10-26-2006, 04:12 AM
| Don Diegoo | | Join Date: Aug 2006 Location: Iran Age: 48
Dear Jakrro !
For iTNC 530 and 5 Axis post processor your must note to somepoint as below :
1- you have fixed rotary table ? or portable rotay table? and this is 1 axis or choosing axis for example this is A axis or C axis ? in this way you have check the Pivot point in machine parametr to introduce to control for rotary table for example you to find the exact X and Y axis in REF mod and put the value in machine parameter Nr. ( you must check with the machine bulder ! ) and it is the same for B axis and rotary head also check it again ! and if it need to little bit adjust do it !
2- depends on your system software version on your control can you active the M128 ? this is needs to all machine program more than 3 axis for running on machine to maintane the point of interpolation between 3 linear and up 2 rotary axis ... check it again...
3- after this your machine posprocessor bulder must know evrything of your machine and also your machine parameter
be happy
F.Sharifi |
