Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Post Processor Files
Post Processor Files Discuss post processor files here!
Old 11-19-2010, 12:53 PM
Argent is on a distinguished road
Post problems
Hello all,
I am having a problem with my post processor. This first post is from Mastercam7 and the next is from Mastercam X3.
O0001
(PROGRAM NAME - MC7)
(DATE=DD-MM-YY - 19-11-10 TIME=HH:MM - 12:12)
(1/8 CENTERDRILL TOOL - 1 DIA. OFF. - 1 LEN. - 1 DIA. - .125)
N100G20
N102G0G17G40G49G80G90
N110T1M6
N112G0G90X0.Y0.A0.S2250M3
N114G43H1Z.5M8
N116G98G81Z-.05R.25F6.
N118G80
N120M5
N122G91G0G28Z0.M9
N124G90
N126M30
O0000
N10G54X0.Y0.Z.5
N20G98G81Z-.05R.25F6.
N30G80
(PROGRAM NAME - MCX3)
(DATE=DD-MM-YY - 19-11-10 TIME=HH:MM - 12:13)
( 1/8 CENTERDRILL TOOL - 1 DIA. OFF. - 1 LEN. - 1 DIA. - .125)
N40G20
N50G0G17G40G49G80G90
N60T1M6
N70G0G90X0.Y0.A0.S2250M3
N80G43H1Z.5M8
N90M5
N100G91G28Z0.M9
N110G90
N120M30
The MC7 post works just fine but the X3 does not. I see that it placed two lines at the beginning of the program that should be between N80 and N90. My question is how to I modify my post processor to get it to post out in the correct format?
Here is my MCX3 *.pst.
[POST_VERSION] #DO NOT MOVE OR ALTER THIS LINE# V11.00 E1 P0 T1276788110 M11.00 I0 X0.00
# Post Name : MPFAN
# Product : MILL
# Machine Name : GENERIC FANUC
# Control Name : GENERIC FANUC
# Description : GENERIC FANUC MILL POST
# Associated Post : NONE
# Mill/Turn : NO
# 4-axis/Axis subs. : YES
# 5-axis : NO
# Executable : MP 7.20
# WARNING: THIS POST IS GENERIC AND IS INTENDED FOR MODIFICATION TO
# THE MACHINE TOOL REQUIREMENTS AND PERSONAL PREFERENCE.
# Revision log:
# Features:
# This post supports Generic Fanuc code output for 3 and 4 axis milling.
# It is designed to support features of Mastercam Mill V7.
# Following Misc. Integers are used:
# mi1 - Work coordinate system
# 0 = Reference return is generated and G92 with the
# X, Y and Z home positions at file head.
# 1 = Reference return is generated and G92 with the
# X, Y and Z home positions at each tool.
# 2 = WCS of G54, G55.... based on Mastercam settings.
# mi2 - Absolute, or Incremental positioning
# 0 = absolute
# 1 = incremental
# mi3 - Select G28 or G30 reference point return.
# 0 = G28, 1 = G30
#Canned text:
# Entering cantext on a contour point from within Mastercam allows the
# following functions to enable/disable.
# Cantext value:
# 1 = Ostop = output the "M01" optional stop code
# 2 = Stop = output the "M00" stop code
# 3 = Bld on = turn on block delete codes in NC lines
# 4 = bLd off = turn off block delete codes in NC lines
#Milling toolpaths (4 axis)
#Layout:
# The term "Reference View" refers to the coordinate system associated
# with the Top view (Alt-F9, the upper gnomon of the three displayed).
# Create the part drawing with the the axis of rotation about the axis
# of the "Reference View" according to the setting you entered for
# 'rot_on_x'. The Top View (Z plus of the Reference View) indicates
# the position on the part of rotary axis zero. The top view rotated
# about the selected axis as a "single axis rotation" are the only
# legal views for 4 axis milling. Rotation direction around the part
# is positive in the CCW direction when viewed from the plus direction
# of the rotating axis. Set the variable 'rot_ccw_pos' to indicate
# the signed direction. Always set the work origin at the center of
# rotation.
#Toolplane Positioning:
# 1) Create the Cplane and Tplane as the rotation of the Top View about
# the selected axis of the "Reference View". The toolplane is used
# to calculate the position of the rotary axis.
#Axis substitution:
# 1) Use the Rotary axis substitution by drawing the geometry flattened
# from the cylinder. Positions are wrapped from and to the cylinder
# by using the Roll function. Rapid positions in the NC parameters
# are relative to the chained geometry. The rotary axis button must
# be active for axis substitution information to be output to the
# NCI file. The radius of the rotary diameter is added to the all the
# Z position at output.
# 2) Drill positions can also be substituted in this function.
#Rotary 4 axis:
# 1) 4 axis toolpaths can be generated from the Multisurf Rotary 4 axis
# function. Use the Top View for the toolplane and the Cplane to define
# the step over slicing plane (uses depth).
#Additional Notes:
# 1) G54 calls are generated where the work offset entry of 0 = G54,
# 1 = G55, etc.
# 2) Metric is applied from the first NCI met_tool variable.
# 3) Incremental mode calculates motion from home position at toolchanges.
# The home position is used to define the last position of the tool
# for all toolchanges.
# Debugging and program switches
fastmode$ : 1 #Posting speed optimizition
bug1$ : 2 #0=No display, 1=Generic list box, 2=Editor
bug2$ : 0 #Append postline labels, non-zero is column position?
bug3$ : 0 #Append whatline no. to each NC line?
bug4$ : 0 #Append NCI line no. to each NC line?
whatno$ : yes$ #Do not perform whatline branches? (leave as yes)
linktolvar$ : 1 #Associate X tolerance variables to V9- variable?
linklvar$ : 1 #Associate X lathe specific variables to V9- variable?
cant_tlchng$ : 1 #Ignore cantext entry on move with tlchng_aft?
get_1004$ : 1 #Find gcode 1004 with getnextop?
skp_lead_flgs$ : 1 #Do NOT use V9+ style contour flags?
rpd_typ_v7$ : 1 #Use V7+ style contour flags/processing?
strtool_v7$ : 2 #Use Version 7 toolname?
arcoutput$ : 1 #0 = IJK, 1 = R no sign, 2 = R signed neg. over 180
arctype$ : 2 #Arc center 1=abs, 2=St-Ctr, 3=Ctr-St, 4=unsigned inc.
stagetool : 0 #0 = Do not pre-stage tools, 1 = Stage tools
use_gear : 0 #Output gear selection code, 0=no, 1=yes
max_speed : 10000 #Maximum spindle speed
min_speed : 50 #Minimum spindle speed
index : 0 #Use index positioning 0=No,1=Direction M-Codes,2=Signed
#3=Controler takes shortest path
ctable : 5 #Degrees for each index step with indexing table
rot_on_x : 0 #Axis rotating about, 0 = Y axis, 1 = X axis
rot_ccw_pos : 0 #Axis signed direction, 0 = CW positive, 1 = CCW positive
lock_table : no$ #Lock table for indexing operations
use_frinv : 0 #Output feedrate with rotary as inverse time, 0=no, 1=yes
maxfrdeg : 2000 #Limit for feed in deg/min
maxfrinv : 999.99#Limit for feed inverse time
force_wcs : no$ #Force WCS output at every toolchange?
scaxadrs A #Address for the rotary axis
# INITIALIZE - initialize system variables
arccheck$ : 1 #Check for small arcs, convert to linear
breakarcs$ : yes$ #Break arcs into quadrants?
getnextop$ : 2 #Build the next variable table
newglobal$ : 1 #Error checking for global variables
nobrk$ : no$ #Omit breakup of x, y & z rapid moves
omitseq$ : no$ #Omit sequence no.
progname$ : 1 #Use uppercase for program name
rotaxtyp$ : 1 #Rotary axis type for toolplane
seqmax$ : 9999 #Max. sequence no.
spaces$ : 0 #No. of spaces to add between fields
tlchng_aft$ : 1 #Delay call to toolchange until move line
tooltable$ : 1 #Read for tool table and pwrtt
#Common variables and strings
zero : 0 #Define constant
one : 1 #Define constant
two : 2 #Define constant
c9k : 9999 #Define constant
frc_cinit : 0 #Force C axis reset and C axis codes at each toolchange
#overrides the modality based on postflg
speed : 0 #Absolute value of ss
bld : 0 #Block delete active
result : 0 #Return value for functions
sav_spc : 0 #Save spaces
sav_gcode : 0 #Gcode saved
sav_nobrk : 0 #nobrk saved
absinc$ : 0 #Absolute/Incremental
ctype : 0 #Cut type
cflag : 0 #1 = in path
#Position control variables
x_mult : 1 #Multiplier for output on X axis
y_mult : 1 #Multiplier for output on Y axis
z_mult : 1 #Multiplier for output on Z axis
#English constant variables, adjust according to metric/english setting
conversion : 12 #Unit conversion value, do not change
ltol$ : 0.002 #Length tolerance for arccheck
vtol$ : 0.0001#System tolerance
maxfeedpm : 500 #Limit for feed in unit/min
pconsmet #Metric constant variables
conversion = 1000
ltol$ = 0.05
vtol$ = 0.001
maxfeedpm = 10000
# Format statements - n=nonmodal, l=leading, t=trailing, i=inc, d=delta
#Default english position format statements
fs 1 0.4 #Decimal, absolute, 4 place, default for initialize (
fs 2 0.4 #Decimal, absolute, 4 place
fs 3 0.4d #Decimal, delta, 4 place
#Metric position format statements
fs 22 0.3 #Decimal, absolute, 3 place
fs 23 0.3d #Decimal, delta, 3 place
#Common format statements
fs 4 1 0 #Integer, not leading
fs 5 2 0l #Integer, force two leading
fs 6 3 0l #Integer, force three leading
fs 7 4 0l #Integer, force four leading
fs 8 0 4t #No decimal, absolute, four trailing
fs 9 0.1 #Decimal, absolute, 1 place
fs 10 0.2 #Decimal, absolute, 2 place
fs 11 0.3 #Decimal, absolute, 3 place
fs 12 0.4 #Decimal, absolute, 4 place
fs 13 0.5 #Decimal, absolute, 5 place
fs 14 0.3d #Decimal, delta, 3 place
fs 15 0 3t #No decimal, absolute, 3 trailing
fs 16 0 2t #No decimal, absolute, 2 trailing
#Address string definitions
srad "R"
srminus "R-"
sblank
# Motion G code selection
sg00 G0 #Rapid
sg01 G1 #Linear feed
sg02 G2 #Circular interpolation CW
sg03 G3 #Circular interpolation CCW
sg04 G4 #Dwell
sgcode #Target for string
fstrsel sg00 gcode$ sgcode 5 -1 0
# Select work plane G code
sg17 G17 #XY plane code
sg19 G19 #YZ plane code
sg18 G18 #XZ plane code
sgplane #Target string
fstrsel sg17 plane$ sgplane 3 -1 0
#Select english/metric code
sg20 G20 #Inch code
sg21 G21 #Metric code
smetric #Target string
fstrsel sg20 met_tool$ smetric 2 -1 0
#Select reference return code
sg28 G28 #First reference point return
sg30 G30 #Second reference point return
sg28ref #Target string
fstrsel sg28 mi3$ sg28ref 2 -1 0
# Cutter compensation G code selection
scc0 G40 #Cancel cutter compensation
scc1 G41 #Cutter compensation left
scc2 G42 #Cutter compensation right
sccomp #Target for string
fstrsel scc0 cc_pos$ sccomp 3 -1 0
# Select incremental or absolute G code
sg90 G90 #Absolute code
sg91 G91 #Incremental code
sgabsinc #Target string
fstrsel sg90 absinc$ sgabsinc 2 -1 0
# Feed mode G code selection
sg94 G94 #UPM
sg94d G94 #DPM
sg93 G93 #Inverse
sgfeed #Target for string
fstrsel sg94 ipr_type sgfeed 3 -1 0
# Generate string for spindle
sm04 M4 #Spindle reverse
sm05 M5 #Spindle off
sm03 M3 #Spindle forward
spindle #Target for string
fstrsel sm04 spdir1 spindle 3 -1 0
# Coolant M code selection
sm09 M9 #Coolant Off
sm08 M8 #Coolant Flood
sm08_1 M8 #Coolant Mist
sm08_2 M8 #Coolant Tool
scoolant #Target for string
fstrsel sm09 coolant$ scoolant 4 -1 0
# Table rotation direction
sindx_m M22 #Rotate CCW code
sindx_p M21 #Rotate CW code
sindx_m2 M22 #Rotate CCW code
sindx_mc #Target for string
fstrsel sindx_m indx_mc sindx_mc 3 -1 0
sunlock M11 # Unlock Rotary Table
slock M10 # Lock Rotary Table
# Define the gear selection code
flktbl 1 3 #Lookup table definition - table no. - no. entries
40 0 #Low gear range
41 400 #Med gear range
42 2250 #Hi gear range
# Toolchange NC output
fmt O 7 progno$ #Program number
fmt T 4 t$ #Tool No
fmt T 4 first_tool$ #First Tool Used
fmt T 4 next_tool$ #Next Tool Used
fmt D 4 tloffno$ #Diameter Offset No
fmt H 4 tlngno$ #Length Offset No
fmt G 4 g_wcs #WCS G address
fmt P 4 p_wcs #WCS P address
fmt S 4 speed #Spindle Speed
fmt M 4 gear #Gear range
fmt 11 indx_out #Index position
fmt "TOOL - " 4 tnote # Note format
fmt " DIA. OFF. - " 4 toffnote # Note format
fmt " LEN. - " 4 tlngnote # Note format
fmt " DIA. - " 1 tldia$ # Note format
ptoolcomment #Comment for tool
tnote = t$
toffnote = tloffno$
tlngnote = tlngno$
"(", pstrtool, *tnote, *toffnote, *tlngnote, *tldia$, ")", e$
pstrtool #Comment for tool
if strtool$ <> sblank, pstrtool2
pstrtool2 #Comment for tool
strtool$ = ucase(strtool$)
*strtool$, " "
pcomment$ #Comment from manual entry
pcomment2
pcomment2 #Comment from manual entry
scomm$ = ucase (scomm$)
if gcode$ = 1007, "(", scomm$, ")"
else, "(", scomm$, ")", e$
pheader$ #Start of file
"%",e$
*progno$,e$
psof0$ #Start of file for tool zero
psof$
psof$ #Start of file for non-zero tool number
nextcflg$ = c9k
plast_recd
rc1 = one
gcode1 = rbuf ( one, rc1 )
if ntools$ = one, stagetool = two #skip single tool output
gcode$ = zero
cc_pos$ = zero
pspindle
pcom_movbtl
"(PROGRAM NAME - ", sprogname$,")",e$
"(DATE=DD-MM-YY - ", date$, " TIME=HH:MM - ", time$, ")",e$
ptoolcomment
comment$
pbld, n$, *smetric,e$
pbld, n$, *sgcode, *sgplane, "G40", "G49", "G80", *sgabsinc,e$
if mi1$ <= one, pg92_rtrnz, pg92_rtrn, pg92_g92
absinc$ = mi2$
if stagetool <> two, pbld, n$, *t$, "M6",e$
pindex
pbld, n$, *sgcode, *sgabsinc, pwcs, pfxout, pfyout, pfcout,
*speed, *spindle, pgear, pcan1,e$
pbld, n$, "G43", *tlngno$, pfzout, scoolant, [if stagetool = one, *next_tool$],e$
pcom_movea
ptlchg0$ #Call from NCI null tool change (tool number repeats)
if workofs$ <> prv_workofs$,
sav_nobrk = nobrk$
nobrk$ = zero
pctype
prv_x$ = vequ (xa)
pspindle
comment$
pbld, n$, sgplane, e$
if prv_spdir1 <> spdir1, [spdir1 = 1], pbld, n$, *spindle, e$
if prv_speed <> speed | prv_spdir1 <> spdir1,
pbld, n$, *speed, *spindle, pgear, e$
pbld, n$, scoolant,e$
ptlchg$ #Tool change
gcode$ = zero
pspindle
pcom_movbtl
if mi1$ = one, pg92_rtrn, pg92_g92
absinc$ = mi2$
pbld, n$, "M01", e$
ptoolcomment
comment$
pindex
pcom_movea
ptlchg1002$ #Call at actual toolchange
pctype
absinc$ = mi2$
prv_feed = c9k
linarc$ = zero
brklinestype$ = zero
xh$ = xh$ * x_mult
yh$ = yh$ * y_mult
zh$ = zh$ * z_mult
prv_xia = vequ (xh$)
if abs(ctype) = two & rotdia$ = zero, proterror
ptoolend$ #End of tool path
if gcode1 <> 1000, ptoolend_t
ptoolend_t #End of tool path, toolchange
gcode$ = zero
coolant$ = zero
absinc$ = one
if cc_pos$ <> zero, cc_pos$ = zero
pbld, n$, sccomp, "M5", e$
pbld, n$, sgabsinc, sgcode, *sg28ref, "Z0.", scoolant, e$
if mi2$ = one, pbld, n$, *sg28ref, "X0.", "Y0.", protretinc, e$
else, protretabs
protretinc #Reset the C axis revolution counter
if frc_cinit = one, presetrev
protretabs #Reset the C axis revolution counter
if frc_cinit = one, pbld, n$, *sg28ref, presetrev, e$
presetrev #Reset the C axis revolution counter
rev = zero
cabs = zero
prv_csav = zero
prv_cabs = zero
*scaxadrs
sav_spc = spaces$
spaces$ = zero
"0."
spaces$ = sav_spc
peof0$ #End of file for tool zero
peof$
peof$ #End of file for non-zero tool
ptoolend_t
pbld, n$, "G90",e$
comment$
if stagetool = one, pbld, n$, *first_tool$,e$
pbld, n$, "M30",e$
"%",e$
pwcs #G54+ coordinate setting at toolchange
if mi1$ > 1, pwcs_g54
pwcs_g54 #G54 coordinate setting
if workofs$ < 6, g_wcs = workofs$ + 54
else, p_wcs = workofs$ - 5
if workofs$ < 6 & (prv_g_wcs <> g_wcs | force_wcs = yes$), *g_wcs
if workofs$ > 5 & (prv_p_wcs <> p_wcs | force_wcs = yes$), "G54.1", *p_wcs
!workofs$, !g_wcs, !p_wcs
pwcs_2 #G54+ coordinate setting and position
absinc$ = zero
if (workofs$ < 6 & prv_g_wcs <> workofs$ + 54)
| (workofs$ > 5 & prv_p_wcs <> p_wcs),
pbld, n$, sgabsinc, pwcs_g54, pfxout, pfyout, pfzout, e$
absinc$ = mi2$
nobrk$ = sav_nobrk
pg92_rtrnz #Z home position return
absinc$ = one
pfbld, n$, sgabsinc, *sg28ref, "Z0.", e$
pg92_rtrn #XY home position return
pfbld, n$, *sg28ref, "X0.", "Y0.", e$
pg92_g92 #G92 coordinate setting at tool change
pfbld, n$, "G92", *xh$, *yh$, *zh$, e$
pgear #Find spindle gear
if use_gear = one, pgear2
pgear2 #Find spindle gear and output
gear = frange ( 1, speed )
*gear
pcan #Canned text - before output call
pcan1 #Canned text - with move
pcan2 #Canned text - after output call
if opcode1 = 3 & dwell$ <> zero & gcode$ = one, pdwell1
if cantext$ = one, pbld, n$, "M01", e$
if cantext$ = two, pbld, n$, "M00", e$
pspindle #Spindle speed calculations for RPM
speed = abs (ss1)
if speed > max_speed, speed = max_speed
if speed < min_speed, speed = min_speed
pctype #Determine the cut type
#Multisurf Rotary 4 axis or 11 gcode = one
#Axis substitution = two
ctype = zero
if nextop$ = 11, ctype = one
if (rotaxis$ = one & rot_on_x = one)
| (rotaxis$ = two & rot_on_x = zero), psuberror
if rotaxis$ = one | rotaxis$ = two, ctype = two
if rot_on_x = zero, ctype = -ctype
# Motion NC output
#The variables for absolute output are xabs, yabs, zabs.
#The variables for incremental output are xinc, yinc, zinc.
#They are found from the variables xa, ya, za.
#To prevent disturbing xa, ya, za they are used to calculate the output
#variables with multipliers.
fmt N 4 n$ #Sequence number
fmt X 2 xabs #X position output
fmt Y 2 yabs #Y position output
fmt Z 2 zabs #Z position output
fmt X 3 xinc #X position output
fmt Y 3 yinc #Y position output
fmt Z 3 zinc #Z position output
fmt 11 cabs #C axis position
fmt 14 cinc #C axis position
fmt I 3 iout #Arc center description in X
fmt J 3 jout #Arc center description in Y
fmt K 3 kout #Arc center description in Z
fmt R 2 arcrad$ #Arc Radius
fmt F 10 feed #Feedrate
fmt P 11 dwell$ #Dwell
prapidout #Output to NC of linear movement - rapid
pbld, n$, sgplane, sgcode, pccdia, pxout, pyout, pzout, pcout,
pcan1, e$
plinout #Output to NC of linear movement - feed
pbld, n$, sgfeed, sgplane, sgcode, pccdia, pxout, pyout, pzout, pcout,
pfr, pcan1, e$
pcirout #Output to NC of circular interpolation
parc, pfr, pcan1, e$
prapid$ #Output to NC of linear movement - rapid
pcom_moveb
if mi1$ > 1, pwcs_2
ppos_cax_lin
prapidout
pcom_movea
pzrapid$ #Output to NC of linear movement - rapid Z only
prapid$
plin$ #Output to NC of linear movement - feed
pcom_moveb
if mi1$ > 1, pwcs_2
if ctype = zero, ppos_cax_lin
plinout
pcom_movea
pz$ #Output to NC of linear movement - feed Z only
plin$
pmx$ #Output to NC of Multisurf Rotary
if fr$ = -2,gcode$ = zero
else, gcode$ = one
if gcode$ = one, plin$
else, prapid$
pcir$ #Output to NC of circular interpolation
pcom_moveb
if mi1$ > 1, pwcs_2
pcirout
pcom_movea
ppos_cax_lin #Position the rotary axis before move - rapid
if ctype = zero & fmtrnd(prv_cabs) <> fmtrnd(cabs), ppos_cax_lin2
pindex
ppos_cax_lin2 #Position the rotary axis before move - rapid
sav_gcode = gcode$
gcode$ = zero
pbld, n$, sgcode, pcout, e$
gcode$ = sav_gcode
pdwl_spd$ #Call from NCI gcode 4
ss1 = ss$
spdir1 = spdir$ + one
pspindle
comment$
pdwell1
if prv_spdir1 <> spdir1, pbld, n$, "M5", e$
pdwell2 #Output to NC of dwell
gcode$ = 4
pbld, n$, *sgcode, *dwell$, e$
pdwell1 #Check for zero dwell
if fmtrnd(dwell$) <> zero, pdwell2
pcom_movbtl #Common motion preparation routines, before, toolchange
xa = vequ(x$)
pxyzcout
ps_prvx
pcan
pcom_moveb #Common motion preparation routines, before
xa = vequ(x$)
pxyzcout
ps_prvx
comment$
pcan
pcom_movea #Common motion preparation routines, after
pcan2
pe_prvx
if cend$ = one, cflag = zero
# Motion output components
pbld #Canned text - block delete
if cantext$ = 3, bld = one
if cantext$ = 4, bld = zero
if bld = one, '/'
pfbld #Force - block delete
pccdia #Cutter Compensation
#Force Dxx#
if prv_cc_pos$ <> cc_pos$ & cc_pos$ <> zero, prv_tloffno$ = c9k
sccomp
if cc_pos$ > zero, tloffno$
pfxout #Force X axis output
if absinc$ = zero, *xabs, !xinc
else, *xinc, !xabs
pxout #X output
if absinc$ = zero, xabs, !xinc
else, xinc, !xabs
pfyout #Force Y axis output
if absinc$ = zero, *yabs, !yinc
else, *yinc, !yabs
pyout #Y output
if absinc$ = zero, yabs, !yinc
else, yinc, !yabs
pfzout #Force Z axis output
if absinc$ = zero, *zabs, !zinc
else, *zinc, !zabs
pzout #Z output
if absinc$ = zero, zabs, !zinc
else, zinc, !zabs
pfcout #Force C axis output
if index = zero, pfcout2
pfcout2 #Force C axis output
if absinc$ = zero, *cabs
else, *cinc
pcout #C axis output
if index = zero, pcout2
pcout2 #C axis output
if absinc$ = zero, cabs, !cinc
else, cinc, !cabs
parc2 #Arc output for R
if abs(sweep$) <= 180 | arcoutput$ = one, result = nwadrs(srad, arcrad$)
else, result = nwadrs(srminus, arcrad$)
*arcrad$
parc0 #Arc output for I, J, K
iout = i$ * x_mult
jout = j$ * y_mult
kout = k$ * z_mult
iout, jout, kout
parc #Select the arc output
if arcoutput$ = zero, parc0
else, parc2
pindex #Index output
if prv_indx_out <> fmtrnd (indx_out),
if lock_table = yes$, pbld, n$, *sunlock, e$
if index = one, pbld, n$, *sindx_mc, *indx_out, e$
else, pbld, n$, *indx_out, e$
if lock_table = yes$, pbld, n$, *slock, e$
if index <> zero, !cabs, !cinc
!indx_out
pffr #Output feedrate, force
*feed
pfr #Output feedrate
feed
# Drilling
usecandrill$ : yes$ #Use canned cycle for drill
usecanpeck$ : yes$ #Use canned cycle for Peck
usecanchip$ : yes$ #Use canned cycle for Chip Break
usecantap$ : yes$ #Use canned cycle for Tap
usecanbore1$ : yes$ #Use canned cycle for Bore1
usecanbore2$ : yes$ #Use canned cycle for Bore2
usecanmisc1$ : yes$ #Use canned cycle for Misc1
usecanmisc2$ : yes$ #Use canned cycle for Misc2
fmt Q 2 peck1$ #First peck increment (positive)
fmt 2 peck2$ #Second or last peck (positive)
fmt Q 2 shftdrl$ #Fine bore tool shift
fmt R 2 refht_a #Reference height
fmt R 3 refht_i #Reference height
drlgsel : -1 #Drill Select Initialize
drillref : 0 #Select drill reference
peckacel$ : 0 #Fractional percent to reduce peck2 when usecan.. : no
drlgcode : 0 #Save Gcode in drill
# Canned drill cycle string select
sg81 G81 #drill - no dwell
sg81d G82 #drill - with dwell
sg83 G83 #peck drill - no dwell
sg83d G83 #peck drill - with dwell
sg73 G73 #chip break - no dwell
sg73d G73 #chip break - with dwell
sg84 G84 #tap - right hand
sg84d G74 #tap - left hand
sg85 G85 #bore #1 - no dwell
sg85d G89 #bore #1 - with dwell
sg86 G86 #bore #2 - no dwell
sg86d G86 #bore #2 - with dwell
sgm1 G76 #misc #1 - no dwell
sgm1d G76 #misc #1 - with dwell
sgm2 G81 #misc #2 - no dwell
sgm2d G82 #misc #2 - with dwell
sgdrill #Target for string
fstrsel sg81 drlgsel sgdrill 16 -1 0
#Canned drill cycle reference height
sg98 G98 #Reference at initht
sg99 G99 #Reference at refht
sgdrlref #Target for string
fstrsel sg98 drillref sgdrlref 2 -1 0 # Drill cycle G string select
pdrill0$ #Drill, motion test
gcode$ = zero
znci$ = initht$ * x_mult
xa = vequ(xnci$)
pxyzcout
if mi1$ > 1, pwcs_2
pdrlcommonb #Canned Drill Cycle common call, before
if cstart$ = one, cflag = one
if drillcyc$ = 3, drlgsel = fsg1 (-ss1) + drillcyc$ * 2
else, drlgsel = fsg2 (dwell$) + drillcyc$ * 2
if initht$ <> refht$, drillref = 0
else, drillref = 1
z$ = depth$ * z_mult
if absinc$ = one, prv_zia = refht$ * z_mult
feed = fr_pos$
pcom_moveb
pindex
pdrlcommona #Canned Drill Cycle common call, after
pcom_movea
z$ = initht$ * z_mult
za = initht$ * z_mult
prv_zia = initht$ * z_mult
pxyzcout
prv_gcode$ = -1
prdrlout #R drill position
refht_a = refht$ * z_mult
refht_i = (refht$ - initht$) * z_mult
if absinc$ = zero, *refht_a
else, *refht_i
pdrill$ #Canned Drill Cycle
pdrlcommonb
pbld, n$, *sgdrlref, *sgdrill, pxout, pyout, pfzout, pcout, prdrlout,
dwell$, pffr, e$
pdrlcommona
ppeck$ #Canned Peck Drill Cycle
pdrlcommonb
pbld, n$, *sgdrlref, *sgdrill, pxout, pyout, pfzout, pcout, prdrlout, *peck1$,
pffr, e$
pdrlcommona
pchpbrk$ #Canned Chip Break Cycle
pdrlcommonb
pffr, e$
pdrlcommona
ptap$ #Canned Tap Cycle
pdrlcommonb
pffr, e$
pdrlcommona
pbore1$ #Canned Bore #1 Cycle
pdrlcommonb
dwell$, pffr, e$
pdrlcommona
pbore2$ #Canned Bore #2 Cycle
pdrlcommonb
pffr, e$
pdrlcommona
pmisc1$ #Canned Misc #1 Cycle
pdrlcommonb
shftdrl$, dwell$, pffr, e$
pdrlcommona
pmisc2$ #Canned Misc #2 Cycle (User Option)
pdrill$
prdrlout_2 #R drill position
if absinc$ = zero, refht_a
else, refht_i
pdrill_2$ #Canned Drill Cycle
pdrlcommonb
pbld, n$, pxout, pyout, pzout, pcout, prdrlout_2, dwell$, e$
pdrlcommona
ppeck_2$ #Canned Peck Drill Cycle
pdrill_2$
pchpbrk_2$ #Canned Chip Break Cycle
pdrill_2$
ptap_2$ #Canned Tap Cycle
pdrill_2$
pbore1_2$ #Canned Bore #1 Cycle
pdrill_2$
pbore2_2$ #Canned Bore #2 Cycle
pdrill_2$
pmisc1_2$ #Canned Misc #1 Cycle
pdrill_2$
pmisc2_2$ #Canned Misc #2 Cycle
pdrill_2$
pcanceldc$ #Cancel canned drill cycle
pbld, n$, "G80", e$
prv_dwell$ = zero
@dwell$
# Position calculations
#Unshifted machine position
xa : 0 #Absolute unshifted value for X
ya : 0 #Absolute unshifted value for Y
za : 0 #Absolute unshifted value for Z
#Incremental calculations
xia : 0 #Formated absolute value for X
yia : 0 #Formated absolute value for Y
zia : 0 #Formated absolute value for Z
#Rotary/Index output
csav : 0 #C saved value
prvcabs : 0 #Saved cout calculation from deg.
ctol : 225 #Tolerance in deg. before rev flag changes
cdelta : 0 #Calculation for angle change
rev : 0 #Calculation for deg/min
ixtol : 0.01 #Tolerance in deg. for index error
indx_dlt : 0 #Rotation direction calculation
indx_dlt2 : 0 #Rotation direction calculation
indx_mc : 0 #Rotation direction calculation
indx_out : 0 #Rotation direction calculation
aaxisx : 1 #A rotation vector
aaxisy : 0
aaxisz : 0
baxisx : 0 #B rotation vector
baxisy : 1
baxisz : 0
#Feed output control variables
ipr_type : 0 #0 = UPM, 1 = DPM, 2 = Inverse
frdegstp : 10 #Step limit for feed in deg/min
frdelta : 0 #Calculation for deg/min
frinv : 0 #Feedrate inverse time
frdeg : 0 #Feedrate deg/min actual
prvfrdeg : 0 #Feedrate deg/min actual
ldelta : 0 #Calculation for deg/min, linear
ccdelta : 0 #Calculation for deg/min, rotary
cldelta : 0 #Calculation for deg/min, linear and rotary
circum : 0 #Calculation for deg/min
ps_prvx #Incremental calculations, start
xia = fmtrnd(xabs)
yia = fmtrnd(yabs)
zia = fmtrnd(zabs)
xinc = vsub (xia, prv_xia)
cinc = cabs - prv_cabs
pe_prvx #Incremental calculations, end
!xia, !yia, !zia
!x$, !y$, !z$
#Pre-process rotary motion control flags
plin0$ #Linear movement, mill motion test
linarc$ = zero
if abs(ctype) = two, plin0_1
pcc_upd
plin0_1 #Set brklinestype
if ctype = two & cflag = one, brklinestype$ = 4
if ctype = -2& cflag = one, brklinestype$ = 5
pcir0$ #Circular interpolation, mill arc motion test
linarc$ = zero
if abs(ctype) = two, linarc$ = one
pcc_upd
pcc_upd #Update cc_pos for cutter comp. control
if ccomp$ <> 1 & nextcflg$ = 1000 & (nextccomp$ = two | nextccomp$ = 3),
cc_pos$ = nextccomp$ - one
if ((nextop$ = 1011 & ccomp$ = 4 & nextcflg2 = 1000 & prv_cc_pos$ = cc_pos2)
| (nextcflg$ = 1000 & ccomp$ = one & (nextccomp$ - one) = prv_cc_pos$)
| (ccomp$ = 4 & cend$ = one)), cc_pos$ = prv_cc_pos$
#Map coordinates
pxyzcout #Output values
if ctype = zero, pxyzcout_0 #Tool plane positioning
if abs(ctype) = one, pxyzcout1 #Multisurf Rotary
if abs(ctype) = two, pxyzcout2 #Axis substitution
xabs = xabs * x_mult
yabs = yabs * y_mult
zabs = zabs * z_mult
pcoutrev
pindxcalc
pfcalc
!xa, !ya, !za
prvcabs = fmtrnd(cabs)
#Toolplane positioning, ctype = 0
pxyzcout_0 #Multisurf rotary axis motion about X axis
xabs = vequ (xa)
csav = c$
if rot_ccw_pos = one, csav = -csav
#Multisurf Rotary, ctype = 1
pxyzcout_1 #Multisurf rotary axis motion about X axis
csav = atan2 (-vtooly$, vtoolz$)
axisx$ = vequ (aaxisx)
pxyzcout__1 #Multisurf rotary axis motion about Y axis
#CNC<<CONVERT>>pxyzcout-1 #Multisurf rotary axis motion about Y axis
#CNC<<MSG-ERROR(1007)>> Illegal character(s) encountered
csav = atan2 (vtoolx$, vtoolz$)
axisx$ = vequ (baxisx)
pxyzcout1 #Multisurf rotary axis motion
if ctype = one, pxyzcout_1 #Multisurf Rotary about X
else, pxyzcout__1 #Multisurf Rotary about Y
#CNC<<CONVERT>> else, pxyzcout-1 #Multisurf Rotary about Y
#CNC<<MSG-ERROR(1015)>> Illegal character(s) encountered
xabs = rotp (-csav, xa)
if rot_ccw_pos = zero, csav = -csav
#Y axis substitution, ctype = 2, directions are ok
pxyzcout_2 #Output values for Y axis substitution, top view
xabs = xa * x_mult
yabs = zero
zabs = (za + (rotdia$ / two)) * z_mult
csav = ya * (360 / (pi$ * rotdia$))
pxyzcout__2 #Output values for X axis substitution, top view
#CNC<<CONVERT>>pxyzcout-2 #Output values for X axis substitution, top view
#CNC<<MSG-ERROR(1028)>> Illegal character(s) encountered
xabs = zero
yabs = ya * x_mult
csav = xa * (360 / (pi$ * rotdia$))
if ctype = two, pxyzcout_2 #Y axis substitution
if ctype = -2,pxyzcout__2 #X axis substitution
#CNC<<CONVERT>> if ctype = -2,pxyzcout-2 #X axis substitution
#CNC<<MSG-ERROR(1038)>> Illegal character(s) encountered
#Index calculations
pindxcalc #Index move calculations
if frac (abs(csav)/ctable) > ixtol & index = one, pindxerror
indx_dlt = prvcabs - cabs
indx_dlt2 = abs (indx_dlt)
indx_mc = zero
if indx_dlt < zero, indx_mc = one
if indx_dlt2 > 180, indx_mc = indx_mc + one
# Absolute Positioning 1 = M-Codes
# 3 = control takes shortest path
if index = 1 | index = 3,
indx_out = abs(csav)
# Signed direction calculation
if index = 2,
indx_out = csav
# Adjust format assignment
if frac(ctable),
result = newfs(11, indx_out)
else,
result = newfs(4, indx_out)
#Rotary axis revolution calculation
pcoutrev2 #Add or subtract 360 degree for position
if cdelta > zero, rev = rev - one
else, rev = rev + one
pcoutrev1 #If motion exceeds ctol, add wind-up
if abs(cdelta) > ctol, pcoutrev2
pcoutrev #Modify for wind-up
cdelta = csav - prv_csav
pcoutrev1
cabs = rev * 360 + csav
!csav
#Feedrate calculation
pfcalc #Feedrate calculations
ipr_type = zero
if fmtrnd(cabs) = prvcabs | index = one | opcode$ = 3
| (abs(ctype) = two & cflag = zero), pfcalc2
else, pfclc_deg_inv
pfcalc2 #Feedrate
if ipr_type <> prv_ipr_type, prv_feed = c9k
feed = fr_pos$
if feed > maxfeedpm, feed = maxfeedpm
prvfrdeg = feed
pfclc_deg_inv #Feedrate deg/min
circum = zabs * two * pi$
if circum = zero, circum = c9k #Don't allow Zero
ldelta = sqrt(((xabs-prv_xabs)/x_mult)^2+((yabs-prv_yabs)/y_mult)^2+((zabs-prv_zabs)/z_mult)^2)
ccdelta = ((abs(cabs - prvcabs))/360)*circum
cldelta = sqrt(ccdelta^2 + ldelta^2)
if cldelta = zero, cldelta = c9k
if ldelta = zero, cldelta = ccdelta
if use_frinv = one, pfcalc_inv
else, pfcalc_deg
pfcalc_inv #Feedrate inverse calculation
ipr_type = two
prv_feed = c9k
frinv = fr_pos$ / cldelta
if frinv > maxfrinv, frinv = maxfrinv
feed = frinv
pfcalc_deg #Feedrate deg/min calculation
ipr_type = zero #Change to one to force on DPM
frdeg = abs(ccdelta / cldelta) * abs(fr_pos$ * (360 / circum))
frdelta = abs(frdeg - prvfrdeg)
if frdelta > frdegstp | prv_feed = c9k, pfcalc_deg2
if frdeg > maxfrdeg, feed = maxfrdeg
pfcalc_deg2 #Feedrate deg/min control
prvfrdeg = frdeg #Control output of frdeg
feed = frdeg #Control output of frdeg
# Post setup and metric format conversion
pq$ #Setup post based on switch settings
if stagetool = one, bldnxtool$ = one
psetup #Setup post based on NCI settings
if arctype$ = one | arctype$ = 4, pijkengabs
else, pijkengdlt
if met_tool$ = one, pmetric
#Apply rotary axis address
result = nwadrs(scaxadrs, cabs)
result = nwadrs(scaxadrs, cinc)
result = nwadrs(scaxadrs, indx_out)
pmetric #Metric format, English is default
pconsmet
if arctype$ = one | arctype$ = 4, pijkmetabs
else, pijkmetdlt
#Metric conversion for position values
result = newfs(22, xabs)
result = newfs(22, yabs)
result = newfs(22, zabs)
result = newfs(23, xinc)
result = newfs(23, yinc)
result = newfs(23, zinc)
result = newfs(22, arcrad$)
result = newfs(9, feed)
#Drill calculations metric conversion
result = newfs(22, peck1$)
result = newfs(22, peck2$)
result = newfs(22, dwell$)
result = newfs(22, shftdrl$)
result = newfs(22, refht_a)
result = newfs(23, refht_i)
pijkmetabs #Metric ijk format, absolute
result = newfs(22, iout)
result = newfs(22, jout)
result = newfs(22, kout)
pijkmetdlt #Metric ijk format, delta
result = newfs(23, iout)
result = newfs(23, jout)
result = newfs(23, kout)
pijkengabs #English ijk format, absolute
result = newfs(2, i$)
result = newfs(2, j$)
result = newfs(2, k$)
pijkengdlt #English ijk format, delta
result = newfs(3, i$)
result = newfs(3, j$)
result = newfs(3, k$)
# Tooltable look ahead routine
# Toolchange information buffer - (var#, 1 for current, 2 for next)
wc1 : 1 #Initial count for write buffer 1
rc1 : 1 #Initial count for read buffer 1
size1 : 0 #Buffer 1 size
gcode1 : 0 #Buffer 1
cc_pos1 : 0 #Buffer 1
cc_pos2 : 0 #Buffer 1
opcode1 : 0 #Buffer 1
ss1 : 0 #Buffer 1
spdir1 : 0 #Buffer 1
nextdc1 : 0 #Buffer 1
nextcflg2 : 0 #Buffer 1
fbuf 1 0 8 0 0 #Buffer 1
upd_pmv : 0 #Saved count for the first point motion (0 is off)
ppmv_recd2 #Update the toolchange point move, variables to update in prv_
!cc_pos1, !opcode1, !ss1, !spdir1, !nextdc1
rc1 = upd_pmv
cc_pos1 = prv_cc_pos1
opcode1 = prv_opcode1
ss1 = prv_ss1
spdir1 = prv_spdir1
nextdc1 = prv_nextdc1
rc1 = upd_pmv
gcode1 = wbuf ( one, rc1 ) #rc1 is used to write also
upd_pmv = zero
ppmv_recd #Update the point move if null or cancel if toolchange
if gcode1 > 1000, upd_pmv = zero
else, ppmv_recd2
plast_recd #Update the last record with the current information (2)
rc1 = wc1 - one
if nextccomp$ = zero | nextccomp$ = one | nextccomp$ = 4, cc_pos2 = zero
if nextccomp$ = two, cc_pos2 = one
if nextccomp$ = 3, cc_pos2 = two
nextcflg2 = nextcflg$
rc1 = wc1 - one #rc1 is used to write also
if upd_pmv <> zero & prv_opcode$ <> 15, ppmv_recd
pcur_recd #Write to the current tool record (1)
gcode1 = gcode$
cc_pos1 = cc_pos$
if opcode$ = 3, cc_pos1 = zero
opcode1 = opcode$
ss1 = ss$
nextdc1 = nextdc$
gcode1 = wbuf ( one, wc1 )
pwrtt$ #Buffer toolchange information
if gcode$ = 1001, psetup
#test for toolchange point move (opcode 15) update
if gcode$ <> 1001, plast_recd
pcur_recd
if gcode$ > 1000 & opcode$ = 15, upd_pmv = wc1 - one
!opcode$
# Error messages
psuberror #Arc output not allowed
"ERROR - WRONG AXIS USED IN AXIS SUBSTITUTION", e$
proterror #Rotaxis diameter not set
"ERROR-ROTARY AXIS DIAMETER VALUE NOT SET", e$
rotdia$ = 0.1#Avoid divide error
pindxerror #Index increments are not correct
"ERROR-INDEX BY ", *ctable, " DEGREES", e$
# Numbered questions for Mastercam
38. Rapid feedrate? 300.0
80. Communications port number for receive and transmit (1 or 2) ? 2
81. Data rate (110,150,300,600,1200,2400,4800,9600,14400,19200,38400)? 300
82. Parity (E/O/N)? E
83. Data bits (7 or 8)? 7
84. Stop bits (1 or 2)? 2
85. Strip line feeds? N
86. Delay after end of line (seconds)? 0
87. Ascii, Eia, or Binary (A/E/B)? A
88. Echo keyboard to screen in terminal emulation? n
89. Strip carriage returns? N
90. Drive and subdirectory for NC and Material files?
91. Name of executable post processor? MP
92. Name of reverse post processor? RP
93. Reverse post PST file name? RPFAN
100. Number of places BEFORE the decimal point for sequence numbers? 3
101. Number of places AFTER the decimal point for sequence numbers? 0
103. Maximum spindle speed? 5000
107. Average time for tool change (seconds)? 2.0
158. Use wear compensation for pocket finish passes? n
159. Compensate the first and last point in cutter comp. in control simulation? y
160. Display first and last entity in toolpath when simulating cutter compensation in control? y
161. Enable Home Position button? y
162. Enable Reference Point button? n
163. Enable Misc. Values button? y
164. Enable Rotary Axis button? n
165. Enable Tool Plane button? y
166. Enable Construction Plane button? y
167. Enable Tool Display button? y
168. Check tplane during automatic work origin creation? n
#110. Default tool library? TOOLS.TL7
# Default Miscellaneous Real Values
201. Default miscellaneous real variable 1 (mr1)? 0.0
202. Default miscellaneous real variable 2 (mr2)? 0.0
203. Default miscellaneous real variable 3 (mr3)? 0.0
204. Default miscellaneous real variable 4 (mr4)? 0.0
205. Default miscellaneous real variable 5 (mr5)? 0.0
206. Default miscellaneous real variable 6 (mr6)? 0.0
207. Default miscellaneous real variable 7 (mr7)? 0.0
208. Default miscellaneous real variable 8 (mr8)? 0.0
209. Default miscellaneous real variable 9 (mr9)? 0.0
210. Default miscellaneous real variable 10 (mr10)? 0.0
# Default Miscellaneous Integer Values
301. Work Coordinates [0-1=G92, 2=G54's] (mi1)? 2
302. Absolute or Incremental [0=ABS, 1=INC] (mi2)? 0
303. Reference Return [0=G28, 1=G30] (mi3)? 0
304. Miscellaneous integer variable 4 (mi4)? 0
305. Miscellaneous integer variable 5 (mi5)? 0
306. Miscellaneous integer variable 6 (mi6)? 0
307. Miscellaneous integer variable 7 (mi7)? 0
308. Miscellaneous integer variable 8 (mi8)? 0
309. Miscellaneous integer variable 9 (mi9)? 0
310. Miscellaneous integer variable 10 (mi10)? 0
# Configuration File association parameters (default is "y")
400. Name of associated cfg file?
401. Read SYSTEM COLORS section? y
402. Read ALLOCATIONS section? y
403. Read TOLERANCES section? y
404. Read DATA PATHS section? y
405. Read COMMUNICATIONS section? y
406. Read DRAFT SETTINGS section? y
407. Read MISCELLANEOUS section? y
408. Read NC SETTINGS section? y
409. Read DIALOG SCRIPTS section? y
410. Read DESIGN SETTINGS section? y
411. Read PLOTTER SETTINGS section? y
412. Read ALT-KEY ASSIGNMENTS section? y
413. Read CAD section? y
414. Read START/EXIT section? y
415. Read SCREEN section? y
416. Read FILE NAMES section? y
[CTRL_MILL|DEFAULT]
[misc integers]
1. //2
[CTRL_MILL|JJMPFAN]
[misc integers]
1. //2
[CTRL_TEXT_END]
Old 11-28-2010, 05:21 PM
More information?
Anybody?
[IMG] code is Off
Need Help!- post processor problems meldusa BobCad-Cam 0 02-26-2010 02:06 PM
Post Problems? MSPP BobCad-Cam 3 10-10-2007 08:36 AM
Post problems Ken_Shea Forum Questions or Problems 0 05-05-2007 12:45 PM
Post Problems SPEEDRE Vectric 1 03-26-2006 05:33 PM
Post Problems rfstar GibbsCAM 26 04-27-2004 12:39 PM
