Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Post Processor Files
Post Processor Files Discuss post processor files here!
Old 05-20-2010, 02:13 PM
Atb115 is on a distinguished road
sufcam99
Recently I found a surfcam99 program stuck in a drawer and was playing around to see if i could get it to work and post a lathe program for Okuma LB12 OSP 500L-G cnc lathe. I used the Okums OSP series post that is standard to surfcamm99. Anyway it looks as though some preparatory functions are not posted. It needs a program stop at the beginning along with absolute positioning, metric units, and index turret. Is this a problem with the post processer and do I need to contact the surfcam or can someone on here help? Also noticed a G99 which as I remember was a unassigned EIA code. How can I find out what is assigned to that code? And does anyone have some suggestions? Thanks.
Old 06-01-2010, 03:10 PM
BuiltMachine is on a distinguished road
surf99 post help
I use surrf99 and have a cnc lathe fanuc though.
g99 is for feed per rev versus
g98 feed per minute.
That is the simple question.
The other about the post processor...
the lathe post will have a file with ext .L
the mill .M
the manipulation will be somewhat versatile I have found,
however not everything is workable.
I still cannot move the tool comment block into the tool it belongs,
rather it appears 2 blocks before the last tool ends.
I found the first tool change group of codes and added things directly
Like for the mill I made a G0G90G80G40G54
there and to start every tool.
And I was able to modify the rest to a satisfactory level.
Lookin surf99 directory for
postform.L
It probably looks like this inside where the applicable machine is
StartCode # Start of the program
%0
O0
End
1stToolChange # First tool change
T[Tool] t[Tool]
G[FeedType] G[SpeedType] S[Speed] M[Direct]
G0 X[V] Z[H] M[Cool]
End
Infeed # Enable cutter comp
G1 G41 X[V] Z[H] F[FRate]
End
Outfeed # Disable cutter comp
G1 G40 X[V] Z[H] F[FRate]
End
ToolChange # Secondary tool changes
M5 M9
T[Tool] t[Tool]
End
EndCode # End of the program
M5 M9
M30
%0
End
Maybe I can be more help for a specific tricky task.
Hope this will help some.
[IMG] code is Off
