Have an Anderson CNC wood router which has two spindles.
Looking for software which has a PP to handle this as I use both spindles and require the PP to be able to alternate between them.
Spindle 1 is T1 and spindle 2 is T2.
Each spindle has its own tool changer which hold eight tools each.
EG if I need tool 2 on spindle 1 then it becomes T12 or if I need tool 2 on Spindle 2 then itis T22.
The mcodes are M11 for tool down for tool start is M13 for spindle one and M21 and M23 for spindle 2.
The spindles can manually be moved towards or away from each other.
The macine runs with a Fanuc OM controller.
I also have a software product called VCarve Pro which has ATC capabilities but only with one spindle.
Your assistance is greatly appreciated.
Kind regards,
John
