Pro/manufacture -number of decimal places arc events
I use pro/e and pro/man.
my post procesor is specifically for my Dynapath Delta 20 from the PTC website, but for some reason it outputs arc commands to 5 decimal places. the controll only takes 4. --all the linear events are the correct 4 places.
i found settings for decimal places in the MCD editor for the xyz linerar moves, and changing that value has the expected result.
but the field for places in an arc motion were greyed out. I was able to enable them and enter a value but it had no effect.
I'm pretty sure it should have worked but obviously it didn't and everybodies post processor is different and I'm going to have a hell of a time finding someone using pro/e with an old dynapath controll (on a Tree journeyman 325 mill) who has allready been down this road.
Are you using Gpost? I saw a Dynamite controller in the Gpost directory. In the fil file the first move is accuracy for arcs is .005. I think that this is where you are going to fix this issue. I can find out about this issue on Tuesday, or you can go to "mcadcentral". Not that this site is not going to help but these guys do proe/proman. You can also go to prouser and setup an account for manufacturing as well. We helped a guy in there with building his post. It took him awhile but it got done. If you are looking for a custom post I can get you in touch with a guy that can do this as well.
dynamite is different. i have a dynapath delta 20. I got the files from PTC's library of posts.
I have posted on mcadcentral and also just this morning joined the prouser group for manufacturing
these are the files I got from PTC
uncx01.p30 and uncx01.f30
this is my uncx01.f30 Is this a fil file? I'm unsure of the terminology
REDEF/ON $$ ALLOW SYMBOLS TO BE OVERWRITTEN
CYCFLG=0 $$ CREATE A SYMBOL = 0
FSTPNT=0 $$ CREATE A SYMBOL = 0
MNRWRD=0 $$ CREATE A SYMBOL = 0
CIRFLG=0 $$ CREATE A SYMBOL = 0
SIDE=0 $$ CREATE A SYMBOL = 0
SEQINC=0 $$ CREATE A SYMBOL = 0
mode=1
CIMFIL/ON,MACHIN $$ CAPTURE MACHIN
RSLT=POSTF(13) $$ SEND RECORD TO POST
SEQNO/OFF $$ TURN SEQUENCE NUMBERS OFF
INSERT/'(1)$' $$ WRITE BLOCK TO POST
CIMFIL/OFF $$ END MACHIN
CIMFIL/ON,LOADTL $$ CAPTURE LOADTL
CALL/SEQNUM $$ CALL SEQUENCE NUMBER MACRO
RSLT=POSTF(20) $$ SAVE RECORD
INSERT/'N',SEQ,'(9)' $$ OUTPUT N# (9)
REPEAT/20,5,1 $$ OUTPUT E1 WITH THE NEXT T
RSLT=POSTF(21) $$ LOAD SAVED RECORD
RECNUM=POSTF(7,1) $$ CREATE A SYMBOL = THE CURRENT RECORD NUMBER
LIMIT=100000 $$ CREATE A SYMBOL = A LARGE NUMBER
DO/PRESEL,COUNT=1,LIMIT $$ CREATE A DO LOOP TO FIND CUTTER COMP
RSLT=POSTF(14) $$ READ NEXT RECORD
RECTYP=POSTF(7,2) $$ CREATE A SYMBOL = RECORD NUMBER
CASE/RECTYP $$ CREATE A CASE TEST
WHEN/14000 $$ WHEN EOF IS FOUND
RSLT=POSTF(15,(RECNUM+1)) $$ RETURN TO BEGINING
COUNT=(LIMIT+1) $$ EXCEED LIMIT
CMPCHK=0 $$ CREATE A SYMBOL = 0
WHEN/2000 $$ WHEN A STANDARD POST RECORD
WORD=POSTF(7,3) $$ CREATE A SYMBOL = MAJOR WORD
IF(WORD.EQ.ICODEF(CUTCOM))THEN $$ IF IT IS CUTCOM
CMPCHK=1 $$ CREATE A SYMBOL = 1
ENDIF $$ END IF TEST
IF(WORD.EQ.ICODEF(SELECT))THEN $$ IF SELECT ID FOUND
FXTOFF=POSTF(7,4) $$ CREATE A SYMBOL = MINOR WORD
ENDIF $$ END ID TEST
IF(WORD.EQ.ICODEF(LOADTL))THEN $$ IF TOOL CHANGE IS FOUND
ENDCAS $$ END CASE
PRESEL)CONTIN $$ END OD DO LOOP
CIMFIL/OFF $$ END LOADTL
CIMFIL/ON,SPINDL $$ CAPTURE SPINDL
RSLT=POSTF(2,1,1867,1) $$ SIMULATION ON
RSLT=POSTF(2,1,1867,0) $$ SIMULATION OFF
INSERT/'N',SEQ,'(1)M3$' $$ OUTPUT N# (1)M3
CIMFIL/OFF $$ END SPINDLE
CIMFIL/ON,COOLNT $$ CAPTURE COOLNT
CIMFIL/OFF $$ END COOLNT
CIMFIL/ON,CUTCOM $$ CAPTURE CUTCOM
COMP=POSTF(7,4) $$ CREATE A VARABLE = MINOR WORD
CASE/COMP $$ CREATE A CASE TEST
WHEN/ICODEF(LEFT) $$ WHEN LEFT
SIDE=1 $$ CREATE A SYMBOL = 1
WHEN/ICODEF(RIGHT) $$ WHEN RIGHT
SIDE=2 $$ CREATE A SYMBOL = 2
WHEN/ICODEF(OFF) $$ WHEN CANCELED
SIDE=3 $$ CREATE A SYMBOL = 3
ENDCAS $$ END CASE
CIMFIL/OFF $$ END CUTCOM
CIMFIL/ON,RAPID $$ CAPTURE RAPID
MODE=0 $$ CREATE A SYMBOL = 0
CIMFIL/OFF $$ END RAPID
CIMFIL/ON,FEDRAT $$ CAPTURE FEDRAT
MODE=1 $$ CREATE A SYMBOL = 1
CIMFIL/OFF $$ END FEDRAT
CIMFIL/ON,5,5 $$ CAPTURE GOTO
RATE=POSTF(1,3,104) $$ CREATE A SYMBOL = CURRENT FEED RATE
XLOC=POSTF(1,3,414) $$ CREATE A SYMBOL = CURRENT X
YLOC=POSTF(1,3,415) $$ CREATE A SYMBOL = CURRENT Y
ZLOC=POSTF(1,3,416) $$ CREATE A SYMBOL = CURRENT Z
IF(MODE.EQ.0.AND.CYCFLG.EQ.0)THEN $$ IF A RAPID MOVE ONLY
INSERT/'N',SEQ,'(0)' $$ OUTPUT N# (0) NEXT TO...
POSTN/IN,24,XLOC,25,YLOC,26,ZLOC $$ X# Y# Z#
IF(MODE.EQ.1.AND.CIRFLG.EQ.0.AND.CYCFLG.EQ.0.AND.CMPCHK.EQ.0)THEN $$ IF A FEED MOVE ONLY
INSERT/'N',SEQ,'(1)' $$ OUTPUT N# (1) NEXT TO...
POSTN/IN,24,XLOC,25,YLOC,26,ZLOC,6,RATE $$ X# Y# Z# F#
ENDIF $$ END IF
IF(MODE.EQ.1.AND.CIRFLG.EQ.0.AND.CYCFLG.EQ.0.AND.CMPCHK.EQ.1)THEN $$ IF A COMP MOVE
CMPCHK=2 $$ CREATE A SYMBOL = 2
JUMPTO/SKIP $$ JUMP DOWN TO SKIP
ENDIF $$ END IF
IF(MODE.EQ.1.AND.CIRFLG.EQ.0.AND.CYCFLG.EQ.0.AND.CMPCHK.EQ.2)THEN $$ IF A COMP MOVE
CMPCHK=3 $$ SET A SYMBOL TO 3
ENDIF $$ END IF
IF(MODE.EQ.1.AND.CIRFLG.EQ.0.AND.CYCFLG.EQ.0.AND.CMPCHK.EQ.3)THEN $$ IF A COMP MOVE
INSERT/'N',SEQ,'(1)X0/Y0/C0$' $$ OUTPUT N# (1)X0Y0C0
POSTN/IN,24,XLOC,25,YLOC,6,RATE,3,SIDE $$ OUTPUT X# Y# F# C#
POSTN/IN,26,ZLOC,6,RATE $$ OUTPUT Z# F#
ENDIF $$ END IF
IF(SIDE.EQ.3)THEN $$ IF SYMBOL = 3
ENDIF $$ END IF
SKIP) $$ JUMPTO LABEL
IF(MODE.EQ.1.AND.CIRFLG.EQ.1)THEN $$ IF A CIRCLE
INSERT/'N',SEQ,'(',DIR,')' $$ OUTPUT N# (1 OR 2) NEXT TO...
INSERT/'X',XLOC,'Y',YLOC,'Z',ZLOC,'I',ILOC,'J',JLOC,'F',RATE,'$'
ENDIF $$ END IF
IF(CYCFLG.EQ.1)THEN $$ IF SYMBOL = 1 THEN
IF(FSTPNT.EQ.0)THEN $$ IF SYMBOL = 0 THEN
POSTN/IN,24,XLOC,25,YLOC $$ X# Y#
ENDIF $$ END IF
ENDIF $$ END IF
CIMFIL/OFF $$ END GOTO
CIMFIL/ON,3 $$ CAPTURE CIRCLE
CIRFLG=1 $$ CREATE A SYMBOL = 1
ILOC=POSTF(7,9) $$ CREATE A SYMBOL = X ARC CENTER
JLOC=POSTF(7,10) $$ CREATE A SYMBOL = Y ARC CENTER
IF(POSTF(7,14).EQ.-1)THEN $$ IF THE CIRCLE NORMAL IS -1,( RECORD 14 )
DIR=2 $$ CREATE A SYMBOL = 2
ELSE $$ ELSE
DIR=3 $$ CREATE A SYMBOL = 3
CIMFIL/OFF $$ END CIRCLE
CIMFIL/ON,CYCLE $$ CAPTURE CYCLE
DPTH=POSTF(7,6) $$ CREATE A SYMBOL = TOTAL DEPTH
FED=POSTF(7,8) $$ CREATE A SYMBOL = FEED RATE
INC=POSTF(7,10) $$ CREATE A SYMBOL = INCREMENT
PLG=POSTF(7,12) $$ CREATE A SYMBOL = PLUNGE CLEARANCE
TYPE=POSTF(7,4) $$ CREATE A SYMBOL = MINOR WORD
IF(TYPE.EQ.ICODEF(OFF))THEN $$ IF SYMBOL = OFF
CYCFLG=0 $$ SET SYMBOL = 0
ELSE $$ IF SYMBOL IS NOT = OFF
CYCFLG=1 $$ SET SYMBOL = 1
ENDIF $$ END TEST
SUBTYP=POSTF(7,4) $$ CREATE A SYMBOL = MINOR WORD
CASE/SUBTYP $$ TEST MINOR WORD
WHEN/ICODEF(DRILL) $$ WHEN DRILL
POSTN/IN,24,XLOC,25,YLOC,26,DPTH,23,PLG,6,FED,7,1 $$ OUTPUT X# Y# Z# W# F# G1
WHEN/ICODEF(DEEP) $$ WHEN DEEP
POSTN/IN,24,XLOC,25,YLOC,26,DPTH,11,INC,23,PLG,6,FED,7,3 $$ OUTPUT X# Y# Z# K# W# F# G3
WHEN/ICODEF(TAP) $$ WHEN TAP
WHEN/ICODEF(REAM) $$ WHEN REAM
POSTN/IN,24,XLOC,25,YLOC,26,DPTH,23,PLG,6,FED,7,2 $$ OUTPUT X# Y# Z# W# F# G2
WHEN/ICODEF(BORE) $$ WHEN BORE
POSTN/IN,24,XLOC,25,YLOC,26,DPTH,23,PLG,6,FED,7,5 $$ OUTPUT X# Y# Z# W# F# G5
WHEN/ICODEF(OFF) $$ WHEN OFF
POSTN/IN,7,0 $$ OUTPUT G0
ENDCAS $$ END CASE
FSTPNT=1 $$ CREATE A SYMBOL = 1
CIMFIL/OFF $$ END CYCLE
CIMFIL/ON,14 $$ CAPTURE END
RSLT=POSTF(2,1,1867,1) $$ TURN SIMULATION ON
RSLT=POSTF(13) $$ SEND BLOCK TO POST
RSLT=POSTF(2,1,1867,0) $$ TURN SIMULATION OFF
INSERT/'N',SEQ,'(9)M30$' $$ OUTPUT N# (9)M30
RSLT=POSTF(2,1,1847,1) $$ TURN EOB CHARACTERS OFF
INSERT/'END$' $$ OUTPUT END
CIMFIL/OFF $$ END END
SEQNUM=MACRO $$ SEQUENCE NUMBER MACRO
SEQINC=SEQINC+1 $$ INCREMENT SYMBOL BY 10
SEQ=TEXT/CONVF,SEQINC,4,0,0,1,1 $$ TURN THE SYMBOL INTO A FORMATTED TEXT STRING
TERMAC $$ END MACRO
