Phillips CNC-432 post processor??? | marx911 | Post Processor Files | 0 | 12-03-2004 10:07 PM |
