Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Post Processor Files
Post Processor Files Discuss post processor files here!
Old 08-27-2010, 05:52 PM
Colin is on a distinguished road
Mastercam V9 Agie CNC123 Wire Post
We have a legal copy of V9 and was supplied a post processor, called MPWAGIE. This has served us OK on 2D and 2D with angles. I now have need to do full 3D, a spline with the same form top and bottom, but on a taper. I am able to get the nci file from mastercam, but I am having trouble running the nc (geo) file on the machine. I am not sure if this is a post processing fault, or not.
Can anyone suggest if I am using the correct post processor, or if there is another one I should be using for full 4 axis control.
Regards, Colin
Old 08-29-2010, 05:17 PM
*Registered*
TheBigJW is on a distinguished road
I was having problems with V9 wire for a Sodick machine. Mastercam says I can't use splines for 4 axis wire cut. I tried converting splines to arcs but had to set the tolerance to .010 to get this to work. Not good enough. So we program the parts with Esprit and seems to work no problems. Am I missing something in Mastercam?
John
[IMG] code is Off
Need Help!- Need Agie Charmilles wire EDM post processor help LansB Post Processors for MC 12 03-16-2012 08:08 AM
AGIE 100 wire wtm5863743 EDM Machines 4 09-07-2010 07:20 AM
Need post for Agie wire EDM Surfcam Velocity sang sys Surfcam 1 12-08-2006 09:16 PM
Need post for Agie Wire EDM Surfcam Velocity sang sys G-Code Programing 0 12-04-2006 06:34 PM
