Results 1 to 4 of 4
Thread: Add coolant to post processor? M8,M9
    Registered beezerlm's Avatar
    Oct 2005
    Hello,
    Does anyone know how to alter a post that uses M13 as "spindle on flood coolant" to output an M03 and M08 instead? Then use an M09 to stop the coolant at the end of the event? I have attached the post processor for review.
    Thanks,
    Brandon
    Attached Files Attached Files
    Oct 2005
    Are you sure it is a Post item? Coolant and what type is usually in the CAM portion of setting up the job. There is usually a choice of what kind of coolant. Mist, flood, in tool.
    Oct 2005
    I am pretty sure its in the post because when I select no coolant I get an M3 and when I select flood coolant I get an M13.
    Mar 2009
    U.S
    Hi BEEZERLM,
    I think if you change M13 in this post on the spindle codes section to M03 and save file it should work.
    I'm not a post programmer but from doing some minor modifying to some of mine I think it should fix the problem.
    always be sure to make a backup before changing or modifying your post just incase you screw it up you have something to go back to : )
    if that doesn't fix it send me a pm and I will look at your post more in detail
    Tmills
    # Spindle codes
    sm04 M04 # Spindle reverse - no coolant
    sm05 M05 # Spindle off - no coolant
    sm03 M03 # Spindle forward - no coolant
    sm04f M14 # Spindle reverse - flood
    sm05f M05 # Spindle off - flood
    sm03f M13 # Spindle forward - flood (Replace M13 with M03)
    sm04m M04 # Spindle reverse - mist (off if not supported)
    sm05m M05 # Spindle off - mist
    sm03m M03 # Spindle forward - mist (off if not supported)
    sm04t M04 # Spindle reverse - tool (off if not supported)
    sm05t M05 # Spindle off - tool
    sm03t M03 # Spindle forward - tool (off if not supported)
    spdlon # Target Spindle-on M-string
    spdlsel = fsg2(coolant) * 3 + fsg3(ss) # Spindle on selector based on coolant
    # 0 = off, 1 = flood, 2 = mist,
    # 3 = thru spindle-tool
    fstrsel sm04 spdlsel spdlon
  1. Coolant post help
    By greenweanie in forum EdgeCam
    Last Post: 04-13-2010, 08:42 AM
