Results 1 to 8 of 8
Thread: Mastercam CNC jr post
    Jun 2006
    Hi all
    I am looking for download for a CNC jr mill post in Mastercam V9.1 or a suggestion for which supplied post in Mastercam is best suited.
    Thanks for the help.
    Aug 2005
    What control?
    Do you have an example of the code you are looking for?
    Your reseller can modify MPMASTER to do what you want or you can go to Emastercam.com and ask for advice about editing your post. Just don't ask for a post...you won't like the result.
    Registered Rally's Avatar
    Jan 2007
    The Controller is based on a generic Fanuc. If you contact mastercam they will create a custom Post processor for you.
    Mar 2007
    Sweden
    pardon my english
    I subscribe with above, Your reseller should help you. But still it is quite fun to edit it by your self. You have to find a post that is allmost right and if you have some experience of programming it is quite easy in mc8 (probably mc9 allso, haven't run it so I don't know) at least easier modifications. Set the debug to on in the post, then you post the toolpath as usual and after each line you see what the post got the line from. From that you can find out where you shall make your changes in the post. I have just started to work with mcX and it is a little bit more complex but still possible. In mcX you turn on debug in the control definitions. Don't forget to do a backup of your original post before you begin.
    Dec 2005
    UK
    Mastercam Posts
    Hello All
    Mastercam used to publish a manual on Post Processors called, as you might expect, the Post Processor User Guide it had, in V5 the part number 001-090994-P5006.
    Writing or modifying post processors are part of the dealers' support to their end users but also part of their income so help is not always forth coming so ask CNC Software direct if they sell a copy for your MC version.
    I have a copy of the V5 manual and will provide a little help to any forum user but a good place to start is always the Fanuc posts as so many controls are similar, also my experience in post is now very old!
    Regards
    Richard
    Apr 2005
    bucont,
    The Pre V8 Mastercam post is very easy to rework so that it will meet your needs. I'm licensed upto V9 and still prefer to post with a highly modified V5 post. I summitted a copy of my V5 post, which provided a RefHt for milling, to Mastercam and V7 was released with with RefHt for milling. At that time I had absolutely no experience with any type of computer programming. Grab a cold beer and open a post file in any text editor play with it. The experience will only make your? Mastercam better serve your needs. A word of advice; if you contact Mastercam regarding post processor then their first response will will be a question, bear in mind that they now have your phone number.
    Servo
    Jun 2006
    Sounds like we start with the generic Fanuc post and go from there. Thanks all.
    Apr 2007
    Diy
    If you post the code out, and figure out what you want to change, I will help you fix it.
    1. NEED Mastercam Post
      By MrMachine55 in forum Post Processors for MC
      Last Post: 04-14-2007, 11:44 AM
    2. please help with mastercam v9 post
      By gasho in forum Post Processors for MC
      Last Post: 12-07-2006, 09:13 AM
    3. please help with mastercam v9 post
      By gasho in forum General Metalwork Discussion
      Last Post: 12-01-2006, 09:53 AM
    4. Mastercam Post For a KIA 63
      By tlhbear55 in forum Post Processors for MC
      Last Post: 10-06-2005, 10:05 PM
    5. Mastercam to MX3 post help plz
      By srwalden in forum Post Processor Files
      Last Post: 07-18-2005, 07:06 PM
