| Post Processor Files Discuss post processor files here! |
Im completely new at altering the mpost files, but what I want to do is when I choose through coolant to have it post out M88. Now it just post out M0. Can anybody help me this is the current mpost name HAAS VF-SERIES % 00 / 00 O >4 N >4 G >2 g >2 G X ->3.>4 Y ->3.>4 Z ->3.>4 I ->3.>4 J ->3.>4 K ->3.>4 Q ->3.>4 R ->3.>4 P >40 F >3.>3 H >2 D >2 T >2 S >4 M >2 SbackDoor SupressHeader ModalLetters X Y Z F # List of letters that are modal ModalGs 0 1 2 3 73 74 76 80 81 82 83 84 85 # List of g codes that are modal Sequence#s N 0 1 1 # Char, freq, incr & start First#? N # Y or N 'Output 1st sequence no. Last#? N # Y or N 'Output last sequence no. HCode X # X or X U 'Horizontal char. VCode Y # Y or Y V 'Vertical char. Dcode Z # Depth char. FeedCode F # Feed rate char. Comment ( ) # Begin End comment char. Spindle 3 4 5 # Cw, ccw & stop m codes Coolant 8 9 7 61 62 63 64 # Flood, Off, Mist and Thru Spindle M codes DComp 41 42 40 # Left, Right & Cancel m codes LComp 43 49 # On & Off codes Feed G1 # Linear move Rapid G0 # Rapid positioning word ArcPlane G 17 18 19 # G17, G18, G17 Arc Plane selection ReturnPlane 98 99 # G98 G99 Return Plane selection Cw G2 # Circular move clockwise Ccw G3 # Circular move counter clockwise Inc/Abs G 91 90 # Inc & Abs char. & values CtrCode I J K # I J or R or I J K L Helical? Y Spaces? Y # Y or N 'Spaces between words Incremental? N # Y or N 'Inc or abs output CtrIncremental? Y # Y or N 'Inc or abs I & J ByQuadrants? N # Y or N 'Break arcs at quadrants UppercaseComments? Y # Y or N 'Require uppercase comments Drill # Drilling canned/manual cycle G81 G[RetPlane] X[H] Y[V] Z[D] R[Vclear] F[FRate] end cancel CSink G82 G[RetPlane] X[H] Y[V] Z[D] R[Vclear] F[FRate] P[Dwell] end cancel Peck # Pecking canned/manual cycle G83 G[RetPlane] X[H] Y[V] Z[D] Q[VBite] R[Vclear] F[FRate] end cancel Tap # Tapping canned/manual cycle G84 G[RetPlane] X[H] Y[V] Z[D] R[Vclear] F[Frate] Q[VBite] end cancel LTap # Left handed tapping cycle G74 G[RetPlane] X[H] Y[V] Z[D] R[Vclear] F[FRate] end cancel Ream # Reaming canned/manual cycle G85 G[RetPlane] X[H] Y[V] Z[D] R[Vclear] F[FRate] end cancel Bore # Boring canned/manual cycle G86 G[RetPlane] X[H] Y[V] Z[D] R[Vclear] F[FRate] end cancel Back # Back boring canned/manual cycle G87 G[RetPlane] X[H] Y[V] Z[D] R[Vclear] F[FRate] end cancel Cancel # Cancel a canned/manual cycle G80 end StartCode # Start of the program %0 O[0] G17 G40 G80 G90 End 1stToolChange # First tool change T[Tool] M6 M[Direct] S[Speed] G0 G90 G[Work] X[H] Y[V] G43 Z[D] H[Lcomp] M[Cool] End Infeed # Enable cutter comp G[Side] X[H] Y[V] D[DComp] F[FRate] end Outfeed # Disable cutter comp G1 G40 X[H] Y[V] Z[D] end ToolChange # Secondary tool changes T[Tool] M6 G0 G90 G[Work] X[H] Y[V] S[Speed] M[Direct] G43 Z[D] H[Lcomp] M[Cool] End Upon [Speed] # Output spindle speed change M[Direct] S[Speed] End EndCode # End of the program M9 G28 g91 Z0 M30 %0 End |
| I don't use Surfcam, but I use GibbsCAM and our Posthaste posting option is also created by Ground Support, who makes your Surfcam post. You need to add 88 to the coolant command. Also, make sure the notes/descriptions that follow each line is separated by two or more spaces. In the copy of your template you have no spaces: Coolant 8 9 7 61 62 63 64 88 - need spaces here- #Flood, Off, Mist and Thru Spindle M codes |
| Waterjet post need for Surfcam | Traceman | Surfcam | 2 | 03-15-2007 02:55 PM |
| Surfcam post for g71 | villiersterrace | Haas Mills | 0 | 08-02-2006 06:44 PM |
| Surfcam Post Processor | drakesis | TurboCNC | 6 | 05-24-2006 08:17 AM |
| Surfcam and Bridgeport EZ post??? | Hypermold | General CNC (Mill and Lathe) Control Software (NC) | 0 | 03-08-2006 09:22 AM |
| Heidenhain 430 post 4 surfcam | coole_jag | Post Processor Files | 0 | 01-29-2005 02:53 PM |
